Build the H.U.L.C Suit From the Movie Elysium
32,264
444
47
About: I enjoy building things and being creative.
After seeing the movie Elysium, with Matt Damon, I knew I had to do the costume for Halloween! This was a challenging build and my first time working with foam. This build took a month and over 100 hours.
I'm a huge fan of Neill Blomkamp, I also did a District 9 costume some years back.
https://www.instructables.com/id/District-9-themed-...
The cost was surprisingly low though. PIC HEAVY instructable! Enjoy guys! PLEASE be sure and VOTE!
Step 1: Inspiration
After scouring the internet for every screenshot and piece of concept art I could find, this is what I came up with. I did not do any mock ups or drawings of my own. I measured on my body relative to the pictures and drew on the foam.
Step 2: Tools and Materials
Tools:
Hack saw, scissors, pipe cutter, sander, band saw, pliers, hot knife, soldering iron, xacto knife, drill press, hot glue gun, high heat
Materials:
4pack garage floor foam mat, various thickness craft foam, metal wire coat hangers, high heat hot glue, various nuts, bolts and washers, 1/2" PVC, wood dowel, elastic string, nylon straps, velcro, needle, thread, eye screws, paint..... Lots of paint.... Spray on plastidip, old phone (for blue back lit LCD), 9 volt battery, led light, spare wiring.
Step 3: The Chest
I started by tracing out my chest piece on the thick foam mat and cutting it out with an exacto knife. I reinforced it with metal coat hanger wire from behind. Cutting a slot and use high strength hot glue to secure. I then added detail with a hot knife and layered thinner pieces of foam. I "weathered" it to make it look beaten and scratched, by melting the foam with the hot knife.
Step 4: The Arms
I used the same method as be for, cutting and strengthening with wire, to form the arms. I made loops with the wire to reinforce the holes where the points would be located. securing the joints with washers as well. I also used thick aluminum bar for the very top joint, as seen in the picture. I also glued on nuts to give it that industrial look. I cut out and attached the fore arm guards to corrugated plastic, attacking with aluminum plating. For the final touches, I coated with the spray plastadip, black paint and silver on the edges to make the metal look worn.
Step 5: The Back
After cutting out the parts, I added a joint in the back to give better mobility. I used one long, thick piece and attached all of the back segments to the strip. accenting with thin foam and large washers, detailing with a hot knife. Almost all gluing was done with high strength hot glue. In hind sight, the joints and thinner areas could have done with a stronger adhesive. I used the same paint method as before, plastadip and painting
Step 6: The Legs
The legs proved to be a greater challenge, needing a high range of motion and still looking the part. The same construction and paint process as detailed in the previous pages. I used a ton of straps and Velcro here!
Step 7: The Pistons
The biggest issue I ran into was the fact I used hot glue to build the pistons, attaching the washers to the PVC. Had I used epoxy instead this would have held up better. but I was in a time crunch and rushed it! I used PVC and wood dowel to form the piston body, capping it with a washer and using eyelet screws to attach. the pistons were held in place with a piece of string elastic. They worked really well and looked amazing!
Step 8: Head Piece
This was tricky, I took apart an old land line phone and used the LCD for the back panel. wiring it together with a blinking green LED to a 9V battery. Same construction process as detailed before. I attached it to my head with hair clips. this proved difficult to say the least!
Step 9: Putting It All Together
I attached everything with nylon straps an Velcro, most of which I hid under my blood stained shirt. I cut holes for the straps to go through. Most of the joints were attached with plain nuts and bolts, with lock-tite. It's easy to see in the pictures how this thing went together, then trying to explain in text!
Step 10: Final Thoughts.
I was really pleased with the outcome of this costume, people were blown away! mobility was great and everything actuated as it should have. As I said before, the biggest mistake I made was using high strength hot glue as my only adhesive. This was the first time I have ever worked with foam, so please be kind! I also made a pistol form the movie to go with the costume, but that's another episode ;-)
Fandom Contest
First Prize in the
Fandom Contest
PVC Challenge
Runner Up in the
PVC Challenge
    • Trash to Treasure
      Trash to Treasure
    • Paper Contest
      Paper Contest
    • Tape Contest
      Tape Contest
    47 Discussions
    AreThreeSeaTea
    2 years ago
    Nice build, best cheap exo suit I've seen. Would you be able to attach a full list of the materials and tools used as well as downloadable schematic files, that would be awesome!
    diybomber834
    3 years ago
    could you make a vault 111 suit how to im a big fan boy of fallout4
    desertsniperdiybomber834
    Reply 3 years ago
    I plan on doing some fallout related stuff, just not sure when I will get around to it! thanks though!
    diybomber834
    3 years ago
    is it a prop or a real exo suit?
    RianC1
    3 years ago on Introduction
    plz make 1 with less requirements or tell me other materials I could use to make this cause this looks super cool!
    desertsniperRianC1
    Reply 3 years ago on Introduction
    Well, I think this is about the most simple (and cheap) way to make a convincing exo-skeleton. What issues are you having with this build? maybe I can help?
    Thanks, I think I got 4 large 1" tiles (24"x24"?) for 20$ and at craft/ hobby store its around 50 cent for a thin 1/8" sheets. the only down side is you have to coat in plastidip spay before you paint, or normal spray paints will eat the foam. hope this helps!
    Unfortunately, the suit only lasted about 4 or 5 Halloween parties. The hot glue I used to hold the piston together gave out. It is no longer usable. I do custom work, if you would like something commissioned please PM me. thank you for the intrest!
    Louietacticaldesertsniper
    Reply 3 years ago
    Thank you for replying! You are very talented! I'm working on a new shooting vid for my yt channel and really want to end the vid with an exo suit in action blasting away. I would buy the one you made if you change your mind. Just give me a price. Maybe you can reglue the Pistons. Anyways keep up the awesome work brother! Here's my yt channel if you're curious on what kind of vids I do. The suit would be epic in my new one! Best regards,
    Louie
    www.youtube.com/louietactical
    MadMike3
    well, very interesting, when I first saw the instructable, I thought some one had created a real cheap exo thingy, then the word foam cropped up, lol, looks good/great even, not seen the movie however, but as got me to thinking, along the lines of someone else who seems interested in a real world unit,. When carbon nano tubes go mainstream, thats the weight sorted, fluid for hydrolics, soz my spelling. pnematics, may not be up to the task, newer tech batteries supply what ever we can come up with, I have not yet hasd the privalage of seeing ur iron man suit... 3d printing is abot to take off big time in all of various materials ,,, titanium being one, the future is looking scary........................................
    nice one though
    desertsniperMadMike3
    Elysium is a great movie, check it out! The future definitely have some amazing things on the horizon. thanks for the complement!
    desertsniperHonus
    Also i'm a huge fan of your work. My fiancé and I made our own wedding rings. I studied your posts thoroughly, your ironman suit is amazing.
    Honusdesertsniper
    Thanks! That's really cool that you were able to make your own rings!
    After Elysium came out I immediately wanted to make a H.U.L.C. suit but I never thought of using eyelets for the ends of the actuators- that's a super cheap solution as the Igus rod ends Weta used aren't inexpensive.
    desertsniperHonus
    We ended up using "a wedding ring experience" a site dedicated to just such a venture. they provided a class and all the tools. I used a silver and gold Mokume Gane billet for my ring and she used white gold. ill post a pic when I can.
    I had contemplated doing a better build, using poly or pvc sheet, aluminum rod/tube and the actual rod connectors. but it would end up costing about 1.5k. plus I had less then a month for the build. I though of this way, I even used foam plugs in the eyelets, washers and springs in areas that needed greater mobility. the entire project cost around 100$
