Bullet Case Key Chain, Carry Container, Dog Tag or Charm
About: I prefer to make my own things whenever possible.
When I exercise outdoors, I like to carry emergency contact information in case something happens. Most people carry "dog tags". I wanted to make something different and since I like fire arms, I came up with this idea.
Step 1: Build It
Material:
bullet casing
small screw
paper clip
Make it:
1-Find a screw that will fit the casing that will serve as a cap.
2-To create a hole for the the loop, push in the back of casing where the firing pin
3-Use small paper clip to create the loop and feed through opening created on the back of casing
4-Once the loop is inside the casing, use the screw driver on the other end of the casing to widen the open end of the small loop you created
5-Now you have a nice container for your key chain, your bike or you can carry it around your neck.
I wrote emergency information on a piece of paper, rolled it up and placed it inside the casing and hanged it from the seat of my mountain bike with a small chain.
    • Pocket Sized Contest
    • Remix Contest
      Remix Contest
    • Tape Contest
      Tape Contest
    FoxysMyGirl
    2 years ago
    Great idea. I hope someone would know to look inside if something ever happened. I think I will try to make one.
