Build Your Own ""Banksy's Self-Destruct Artwork Frame"
927
About: Fab Lab Irbid is a small-scale workshop for personal digital fabrication, equipped with an array of flexible computer controlled tools and various materials, with the aim to make almost anything.
When the Balloon Girl self-shredded itself after hitting a 1.4 million dollars, our inner makers started analyzing how it's done.
There were 2 initial ideas in our mind:
  • The first was that blades were fixed on the base of the frame and two wheels held the painting in place and when they turned the painting would move over the blades and shred itself.
  • The second was that there was an actual paper shredder in the bottom of the painting, which would make sense giving how perfect the slices were for the actual painting and how big the frame was.
We decided to go with the first option.
Step 1: Materials and Tools.
In case you want to make your own Shredder , you'll need the following:
  1. DC Motor High torque "12 v"
  2. 9V High drain battery.
  3. Razors
  4. 3D printed rollers.
  5. Metal Rods " Diameters : 12mm , 8 mm "
  6. MDF "6.5 mm"
  7. Acrylic " 6 mm" for the shredder box
  8. Arduino
  9. Bluetooth Module HC-05.
  10. H-Bridge
Step 2: Design and Manufacturing
The design goes through different steps like 3D printing, laser cutting, metal & electronics.
Drew the design on SolidWorks.
  • 3D printed parts:
We have design the rollers with different inner holes diameters, to match our different rods sizes.
The rollers are consisted of two parts:
  1. Inner rigid PLA part that was printed on Ultimaker +2
  2. Outer part that was printed on the Witbox 2 using Ninga-flex material.
  • Laser cutting parts:
  1. Shredder box : We have designed a geared system, in order to drive the two shafts at the same time with speed reduction.
Using Acrylic with "6 mm " thickness, then cut it using the Trotic speedy 400.
using the following settings:
- Speed : 0.25
- Power : 89%
- Frequency : 1000
Then we made all the shredder enclosure as shown in the pictures.
2. Body : we have designed the frame which will contain the shredder box and the painting. Using MDF "6.5 mm " thickness, and cut it using the following settings:
- Speed : 0.25
- Power : 89%
- Frequency : 1000
Step 3: Electronics
Connect the DC motor with an H-bridge, and the H-bridge was connected with the Bluetooth
The Arduino caod is attached.
Step 4: Experiment
The above video shows an experiment we did on our shredder.
The paper was cut into 6 pieces as shown.
    • Trash to Treasure
      Trash to Treasure
    • Arduino Contest 2019
    • Tape Contest
      Tape Contest
    9 Discussions
    seamster
    6 months ago
    Clever! I wondered if we'd see someone make a DIY version of this. And here it is, nice work! : )
    MikB
    5 months ago
    Fantastic. Now, the next iteration of this should be self resetting, so it can do it again without having to open the frame :)
    No, seriously -- if you have a reasonably large lcd monitor/screen, and a shallow printer (or artificially deep frame INTO the wall/alcove), followed by some razor blades (more blade, or a real shredder for more strips) ... scroll the picture down the screen at the correct rate for the printer emitting the paper version, which is immediately shredded and dropped out the bottom.
    Then it can reset and go again! With different pictures!
    Fablab_IrbidMikB
    Reply 5 months ago
    Hey there MikB!
    We actually can change the picture without opening the frame, we left an opening in the top where we can just slide the pictures in :)
    ronanry
    Question 6 months ago
    what is the file format of the file uploaded at the bottom ? 7zip doesn't seem able to open it
    Fablab_Irbidronanry
    Answer 6 months ago
    Hello,
    The file is a .rar file that can be opened using winrar.
    Let us know if it doesn't work and we'll upload the source files separately :)
    petercdronanry
    Answer 6 months ago
    Its a winrar file, 7zip wasnt working for me either, using an old version V9.38.
    After updating 7zip to the latest 18.05 it opens the file just fine.
    All the dxf files are in the Shredder 2 folder.
    Top dxf file saved as screenprint for an example.
