Build Your Own Foosball Table
18,207
145
8
Several months ago I was build custom ,,Corexy" 3D printer. Sister told me that she want Foosball table. So this inspired me to create 3d printed parts for Foosball table. So it will be cheaper than buy new from store. With all parts it cost to me 120Eur. It is not professional Foosball table, it just for fun playing with friends.
Step 1:
Step 2: The Tools
You will need following tools to build your Foosball table :
Electrical tools:
  • Table circular saw or portable circular saw
  • Jigsaw electric drill or cordless screwdriver
  • Eccentric sander or orbital sander.
  • Plunge router cutter
Other tools
  • Rubber hammer or pinch roller
  • Hand sander with sandpaper in different granulation
  • Spanner and screwdriver
  • Clamp hook
Step 3: List of Materials
Material required for the body and legs:
Body
The body consists of natural wood. The sides are made of 28mm board.
Required quantities :
65cm x 12cm x 2.8cm (Pole side )
118cm x 12cm x 2.8cm (Goal side)
Playfield
The playfield is made of one HPL board of 9 mm thickness.
118cm x 63cm x 0.9mm
HPL, High Pressure Laminate
Legs
The legs is used from chrome table legs
4x 60cm
Bolts, Nuts, Screw
26 x M5x35 bolts
26 x M5 nuts
200 x woodscrew 2.9x19
20 x woodscrew 2.9x9
30 x woodscrew 3x30
Bracket
8x bracket 90 degree
Step 4: 3d Printed Parts
M5 x 35mm - Foosball table Man Player
Screw 2.9x9mm - Foosball Rod Lid End Cap
Screw 2.9x9mm - Foosball_Handle_Grip
Screw 2.9x16mm - Foosball Rod Bearings
Screw 2.9x16mm - Foosball gate inside
Screw 2.9x16mm - Foosball gate outside
Screw 2.9x16mm - Foosball serving hole
Step 5: 3D Printed Foosball Table Accessories
8 rods with a diameter of 16 mm, hollow or solid
We need : 2x 87cm, 4x 95cm, 2x105cm
  1. 13 players in 2 colors that will fit the 16mm rods, and screws.
  2. 16 bushings with a profile of 28 mm diameter
  3. 8 grips fitting the 16mm rods
  4. 16 small rubber buffers or springs
  5. 36mm ball
Step 6: The Sides
Rod hole diameter - 28mm
Foosball serving hole diameter - 50mm
Step 7: Wood Lacquer
After 2 wood lacquer layers sand with 400 and 1000 grit. After that polished with paste.
Step 8: The Playfield
Add green vinyl wrap for playfield with white stripes. I was used the wet application method.
Step 9: The Legs
Playfield board is thick (9mm) Mine solution add additional 30mm MDF board.
Step 10: The Gates
For gates I was used mosquito net for windows.
Step 11: The Assembly and Final Result
Step 12: Foosball Scoreboard
    • Gardening Contest
      Gardening Contest
    • Tape Contest
      Tape Contest
    • Woodworking Contest
      Woodworking Contest
    8 Discussions
    koandoakndlaskn
    7 months ago
    follow me on instagram @dani_sian7 :)
    XD
    mc loner
    1 year ago
    what was your total cost of the whole build. you did a very good build very nice. loner
    ronanry
    1 year ago
    From my experience, (we have the same kind of "flat landscape" football table at work) the problem is the ball sometimes (too much often in my opinion :p ) is stuck in a corner and doesn't come back "alone" in the field.
    On "professionnal" table the corner are a little bit higher than the rest of the field, so the ball can come back in game (it's only for information, that's a great instructables and great idea)
    MoM33
    1 year ago
    However I think molding the players is a better idea.
    perfoMoM33
    Reply 1 year ago
    Nice I'ble thanks. I've been thinking of building one of these for a while.
    @ Mom33 please write an I'ble on how to mould the players at home..I'd be keen to find out how to do it an maybe combine the two....
    MoM33
    1 year ago
    Awesome guys!
    Swansong
    1 year ago
    Awesome! If I can find a place to store it I'd love to make one of these!
