Build a Star Wars Boba Fett Plywood Wall Plaque
12,164
126
14
Allow me to preface...
Being a long-time Superman fan, I was happy to find out that a great-nephew (4 years old) was also a fan.  With that, I decided to make him a a superman emblem to hang on his wall.  With that done, all other great neices and nephews then wanted their own plaque as well (in various forms).  So, making the list brought about a number 26 different plaques to make.  So far, I have made 10 and try to make a new one once a week.
This instructable will show how to make a Star Wars Boba Fett helmet wall plaque.
Since I am making a lot of these in various forms from Boba Fett to Happy face flowers, I kept some ground rules in mind.
Keep price at a minimum and spend no more than $10 per plaque using current materials and paint, then buying extras needed.
Keep it simple enough to complete in a weeks time (about 4-5 hours actual work time)
Use plywood as a base material where possible.
Supplies:
Step 1: Get Your Concept Ready
I ask each neice or nephew who their favorite hero, character, thing is and then research that.  Boba Fett was easy to find. I just searched google images and found all the material I needed for the concept.  That concept being a face on view of Boba Fett's helmet.
As this nephew was a bit older, I wanted to spend some more time on this and try adding the battle scars.  www.thedentedhelmet.com is a site dedicated to the building of Bobba Fett props and was indespensable in heping me find paint templates, close shots, etc.
OK... I got the concept, now time to draw it up!  I took a good front view of the helmet and added it to photoshop.   I then start to crop areas of color to determine how the plywood will be cut and stacked to make the view I want.
After that, it was easy to see how the layers would be painted and stacked.  I then finished the concept and plan drawings with the battle scars to see the complete view of the drawn project.
Step 2: Make Your Templates
After I have the color plans ready, I then remove the color and make a black border around each piece needed.  This make a good template and saves on ink.  I then make each template into a pdf for printing.  I like to do this as it help make sure all of the templates print at the correct size.
Step 3: Cut the Pieces
Using 3/8" or 1/2" plywood (with good finished surfaces) I then transfer the template to the plywoood to cut.  Depending on the pieces, I sometimes double up the plwood and tape together to get exact cuts.  After cutting, I noticed that the dome area was kinda puny feeling with only one plywood layer so added another.  I made 2 so that I could practice the battle scaring.  I added little extra touches where I could such as the dent.
Step 4: Paint!
Once the peices are all cut out to my satisfaction, it's time to paint.  After getting the base paints in place and dried, I printed out some more templates for the battle scars.  The green paint I had was a little darker than I wanted so I did an overspray with white with good result.
Then, I printed out COLOR versions of the battle scars that I found at the dented helmet.  I printed a couple of each so that I could layer some of the paint.  I then cut out large areas of the stencils IE: silver and grey first to paint the grey and then cut another for the inside color for a layered effect.
I then placed some photo paper in the printer and printed out some of the details of the helmet IE: the decals found on the ear flaps, etc. these were then cut out and spray-glued into place.
Step 5: Done!
You are only limited to your imagination on these.  On the Batman logo below I added some imitaion carbon fiber for the background and added some glow in the dark paint to the edges of the bat.  The peace signs used the photo paper and designs found online.
If you would like a full psd or pdf set of any of the plaques that you've seen here, just message!
Enjoy!
5-7- 11 - Here's the boba fett package in a zip file - http://yourfavoriteweb.com/superman/bobafett.zip The file is about 22 megs and contains the templates for cutting and color plates for battle damage. Only the decal page needs printed at high quality on photo paper if you have it.
Here is batman - a 6 meg PDF - http://yourfavoriteweb.com/superman/batman.pdf
  • Fandom Contest
    Fandom Contest
  • Woodworking Contest
    Woodworking Contest
14 Discussions
rbird77Jon316
I used a dremel trio on that one but normally use a scroll saw. But, if you drill some pilot holes to start, you could use a jigsaw. Just be careful where you put the pilot holes if you are using plywood. The out lamanent can split, especially on the bottom. SO, don't drill a pilot too close to the edge that you will be cutting. Hope this helps!
Ron
rbird77TerminalDragon
These are a blast to make! Another rule I made was that all the kids 10 years and younger get theirs first. The big "kids" (some approaching 30) have to wait. :)
TerminalDragonrbird77
That's a good rule! My friends dad did something like this when he was around five, he really loved thunderbirds so he made all the thunderbirds items out of plywood, painted them and put them on his wall and painted a background!
rbird77
I posted a link to the boba fett pdf package on the last page along with a pdf for the batman build.
rbird77ChrysN
Thanks! I feel I get as much or more enjoyment in the build than the recipient gets from receiving it.
rbird77SHIFT!
Thanks! I get more and more Star Wars requests. I've made 2 and have at least 2 more to make!
I'm 25, and can say without a doubt in my mind I'd want several of these (the nerdly ones) hanging in my house. Amazing work, very inspiring.
rbird77FearthePenguin
My request list grows and gets older too. Many in the future might feature leds, and more! The more I do, the more themes make themselves aware. The wife keeps hearing - ""I could make a plaque out of that." Glad you like em!
