Build a Plastic Vacuum Former
45,449
508
30
About: I like to create, no matter the medium. I've made furniture, digital models, costumes, props, videos, graphics, animations, restored a vehicle, etc.
I finally built my vacuum former after looking at builds and collecting parts for years.
If I ever build another one, this outlines everything I need and the tricks I learned along the way. To buy a vacuum former like this, I would have spent over $5,000. I spent a LOT less.
This is an all in one unit. I used heating elements from toasters ovens, and I did not upgrade the circuit breaker or voltage. The heaters are mounted at the top, and a lift arm raises the steel frame and holds it in place while the plastic heats. The lift arms lower the frames onto the platen/object and I flip a switch to activate the vacuum, sucking the plastic onto the object. This set up uses a single tank and a vacuum pump.
Originally I was going to rely on an oven and a shop vac, but decided to build something nicer. I started in Google Sketchup, designing for an 18x24 bed.
Supplies:
• (1) 3/4" Plywood sheet 4'-0"x8'-0" for (1) 18x24 perforated platen, (1) 18x24 platen base, (1) 22x28 stand base, (2)17.5"x2.6" shelving, (1) 18x24 heater box, etc (Note: A 16x22 bed would allow a standard 18x24 'For Sale' sign to fit into the frame.)
• (4) 8'-0" Oak 2x4s for framing- legs and shelf bracing
• (2) Rigid Casters
• (2) Swiveling & locking casters
#8 x 3" bugle head drywall screws for 2x4 to 2x4 connections
#6 x 2" bugle head drywall screws for plywood to 2x4 framing connections
• (16) #12 x 1" hex head bolts for casters. Be careful not to over tighten.
• (1) 1/2" Concrete board 3'-0"x5'-0" for the heater box
• Numerous 1-1/4" Zinc coated screws for the concrete board
• (2) Toaster Ovens. I bought them from Goodwill. They were $5.00 each. Look for the ones that have (4) heating elements. I've seen them have between (2) and (4). My 20 amp circuit breaker could only support (2) units with (6) total elements.
• (4) 3/8" 1-1/2" Hex Bolts at vertical to horizontal steel connection
• (4) 3/8" 2-1/2" Hex Bolts at the bottom table connection
• (4) 3/8" 3" Hex Bolts at the top table connection
• (12) 3/8" Nuts
• (20) 3/8" Washers
• (2) 3/8" 1-1/2" Hex Bolts for tank mounting
• (1) #10-32 cap screw 2" for pump mounting
Fire stop caulk for the concrete board joints and holes for wire
Contact cement to attach the aluminum plate to the plywood platen. I re-glued it with Gorilla Glue.
• (2) 5" long 1/4" Hex bolts for base of lift arm
• (6) 1.5" long 1/4 bolts for lift arm joint
• (2) 3" long 1/4" bolts & nuts lift arm to frame
• (2) 2" long 1/4" bolts & nuts to prevent the frame from rotating. These do not attach to the lift arm, but to the steel slider.
• (4) Nylon spacers for 1/4" bolts for lift arm connections
• (4) pieces of steel for lift arm to lift arm connection. I used 1/16"x3"x3" steel.
• (2) pieces of steel for the frame bracket. I used .25"x3"x3" steel.
• (2) 1"x1"x 32" longer wood lift arm. Doing this again, I'd use steel tube.
• (2) 1"x1"x18" shorter wood lift arm. Doing this again, I'd use steel tube.
• (12) 1/16"x1.5"x1.5" Aluminum angle for the heater brackets
• (4) 1.5" long 1/4 bolts & nuts that connect the metal plate lift bracket to the wood lift arm
• (4) #12 x 1" hex head bolts for the closet flange
• Paint - I used a gloss gray base, satin white mid-coat, and a green color coat
Round Aluminum Duct- For the control panel. Round aluminum duct is cheaper than flat sheet metal. While it's thinner, it's $3 instead of $30
Steel Supplies:
I bought steel from a local welding shop. You can check http://www.onlinemetals.com, their prices are fair and shipping isn't bad if you can't find a local source.
• (1) 1/2" 16 gauge expanded aluminum 16"x22" sheet
• (2) 1/2" 16 gauge expanded aluminum 16"x3" strips
• (1) 16 gauge aluminum plate 19.5”x25.5” (I sized this to wrap around the edges of the plywood.
• (4) 33” 1"x.125" steel square tube for vertical heater support
• (2) 19” 1"x.125" steel square tube for horizontal heater support
• (2) 10” 1"x.125" steel square tube sliders
• (4) 18” long 1”x1"x.125" steel angle for the frame
• (4) 25" long 1”x1"x.125" steel angle for the frame
Doing this again, I would make the lift arms steel tube.
Plumbing Supplies:
Galvanized fittings are cheaper than brass, so get galvanized when you can. The barbed fittings only come in brass.
Some of these components I got at a big box store, some I could only find at a hardware store.
I used a 1/2" check valve because I could only find the 3/8" size for an industrial application at a specialty plumbing store which was very expensive.
• (1) 1/2" galvaznied nipple from air tank to tee
• (1) 1/2" ball valve for tank
• (1) 1/2" galvanized nipple from valve to tee
• (1) galvanized 3/4" to 1/2" reducer tee fitting off air tank
• (4) 3/4" hose barb 3/4" fitting at tee, release valve, platen flange
• (1) 3/4" galvanized closet flange
• (1) 3/4" ball valve for platen
• (1) 1" galvanized 2 hole pipe strap
3/4" clear vinyl hose
• (1) 3/4" to 1/2" coupling
• (1) 1/2" fitting to 3/8" barb fitting
• (1) 3/8" galvanized tee fitting
• (4) 3/8" hose barb 3/8" fitting
• (2) 1/4" coupling from pump and for gauge
• (1) 3/8" hose barb 1/4" fitting at pump and at gauge
• (1) 1/2" check valve
• (2) 3/8" hose barb 1/2" fittings for the check valve
3/8" clear vinyl hose
Plumber's Tape for the vacuum line fittings
11 gallon air tank from Harbor Freight (find a coupon)
2 stage 3 cfm vacuum pump from Harbor Freight (find a coupon)
Vacuum gauge. I wanted one that just displayed inHG and was center mounted.
I could have deleted the 1/4" coupling and 3/8" hose barb 1/4" fitting and instead used a 1/4" to 1/2" fitting to connect the pump to the check valve. Doing this again, I would have added a nipple on each end of the 3/4" ball valves and done 90* fittings on each end, with a 90* fitting at the closet flange. This would have resulted in straight stretches of vinyl hose and shorter runs.
Electrical Supplies:
• (2) Toggle switches - 20 amp, single pole single throw
Safety cover switch for the oven switch (because it looks cool) and distinguishes the two switches.
• (2) junction box
• (6) 3/8" twin screw cable clamp
duplex receptacle
• 1/2" EMT conduit
1/2" EMT strap
• Black 14 gauge solid wire
• White 14 gauge solid wire
• (1) 3 prong cord. I salvaged mine from a computer power cord.
Wire Nuts. I used sizes for (2) 14 gauge wires and (3) 14 gauge wires.
Tools:
• Measuring tape & pencil to mark lengths, attachment locations, etc
• Circular Saw/Table Saw to cut the plywood and 2x4s
• Punch to mark drill holes
• Drill/drill press for pre-drilling holes and attachment
• Sanding block to smooth any rough edges from cuts
• Clamps to secure wood (lots of clamps)
• Rubber mallet to adjust secured wood
• Round file in case any drilled bolt holes need enlargement
• Flat file for metal edges
• Jig saw with metal cutting blade
• Socket wrench with 3/8" and 1/4" sockets for the bolts
• Adjustable wrench for plumbing fittings
• Screwdriver
• Solder iron for heater connections
• Test light to confirm you've wired everything correctly
Cost:
• $70 for wood and associated screws
• $16 for casters
• $160 for all steel
• $100 for plumbing fittings
• $10 on toaster ovens
• $15 Concrete board and associated screws
• $30 Air tank
• $130 Vacuum pump
• Welding - I have a friend that welds, so this didn't cost me anything. Done professionally, I would estimate $120-180. Right angle brackets and recessed screws could eliminate the need for welding.
• $8 Aluminum angle
• $30 Electrical supplies
• $15 Paint
TOTAL: $584
That isn't bad considering you'd spend five thousand buying one outright. Forgoing steel would only save an additional $100, and that's not worth it.
Safety:
This project runs the gamut of potential dangers. Caution is a good buzzword.
• This involves various power tools and saws that could remove fingers.
• The aluminum plate and steel tubes, when first cut, will be rough with burs that can cut you.
• When drilling, make sure you don't accidentally drill through anything you don't want to.
• While I tested the limits of a 20 amp circuit in this tutorial, you need to be careful when dealing with electricity.
• Setting up the hinged lift arms can lead to a smashed finger if the frames fall down, and there are plenty of locations where you could pinch a finger.
• Spray paint must be used outdoors in a well ventilated area. A respirator or mask is recommended. Allow time to dry fully.
• Wear old clothes for painting. Chances are paint will find a way to get on your clothes.
Step 1: Base
The table base is wood 2x4s and plywood. The verticals are 2x4s and the shelves are 2x4s for bracing with a plywood top. I split a 2x4 and used that to brace the top. I split the 2x4 for the top bracing as I knew I would be adding controls and gauges and needed the height.
While 2x4s aren't always square and straight, they are always cheaper than steel. To square up the shelves and top, once the 2x4's were attached to each other, I screwed in one corner of the plywood to the 2x4, and then clamped the 2x4s to align them with the plywood. The clamps help pull the 2x4's in line with the plywood edges. Then I screwed the plywood to the 2x4's while clamped.
I would clamp whatever piece I was attaching to mark holes for drilling. I added a 6" apron around the top for controls and release valve and because it matches the height of the heater box.
All holes are pre-drilled to avoid potential splitting. I used 3" screws when attaching through a 2x4 and 2" screws when attaching through plywood. The table was 36" high from top to bottom before casters. The casters add about 4" which is a perfect height.
I added a shelf above the base for the tank and pump, which created storage on the bottom. I'll probably store scrap plastic. The tank is attached through the plywood with hex head bolts and nuts. I drilled a hole in the leg supports for the tank. For the pump, I removed one of the bolts mounting it to the plate and replaced it with a 2" long #10-32 cap screw that runs through the plywood. Since this unit is mobile, I don't want to have to worry about the equipment sliding or moving. This way it's secure at all times.
The vertical heater supports are steel for rigidity and straightness. A steel tube slider will run in between the supports to lift and lower the clamping frames. It will lock into place at the top position to heat the plastic so that I don't have to hold it in place.
I drilled the holes in steel with a drill press. I clamped the steel to the base and used the holes in the steel as a guide for the holes drilled in the wood. This ensures the holes are straight. Make sure you have enough space for the slider. It should should slide easily but not wiggle. I used calipers for precision. I waxed the tracks so it would slide smoothly.
To help coordinate the location for the vertical supports, I attached a horizontal clamp for the bottom of the tubes to rest on, this makes clamping it to the table much easier than trying to hold it still vertically and horizontally. Hex head bolts secure the verticals to the table.
If any of your holes are off, a round file will help enlarge the hole.
I had to shim the steel with a washer between the tube and table to ensure the tubes were straight and level. This will help the heater box fit well.
A 3/4" hole was drilled through the top of the base. A 3/4" closet flange was screwed from the bottom. During finishing I will caulk between the flange and plywood. The platen will attach to the top of the base.
Step 2: Platen
The platen is 3/4" plywood sandwiching 1/4" tall, 3/4" thick plywood. A 3/4" hole is drilled through the bottom which will line up with the base. The expanded metal was screwed into the base to stop it from moving around. I don't know if the vacuum pulls hard enough to crush the platen, but I went ahead and took the precaution.
The bottom of the platen was attached to the top of the base from the bottom side with 1" wood screws. The overall size is 18"x24".
The angle iron frames have an inside clear size of 18"x24". If I did this again I would make it 16"x22". That way a standard large "For Sale" sign would fit in the bracket as the signs are 18"x24".
I used contact cement to attach the aluminum plate to the platen top. I later had to re-glue it with Gorilla glue. Before attaching, the board needs to be 1/8" less long and less wide than the bottom of the platen to account for the aluminum plate thickness. I wrapped the edges of the aluminum down 90* at the edges. If I build this again, I won't wrap the aluminum edges, while I like the look it was an added headache that isn't functional. Or if I do it again, I will account for the thickness of the aluminum first!
It looked really good the first time I bent the edges down. When I had to bend them up and recut the platen to fit the frames, it got a little beat up looking. Upon regluing, I took a small nail to ensure all of the openings were clear of glue or debris. I marked 1/16" holes at 1" on center, accounting for the 1/4" spacer around the perimeter. The spacer needs to be relatively small as it takes up air space. and the tank only holds so much. The larger this air space, the less effective the tank is at removing air.
I hammered the aluminum down on the sides with a rubber mallet.You want to bend the whole edge down evenly a little bit at a time.
Step 3: Oven
The oven box is plywood, fastened the same way as the base with bugle head drywall screws.
To attach the horizontal support, I placed a piece of steel tube between the supports and attached a horizontal clamp. This made clamping the horizontal supports much easier since the clamp stabilized it. Due to clearance, I drilled a 5/8" hole on the inside of the horizontal supports so the bolt heads wouldn't protrude as the concrete board rests directly against the steel.
The bolts of the horizontal supports intersect the outside plywood trim to hold the heater box in place.
I used concrete board as an insulator for the heater box. The concrete board was cut to fit the box and then screwed to the wood. I used fire caulk at all joints and seams. I attached the concrete board to the heater box with zinc coated screws.
I salvaged heating elements from toaster ovens. Cut the connections and then use a belt sander to clean it up. You could use a grinder, but you may accidentally grind right through the steel connectors.
I took the heating elements salvaged from the toasters ovens and began arranging them. You want the elements to be evenly spaced throughout. A ni-chrome wire heating kit would be easier, but it costs a couple hundred dollars.
I spaced my elements at roughly 3.5" on center and 3.5" from the perimeter of the box. While I originally was going to have (11) heating elements. My 20 amp breaker couldn't support it. I have (6) elements. I was going to craft brackets for the elements from metal leftover from the toaster oven shells, but decided to use 1.5" aluminum angle for a better looking and stronger finished product.
I drilled holes in the aluminum brackets to hold the ceramic posts. The ceramic posts should slide freely. The aluminum was trimmed to 1.5" lengths. and screwed to the concrete board.
Step 4: Lift Handle
I have a 10" piece of steel tube that will slide between the vertical supports on each side that lifts and lowers the steel plastic frames. It ensures the frames lower directly onto the platen.
I had thought about facing the sliders with nylon, but that proved too expensive. A bolt goes through the lift handle bracket, slider ube, and into a bracket welded to my angle iron frames. A second bolt goes through the slider and into the welded bracket to prevent the frames from rotating.
The lift handle is wood, as is the cross bar. I used scrap steel to create the hinge to connect the two arms using 1/4" bolts and nuts. Scrap steel bolted to the lift arms acts as the bracket to the frames.
The long lift arm is 32" long. The shorter is 18". One end of the shorter arm was rounded, so that it could rotate. I glued a stop on the bottom side of the lift arm. This allows the lift arms to lock into place and hold the frame at the top position near the heater without falling back down. A nylon spacer is between where the lift arm attaches to the base so the lift arm clears the bolts and vertical steel tubes.
If I had to build this again, I would consider attaching 1" steel tube to the bottom of the frame. It would make the attachment to the lift arm a little cleaner. I welded on a piece of steel to the frame. One bolt connects to the lift arms, the other bolt attaches to the slider to prevent the frame from rotating during use.
The sliders need to be short enough so that the frame contacts the table fully. A gap between the frame and table prevents a seal, making the vacuum less effective. I added weather stripping onto the table to ensure a good seal.
Step 5: Plumbing
Plumbing was determined as I went along. The fitting on the air tank is 1/2" female. The fitting on the vacuum pump is 1/4" male. I used 3/4" inner diameter tubing to the platen and 3/8" inner diameter tubing to the vacuum pump.
A 1/2" nipple connects the air tank to a 1/2" ball valve. Another 1/2" nipple connects the ball valve to the 3/4" to 1/2" reducer tee. One end of the reducer tee is a 3/4" thread 3/4" barb fitting. This side uses 3/4" vinyl tubing to connect to the 3/4" ball valve with 3/4" thread 3/4" barb fittings and the galvanized closet flange with a 3/4" barb fitting.
The other side of the tee has a 3/4" to 1/2" coupling and a 1/2" thread 3/8" barb fitting. This connects to a 3/8" threaded tee and 3/8" thread 3/8" barb fittings. One end of the tee goes to a 1/2" check valve with 1/2" thread 3/8" barb fittings and a 1/4" thread 3/8" barb fitting and 1/4" coupling to the pump. The other end goes to the vacuum gauge with a 1/4" thread 3/8" barb fitting and 1/4" coupling at the gauge. All threads were wrapped three to four times with plumbing/teflon tape. The tape helps seal and ensures connections attach smoothly. The tape should always be wrapped in the direction of the threads, and you want to start on the second thread.
A 1" two hole pipe clamp holds the ball valve in place on the control panel. The wood had to be recessed so the valve handle would clear the front of the panel.
Doing this again, the 3/4" barbs would screw into a 3/4" 90*, this would create straight runs of the vinyl tubing and shorten it by quite a bit.
Step 6: Electrical
Wiring this rig is an area I'm not as familiar with. While I assume there has to be a more efficient way, this is what I came up with based on trial and error and tripping the circuit breaker.
I salvaged a three-prong cord from an old computer monitor. This will plug the vacuum former into a wall outlet. I want this to be plug and play.
In the base, the power cord feeds to the junction box. From this junction box, one set of wires runs to the duplex receptacle for the vacuum pump, the other runs to the junction box on the oven. The junction boxes have a cable clamp for the wires at all locations where wires enter or exit the box. This ensures wire connections can't be loosened or disconnected.
An inline toggle switch is attached for the receptacle and the oven. I used a test light to confirm the switches were installed correctly. Testing the electrical at each step, narrows the possibilities if having problems later. I confirmed the pump worked, then confirmed I was getting power to the oven junction box before connecting the heaters. Whenever I did any electrical work, I confirmed it was unplugged.
The wood panel was recessed from the back so that the toggle switches would clear the front of the panel.
My heater box is built with a gap where the vertical supports extend up. This gap is where I have a junction box mounted. I have a piece of conduit running along the top so that the wiring can access both sides of the box and remain hidden from view. Conduit runs from the oven down to the base adjacent to the vertical support. A 1/2" EMT pipe strap secures both ends of all conduit.
I revised the number of elements from (11) to (6) based on what would NOT trip the breaker.
Some elements heat up to full temperature wired in series, some need to
be wired alone. Trial and error will determine. I looped the wire on the elements to test the setup before soldering. (2) groups of (2) elements are wired in series and (2) elements are wired straight.
If the elements don't glow red/orange, they aren't up to temperature.Let the heaters run for 5-10 minutes during testing. A few times in testing, the heaters wouldn't trip the breaker until they were at operating temperature.
All wiring connections in the junction boxes were wire capped and taped.
I didn't have a good way to test for even heating as I didn't have access to and didn't want to buy a thermal camera. In the test run, even before re-spacing the elements, it seemed to heat fairly well.
Step 7: Finish
I couldn't leave it plain. Even if you don't want to weather it, I recommend painting or staining it just to protect the wood.
I disassembled everything.
I painted all wood gloss gray. This will mimic a steel finish. I then sprayed everything with a satin white. The white will look like a prime coat. My color coat is a green. I wanted something more military green, but I had this on hand.
After spraying the white, I rubbed it off on edges, corners, and anywhere I wanted the 'steel' to be revealed with a shop towel.
Then I applied mustard where the green paint will 'flake' off to reveal the prime coat and steel. You want the mustard to overlap the white so the paint looks layered. This is going to be areas that wear more like edges. I also used salt, which gives a pitted finish. I had never tried salt before, and wish I had used more of it. Wet the salt slightly so it sticks better. Then you can spray the green. Once it dries, wipe off the mustard and salt to reveal the 'steel' and prime coat. You can go back over the green with acetone or mineral spirits to remove green or create wear places. Be careful that you don't remove too much paint.
Once weathering is complete reassemble the unit.
I used the round aluminum duct to create a panel for the front. I removed the curve from the duct by running it over the edge of a 2x4. Then I cut it to fit and cut holes in it for switches, the valve, and the gauge. You can use a hobby knife to enlarge the holes.
You can use black enamel and rub it on then off, to accentuate crevices and recesses. I was going to do this, but haven't yet. It adds a nice layer of grime and use to the unit. When that's complete, clear coat everything to protect the finish.
I added weather stripping where the frames meet the table. You want as tight of a seal as possible.
I also added a 1/2" conduit strap at the top of the base to secure the end of the plug when not in use. This prevents me from stepping on it or running over it.
Step 8: First Use
With this project finally done, the big question is, does it work.
It does!
It's a bit trial and error. First I evacuated the air tank with the pump. I turned the heaters on and let them get hot as I clamped the plastic in the frames. Once the heaters were hot I raised the frames.
I have a small leak in the vacuum lines. I plugged the pump in to a separate outlet on a separate circuit since I know I can't run the pump and heaters simultaneously on the same circuit.
Once the plastic started drooping, I switched off the heaters, lowered the frames and opened the valve. My plastic stretched too far underneath one item that was suspended off the table and broke the seal, so I know I can get a tighter pull. If the seal didn't break, I would have closed the ball valve on the tank and switched on the vacuum pump to remove any additional air. This step might be unnecessary. I need to do a few more pulls to perfect the technique.
On the second pull, the definition was really good. For concave areas like sunken in eyes on a mask, drill a hole in the eye to evacuate air. Gaps less than 1/4" aren't going to pop a hole in the plastic. Flat bases work best, and you can even suspend it off the table for good edge definition.
Epilog Contest 8
First Prize in the
Epilog Contest 8
    • Pie Contest
      Pie Contest
    • Paper Contest
      Paper Contest
    • Trash to Treasure
      Trash to Treasure
    30 Discussions
    mxfaiman
    2 years ago
    How did you end up connecting the wires for the heating elements together?
    As most toaster ovens the wires are spot wleded to the elements (or at least the ones I got). So I would assume that solder would not work due to the temperature going through it. Just curious how you ended up doing that.
    WardWorksmxfaiman
    Reply 2 years ago
    Good question. You are right, the wires to toaster oven elements are spot welded. I had to cut and grind the spot welds.
    The wires are tension fit to the ends of the heating elements. I was going to look at solder, but through my numerous tests, tension fit seemed to work. I used pliers to clamp the loop of copper wire tight around the heating element ends.
    OberstDackel
    2 years ago
    This is excellent. I believe the original prop makers for Star Wars used a vacuum former for the clone troopers armour.
    syates3OberstDackel
    Reply 2 years ago
    'Stormtrooper' armor, and vacuum formed armors for the stuns so they could easily make a large amount in a small amount of time though no two were identical due to deformations breaks repairs and such. 'Clone Troopers' were created in CGI and never ever made real until the 501st and Rebel legion along with talented crafters made them so.
    Butane Flamesyates3
    Reply 2 years ago
    I'm going to need to template moulds you used for the thermo former so i can make my armor please
    syates3Butane Flame
    Reply 2 years ago
    Can't do they aren't mine you can buy the kit from Kevin of imperial surplus. He sells the parts one of the top kit makers in the legion.
    bgunville
    2 years ago
    I have some experience in running a small business vacuum forming. I did this in a sub contract for one shop only and very limited jobs. One issue when pulling around some of the corners and getting to thin is the size and placement of the suction holes. Actually just something to play with developing the mold.
    It was fun but more work then I could handle at the time working to many hours in a large blow mold shop. Ended up just returning the former to the shop owner and sold him every thing else I had acquired working for him.
    Custom work can pay well if you have the time.
    RayF13
    2 years ago
    Ward, how are you keeping the plastic tight in the frame? I missed that part. That is the biggest problem I have with my 24"x24" vacuum former.
    WardWorksRayF13
    Reply 2 years ago
    The plastic is sandwiched between the 1" angle frames. Binder clips clamp the frame together:
    https://www.amazon.com/ACCO-Binder-Clips-Medium-72050/dp/B0035OQGA6
    LuisG223
    2 years ago
    Do you have stuff that you already have try in the former
    WardWorksLuisG223
    Reply 2 years ago
    Check the last step of the Instructable. I formed a dragon priest and skull mask.
    FlorinJ
    2 years ago
    How many watts do all heating elements taken together have? I couldn't figure this out by skimming through the text.
    More important: what's the temperature you need to have inside the oven? IMO a thermostat inside the oven would be very useful - without it, variations in environment temperature, wind or draft or variation of network voltage combined have an unpredictable effect on the temperature inside the oven. Your material can start to bubble or stay too stiff. (I managed to get lots of bubbles inside a 2mm (1/2") sheet of Plexiglas with a heat gun, and it was still too stiff - uniform heating at constant temperature is important.)
    An idea of how to compute what vacuum can or cannot break: the maximum load corresponds to atmospheric pressure, which is equivalent to about a column of water 10 meters high. A good quality 1" thick softwood board could carry that load with a reasonable safety margin. Plus, what vacuum you are able to create with a piston pump is nowhere near close to ideal - 30% or so of the outside air pressure on the inside is already a good performance for such a pump (and more than enough to mold heated plastics).
    stuffdoneFlorinJ
    Reply 2 years ago
    I have a new electronic temperature controller laying around. I think one of those would do the trick. You can buy them on Amazon for $17 giving you dial in temperature with digital read out. Be sure to get the 120 V verson as they are also avalable in other voltages.
    stuffdonestuffdone
    Reply 2 years ago
    Why not a small fan (metal blade protruding inside ) to circulate hot air? Mount motor outside the cement board with only steel shaft poking through and put a metal blade to stir the air. Slow speed, just enough to make for even temperature. Thinking small DC motor so you can easily control RPM
    WardWorksstuffdone
    Reply 2 years ago
    With evenly spaced heaters (assuming heat output is similar), I think heat is fairly uniform.
    During testing and while operating I looked for noticeable areas that weren't being heated and was satisfied with the result. Plastic droop was uniform.
    WardWorksFlorinJ
    Reply 2 years ago
    I would guess around 2200-2400 Watts. I re-wired until I wouldn't trip a 20 amp breaker. Assuming household voltage is around 120 volts and considering that typical toaster ovens uses about 1100 watts and I have 2 toaster ovens wired up that seems to check out.
    I tried to space the heating elements evenly, assuming operating temperatures are close. The elements are fully heated before I bring the plastic up and the droop of the plastic looked even. Results were satisfactory.
    stuffdone
    2 years ago
    Cool idea. I have wondered what to do with the 1500 watt heater elements saved from a defunct space heater. There are three, nicly shaped like very thin bricks!
    I already have a pump, originally from an O2 generator. Twin cylinder. Also have an air tank gathering dust.
    Since electrical and electronics are my thing I think what I would do is wire so the pump and heater would not run at same time to avoid tripping a breaker. Once you have saved a vacuum in the tank than your heat switch turns the pump off and the heat on.
    Limit switches on the arm wired so when you pull down to form, it automatically disconnects heaters and reconnects the pump.
    Another limit switch at bottom travel to operate a solenoid valve to allow vacuum to pull down plastic when it reaches the platen. (alternativly a button on the handle)
    I may make a slightly smaller version due to space and the fact that I mostly would make smaller items.
    WardWorksstuffdone
    Reply 2 years ago
    Automating those processes would make it much more convenient. I'm not I'm up to the task to figure it out on my own.
