Building a Forced Air Composting System
54,744
125
10
These build instructions assume you already have a static compost pile that you’re trying to renovate or already have an understanding of composting or understand how to build a static compost pile. There are a ton of very good resources on why aerating your compost is beneficial and they’re complete with graphs and studies from Universities. What I found was that none of them had actual plans on how to build one.
In very basic terms the microbes that decompose the waste feed on oxygen, and they need a lot of it. Tumbling composters are good but studies have shown that the oxygen levels decrease within minutes of the action stopping. Spinning the tumbler once or twice a day does help to make compost decompose faster, but most people aren’t consistent in the frequency require to spin the bin for the weeks or even months required to finish compost. If you search for “compost aerators” you’ll find tools, which look like dirt corkscrews, but honestly if you’re not going to spin a tub twice a day, every day for a month and a half, using a dirt corkscrew for the same time frame is not realistic.
Also, Tumblers are also too small for large home composting, or small farms or businesses. A single horse can produce 50 pounds of waste a day. A tumbler composter may be able to only hold a single day or two of manure. So if it takes says 2 months for a tumbler to fully compost when turned every day. That would be 40-60 tumblers per horse, turned every day. Don't get me wrong, I love tumblers, I have one for kitchen waste, but for horse/chicken manure, grass clippings, and brush clean up it all goes in to the aerated pile.
Forced air systems allow people to compost who would otherwise have to throw the waste away, or simply make their existing systems more efficient and maximize the available space as a well set up forced air composting system can reduce the time to finished compost to 3 – 5 weeks. Yes, you read that correctly, less than or about a month.
If forced air systems are so great why doesn’t everybody have one ? Simply put, they’re unneeded for the average household, and for those who could benefit from an aerated composting system, those systems usually are too expensive (Custom 3 bin aerated system holding 400 cubic feet starting at $5,000) and/or are too large or overboard for what is needed; i.e. a small family hobby farm doesn’t need the smallest industrial composting system, when the smallest system is $100,000 and 5,000 cubic feet of compostable waste. This is a scalable middle ground between a backyard worm bin and a $4,000 custom set up or $100,000 industrial system.
Step 1: Supplies
• PVC piping
• Appropriately size PVC pipe fittings
• PVC pipe primer and cement.
• Electric Leaf blower
• Outdoor extension cord
• Plug-in light timer
• Flexible Rubber Coupling with Hose Clamps - 3" (rough diameter of the blower) x 2" (PVC pipe size)
Tools
• Saw
• Drill & drill bits
• Hand trowel or shovel
Optional:
• Compost Thermometer
• Compost
Depending on your set up:
• White wire shelf
• Landscaping fabric
Most of the tools are things an average home would have on hand and the rest of the supplies should cost less than $40 to buy; $70 if you need to buy a cheap, basic $30 leaf blower.
Step 2: Design & Setup
Again these instructions assume you already understand composting and building a compost building. For this project I recommend that your compost bin to be no smaller than 27 cubic feet, or roughly 3 feet wide X 3 feet deep X 3 feet tall and that you have two of these bins that are undercover or can be covered securely with a tarp to control moisture levels.
The set up I am working with up is a 7 foot wide X 15 feet deep X 5 foot tall with a 12 foot roof roughly the same width and depth as the average parking spot . By dividing this space in half, this will allow for a two bin system , each bin roughly 3.5 feet wide X 4 feet tall X 12 feet deep, with a rough capacity of 144 cubic feet per bin, which is generally just enough space for a months’ worth of horse manure for 2 large horses or 3 small-medium horses.
Once you have determined the permanent location and dimensions of the bin, map out the best and most efficient location for pipes to be laid.  When filled all of the compost should be within 18 inches of a pipe.
For me this was simple, just single, straight pipe the length of the bin. As the bin was 3 1/2 feet wide, the single pipe  down the middle, would be perfect.
Heated air will naturally rise so incorporate vertical chimney pipes help to aerate the upper layers of the pile and help to distribute heat more evenly through the pile. The chimney pipes will also help to direct moisture down deep to the center of the pile instead of lingering in the upper, outer layers.
When designing the system, try to keep the lengths of pipe the minimum distance you can. If your blower is 35 feet from the compost pile the force of the air will not have adequate pressure to push the air though the compost properly.
Design your system so that the pipes are cyclical or capped to help keep the air pressure up and the air directed properly.
Determine the size of PVC pipe you want to use. For small bins, less than 50 cubic feet in volume I recommend using 1 1/2  inch PVC pipe but anything larger I recommend 2” PVC pipe. I am using 2” PVC pipe in my setup.
For this build I used my leaf blower that I bought for $30 at Home Depot. It’s a no name brand that you can probably find for even cheaper on eBay. This blower is great for 18’ – 24’ feet of pipe. If you use more than 24’ feet of PVC pipe you’re going to need a blower with more power. I would suggest looking in to using a hot tub air blower.
Step 3: Setting Up the Blower
Prepare the site by either digging a trench for the pipe from the inside of the compost to the outside of the bin, or if you have a cement floor, create a hole in the wall big enough for your PVC pipe to fit through.
Remove the nozzle of the leaf blower leaving only the base. Place the base of the leaf blower where you would ideally like the unit to live.
IMPORTANT : Because we are dealing with electricity outside, specifically very close to an area where we will be hosing down with water regularly you will want to make sure the blower is dry and safe from rain and pooling puddles and out from underfoot where people or animals won’t disturb it. Also you want to ensure that the air intake fan of the blower has free and unblock access to air.
For most electric leaf blowers the air intake is located on the bottom. The area my blower unit is located was also covered so I expanded the trench I dug for the pipe to form a small pit. You can also create a water proof well ventilated housing out of a large rubber storage container and a bit of ingenuity.
For my bin I’m using a small, leftover, common, white wire shelf and laid it over the pit, and placed the blower base on top of it. The pit allows for both constant, uninterrupted airflow but also directs any unaccounted for moisture away from the unit. The pit is 18 inches wide and long and 6 inches deep with 2 inches of pea gravel.
Once you have determined the placement of the blower, measure the distance from the blowers exhaust valve (the hole where the air comes out) to the midpoint of your first chimney or bend. Don’t forget to subtract the amount of overlay your pipe has with the connector or your pipe and connector will be off.
My examples in the picture below show the Flexible Rubber Coupling with Hose Clamps attached which is actually done in a later step. I included it on and with the pipe attached to show how I've trenched under the walls to connect the exterior blower.
Step 4: Laying Pipe
There are two ways you can determine the pipe measurements
1) Place all your connectors where you would like them to be and measure the distance between each of the connectors remembering to account for the overlap where the pipe and the connectors meet.
or 2) Lay the length of pipe down then place the connectors where you want them and mark the cuts on the pipe.
Which ever is most conducive to your bin and setup.
In my case because my bin is narrow and long, I laid the 12 foot pipe down and set the fittings down where I wanted them and marked those cuts on the pipe.
Cut your PVC pipe in to measured lengths, while keeping in mind the following best practices :
1) When filled all of the compost should be within 18 inches of a pipe.
2) Air and heat will naturally rise so incorporate vertical chimney pipes help to aerate the upper layers of the pile and help to distribute heat more evenly through the pile. The chimney pipes will also help to direct moisture down deep to the center of the pile instead of lingering in the upper, outer layers.
3) When designing the system, try to keep the lengths of pipe the minimum distance you can. If your blower is 35 feet from the compost pile the force of the air will not have adequate pressure to push the air though the compost properly.
4) Design your system so that the pipes are cyclical or capped to help keep the air pressure up and the air directed properly.
Dry fit your piping to verify everything is where you want it and so you can correct any mistakes before pipes and fittings are permanently bonded together.
Step 5: Drilling
When to drill air holes in to your PVC pipe is a personal preference.
Some pieces I drilled holes in to the pipe before I cemented them together because the pipes location would be too awkward to hold on to an maneuver after they' are permanently cemented togeather and some pieces I wanted the ventilation holes in a very specific order and location so I drilled them after the set up was completely cemented. It is up to you and how you’re comfortable building.
Drill holes in your pipe using either a 1/4 inch drill bit, or just the sharp tip of a 1 inch drill bit.
You will want to avoid drilling holes straight up but rather off to each side. Also for the pipes touching the ground, avoid frequently drilling holes on the bottom, but do drill one or two per pipe for water and condensation to drain out of.
I suggest drilling the holes in your pipes roughly 3 to 4 inches apart but the exact placement is up to you and the placement in your system.
- For one of the chimneys my holes are 4 inch apart on 4 sides of the pipe and each set of parallel holes are offset by two inches from the other.
- For another chimney I drilled a double spiral on opposite side of the pipe every 3 inches.
- For the ground air tubes, from the small pipe to the first chimney is about a foot long and I drilled one row of holes, two inches apart.
- The pipes between the other chimneys have two parallel rows that are off set from the top by 3/4 of an inch for a total of an inch and a half between the two rows, and the space between the holes in each of the rows are 3 inches apart.
Step 6: Cementing & Dry Fitting
Before you start using the purple PVC primer and cement
WARNING:
Do not permanently connect every pipe and every fitting. Eventually you will want to move something or replace something or change out something and if you seal every connection the only way out is to saw. There are locations where a night tight dry fit will work perfectly fine and will still give you the flexibility you might not currently foresee.
For example: the pipe after the first elbow fitting is dry fitted so if I need to remove it in order to shovel finished compost out it’s an easy tug and it slips out; same with the chimneys. The first (furthest back) chimney is bonded to the long pipe as its way, far back there and will always have compost around it, but the second and third chimneys are dry set so that I can easily walk back a manure bucket all the way to the very back when it’s empty and step over them. However when the bin starts filling up closer to the front I can switch out the short chimneys with no holes, that’s enabling for higher air pressure and switch it out for the tall chimney with lots of holes that will aerate the compost when it is fuller.
For the pieces you have decided to permanently connect:
1) Purple primer goes around the outside of the pipe and the inside of the fitting.
2) Push in while giving it a quarter twist. It sets super-fast so you have about 30 seconds to get the pipe and any drilled holes where you want them.
Step 7: Flexible Rubber Coupling With Hose Clamps
The flexible rubber coupling with hose clamps is the trick that makes this all work.
I’m using a 3” to 2” coupling as 3” is the rough diameter of the blower valve and 2” is the size of my PVC pipe. The flexible rubber is lovely since where the leaf blower nozzle on my leaf blower wasn’t a circle but instead a long oval, almost a rounded rectangle.
The Flexible Rubber Coupling fits around where the blower nozzle was previously was and the hose clamps allow for the oddly shaped nozzle to have a custom, leak free fit. The 2” end fits perfectly, as it should, to the standard PVC pipe. You would never know that this wasn’t the original intent for this part.
The leaf blower connects to the 2” PVC pipe via the Flexible Rubber Coupling with Hose Clamps which you tighten by tightening the screws. The connect PVC pipe fits under or through the compost bin wall, and now connect the remaining pipe system.
Finish by capping off all open pipes.
Step 8: Testing
Time to test the system. Plug the blower in and turn it on and then go in to your bin and verify there is air coming out of all of the holes you want and nowhere else.
There will most likely be some but very little air leaks from dry fit connections but make sure they are as tight as can be. The air should be actively blowing out of your system.
If the air isn’t blowing with some strong pressure you either have a disconnected pipe, too many holes in your pipe, an uncapped chimney or you have too many feet of pipe for the power of blower.
Step 9: Finishing Up
Cover the pipes on the ground with landscaping fabric or screen to keep the bulk of the dirt and bugs out.
Cover the pipes with some compost and retest the system.
Again verify air is flowing as expected, if it is fill the bin up with any remaining compost and shove the compost thermometer deep in the heart of the pile.
Step 10: Setting Up the Automatic Timer
Go back to where the blower is plugged in and attach an automatic timer. Keep your neighbors happy by NOT scheduling your blower to go off in the middle of the night, after it is still a leaf blower.
I recommend starting out with twice a day for 5 to 15 minutes, it depends on the timer you bought and the settings you have available. Originally I had a fully adjustable timer and had it set, to run 10 minutes 4 times a day but I found it dried out quickly and it never maintained a core temp of 140 degrees.
Through trial and error of compost troubleshooting I’ve gotten adjusted to work for twice a day for 15 minutes and it now it keeps a good moisture level, no smells or odors and has a consistent all over temperature of 140 degrees which means good microbe activity.
There are compost troubleshooting steps on the resources page.
So long as the blower runs according to schedule, and you keeps the pile moisture level correctly and the pile has regular temperature of 140 degrees. in a month your pile will be compost!
Good luck and enjoy the savings!
Step 11: Resources
Good resources:
The Science of Composting, Natural Environmental Systems, LLC
http://www.naturalenviro.com/Article.php?ArticleSKU=The-Science-of-Composting
Troubleshooting Compost Problems:
http://www.homecompostingmadeeasy.com/troubleshootingguide.html
Composting Horse Manure
http://your.kingcounty.gov/dnrp/library/2000/kcr737.pdf
List of Browns & Greens (Notice horse manure is a green and straw and bedding are browns)
http://www.joyblooms.com/gardening/brown-green.htm
Magic Soil: Forced Air Composting R&D (Studies and data why it’s beneficial)
http://www.magicsoil.com/Research/index.htm
Cornell: Composting Physics:
http://compost.css.cornell.edu/physics.html
Aerated static pile composting
http://en.wikipedia.org/wiki/Aerated_static_pile_composting
    • Tape Contest
      Tape Contest
    • Trash to Treasure
      Trash to Treasure
    • Jewelry Challenge
      Jewelry Challenge
    10 Discussions
    KizmetKid
    Question 3 months ago
    How is your project going now after 7 years of operation? I hope that you will be able to answer my questions even though you posted your fantastic project a long time ago.
    I want to recondition my pastures with composted horse manure and am starting a big project covering a lot of land by improving the soil and changing the grasses. This means finding ways to speed the process (such as your aeration system). I am in a wet and windy part of the UK so will need to protect my compost from too much moisture. I want to minimise effort as much as possible since there's no mechanisation here or extra man-power for turning or moving compost heaps although we do already invest a lot of effort in collecting the manure daily. So I am thinking of creating moveable compost heaps in bins. I have just bought a "hotbin" for composting household waste which is like an insulated wheelie-bin. It is an interesting idea but not big enough for my pasture project. My friend makes Crocodile boxes of varying sizes with "crocodile clips" so that the boxes can be dismantled. Usually the boxes are complete cubes (i.e. 6 sides) but it is easy to take them apart either just to remove one side or to flat-pack them. I am thinking of asking him to make an insulated cube of 1.5m length (minimum) with only 5 sides, so that I can stand the bottom (open side) on a pallet with mesh (to enable air-flow up from the base). I would put the pallet on an area of pasture to be reconditioned and construct the box on top of the pallet, by first creating three sides, inserting aeration pipes, then shovelling in the manure and carbon materials and finally closing up the other two sides for the duration of composting (it may need a vent on the top side just like the "hotbin" and / or some holes into which I could easily insert compost thermometers), My reasons for this moveable composting system is that I can make batches of compost in different locations around the pasture, then spread the compost in that area where it has been created, sow it with new grass seed while moving to another area to recondition. However, I have some questions for you ...
    - have you found with your system that there is no need to turn your compost? (using the "hotbin" there is no need to turn it since the bin is insulated and all of the contents reach and remain at the required temperature for long enough to compost everything effectively)
    - how long does it take to complete the composting process? I thought it only needed 3 days at the 55-65 degrees Celsius temperature but I think you say it will be longer ... and my "hotbin" says 18 days ... so what is your experience?
    - obviously with my roving composting approach I will have trouble getting electricity to the heaps and therefore pumping air through the pipes ... do you think it would be satisfactory to assume that wind / air may naturally penetrated and that this will be sufficient or should I find some kind of rechargeable device?
    Very many thanks for your detailed and ingenious ideas and I look forward to hearing your suggestions to make my scheme workable.
    Best wishes, Katherine
    Odinnmanure
    4 months ago
    Do you have a timer recommendation for a number of intervals and only 10 or 15 minutes? I found ones at home depot with 30 minute intervals but that's probably too long for drier seasons (I am in Portland, Oregon).
    Thanks for this... it is so very thorough and I am already getting temps around 140 with manual turning on and off. I am going to build a manifold to add a second one adjacent to the first.
    kickaha0884
    3 years ago
    Hi, we have built 3 bays in anticipation of fitting the pipe work. It is difficult getting 2" waste pipes, the standard being 40mm (1 3/4"). could you advise me on the layout of 40mm pipes in each bay? we were thinking of 6 x 1.3m (4 foot) high 40mm pipes per bay, driven by a leaf blower. Given the length of the pipework, would you suggest anything more powerful or is this enough? a lot of interest being shown on Facebook by our construction! kind regards, Clive
    i've got 100' length or 3/4 pex left from a remodel.... thinking of how i could use that coil maybe just suspend it. any thoughts? anyone?
    jollyroger78
    5 years ago on Introduction
    vespaskank, you gave me a good idea regarding ordinary electric blower instead of electric motor! Thank you. I'm a guy from cold =)) and distant Russia :P
    I surfed internet and found that :
    1) the microbes could require a volume of air > 20 times the volume of compost, every hour (look at the pic with pyramid and notes for it at this link: http://www.magicsoil.com/Research/)
    2) the oxygen level in the pile drops off very quickly - often to less than 1% within 30 to 45 minutes (source: http://www.o2compost.com/content/Secret.htm) and the previous source says that oxygen drops down even faster - in 15 -20 minutes.
    I have a plastic container of 1 cubic meter, so I suppose that every hour I should blow in 20 cubic meters in the container. it's easy to calculate that if I have , for example, a blower of capacity 228 m3 in hour tha means I should use it 5.2 minutes in hour. + it's essential to divide this 5.2 minutes to have 4 breaks of about 15 minutes or a bit less.
    3) It seems that volume of blown in air depends on the moisture content in the compost components....and it often happens that 20X (to a compost's volume) volume of blown air inside can dry the compost a lot. and what if I have a chance to water a compost once a week ? Should I reduce blown air? I think so. But in this case what's the point to blow the air inside if we have 50% of the whole composting period CO2 existence (= anaerobic bacterias) inside. Productivity in this way fall down to 1/2.
    May be it's better to make a "skeleton" of drilled and connected vertical and horizontal tubes inside the composter and regulate the draft (it's created by heat that's done by bacterias, it's a bit more advanced than guys do in Aerobin 400 ) (you can look at Aerobin here: http://eartheasy.com/yard-garden/composting/aerobin-400-insulated-composter-15-cubic-foot-133-gallon-compost-bin )
    I still have a question - Is it possible to regulate the speed of air flow/ time of its work properly not to dry the compost and have FAST composting speed. Or it's better to make a passive ventilation with tubes (I mean for summer season use)? Do you have an idea/ experience of your own? Thank you !
    vespaskankrimar2000
    Thank you for you feedback!
    Step 10 "Setting up the automatic timer" briefly talks about timing:
    More specifically Ismith254, I've found the you may have to change the frequency depending on the weather, for example I live in Seattle where it rains a lot even in the summer and even though my piles are covered there is some leaching and leaking, so I find that if I add another internal of even 5 minutes it will help to aerate and dry the pile out enough to keep the balance I need.
    Again it really is troubleshooting and trial and error based on your setup and the number of holes in your pipe. For some people and climates every other day for 5 minutes will be enough, and for others 2-3 times a day for 5-15 minutes may be better to keep the right balance.
    Just play with the time and moisture levels until you find out what keeps your compost thermometer at 140 degrees continuously. Hope this helps!
    lsmith254
    I scanned through everything, and could not see anything about how long you leave the blower on? Is it only for a few minutes a day? Thanks!
    vespaskanklsmith254
