CC Chair - How to Bend Plywood
86,728
877
45
I had a few weeks to build a chair and decided to experiment with bending plywood. Instead of laminating veneers or using a product like bendy ply, I tried laminating thin furniture grade plywood to make thicker plywood. My results were quite successful and the chair was very sturdy and relatively cheap to make. The molds were simple to build using hand tools; they can also be CNC machined for faster, more precise results. The seat pan and seat back are made from the same mold, the top and back legs are made from the same mold, and the bottom leg has its own mold. So, three molds make all of the parts for this chair.
Check out the presentation version of the project on Behance.
Step 1: Tools and Materials
Materials:
  1. One gallon woodglue - I prefer to use Titebond III for its longer open time
  2. 1/8 inch 3 ply baltic birch plywood sheets
  3. Wood finish - I used Minwax polyacrylic
  4. Hardware
  5. 3/4 inch MDF sheets
Tools:
  1. Bandsaw with a fence
  2. Tablesaw
  3. Jigsaw
  4. Sandpaper
  5. Pencil
  6. Lots of clamps!
Step 2: Design and Dimension
The design:
To keep the design simple, I designed the chair to be built from three sets of parts. I sketched up a few different concepts and really liked the merging triangle. The side view sketch was very helpful for determining the seat height, leg angles, and seat back angle. This was going to be more of lounge chair so the angles were relatively steep so the person sitting would slide down into the chair. I used Solidworks to refine my chair design and layout the mold shapes.
Before I began building the molds, I tested various bending techniques and wood types. I settled on using 1/8 inch 3 ply baltic birch plywood. It was relatively cheap and bent quite nicely.
Minimum bend radius:
When you bend a material, stress starts to build up in the part. The inside curve of the bend is under compression, while the outside curve is under tension. If the bend is too tight, the material will fail from the tensile stress. Plywood is a unique material since it is a sandwich of thin layers of wood. Wood also has a grain direction. Each layer alternates the direction of the grain direction that that the plywood sheet is nice and rigid. This is a slight problem when trying to bend plywood.
I chose to use the thinnest plywood I could find. With the baltic birch I was able to achieve roughly a 4 inch bend diameter. So, my minimum bend radius would be about 2 inches before the material would start to break. Since wood is a fibrous material, bending slowly helps stretch the fibers gradually which helps reduce breakage. See the sketchbook photo for more explanation.
Step 3: Build the Molds
Use the 3/4 inch MDF sheet to make the molds. I traced the profile of the bend onto the MDF and then cut out the pieces using a jigsaw. Since the molds are 2D extrusions you can replicate the first piece you cut using a flush trim router bit if you have one. Otherwise, keep using the jigsaw to cut out identical pieces until the MDF mold stacks together at the right depth. The leg molds are 4 inches deep and the seat pan/back mold is 17.35 inches deep. You can make them deeper if you want because the plywood parts will be trimmed later.
Step 4: Mold the Legs
Use a table saw or bandsaw to cut the 1/8 inch baltic birch into 4 inch strips. Each leg needs 4 strips of baltic birch plywood laminated together. Place the plywood strips into the mold one at a time and liberally cover the top side with wood glue before placing another piece on top. Work quickly as the glue will start to set after about 10-15 minutes.
Once all of the plywood pieces are glued together in the mold, clamp the entire mold together tightly. More clamps are always better. Let the parts set and rest for at least 8 hours before de-molding them. Set them aside for 24 hours for a full cure.
Step 5: Mold the Seat Pan and Back
Molding the front was the most difficult task because of the size of the part. I ran into problems of the glue setting before I had clamped everything down. I would recommend using the slowest setting glue you can find for this part.
Step 6: Trimming the Parts and Test Fit
Once all of the parts have been molded, trim the uneven edges off using a bandsaw with a fence. The fence will help you cut nice and straight. I traced the front leg profiles onto the large seat pan part and cut out a section with a jigsaw.
Once all of the parts have been trimmed and cut out, it is time to test fit everything together. I used small clamps to hold the chair together to I could look at it from a distance to make some last minute design changes.
Step 7: Add Hardware and Finishes
I used socket head hex screws to secure the parts together. Each screw and nut was recessed and covered with a wood plug that I sanded down flush to the baltic birch. I wanted to hide the hardware as much as possible.
The Minwax polyacrylic finish went on nicely and gave the chair a nice gloss.
Step 8: Photography
Building the chair was great project. Bending plywood to make simple furniture is not as intimidating once you get into it. The laminated baltic birch plywood turned out to be incredibly strong.
Plywood Contest
First Prize in the
Plywood Contest
    • Gardening Contest
      Gardening Contest
    • Arduino Contest 2019
    • Trash to Treasure
      Trash to Treasure
    45 Discussions
    slebowitzdes
    Question 11 months ago on Introduction
    Hoe many sheets of 1/8" plywood did you use for the CC chair?
    hausi
    3 years ago
    Just beautiful. If you don't mind me asking, how much did cost to make (in materials)?
    kniegmannhausi
    Reply 3 years ago
    Gallon of titebond iii ~ $30
    Baltic birch plywood (I bought some extra to experiment) ~ $100
    MDF for molds (had some scrap) ~ $30
    Hardware ~ $10
    Polyacrylic finish ~ $20
    Rough estimate is 190 dollars to build the chair and experiment a bit.
    markslavkniegmann
    Reply 1 year ago
    Where did you buy Baltic birch plywood
    kniegmannmarkslav
    Reply 1 year ago
    I found the plywood at a lumber supply store just outside of Atlanta.
    WayneS146
    Question 1 year ago on Introduction
    Is the end result stronger than if you had used bendy ply? Or was there some other reason you chose this material?
    1 answer
    kniegmannWayneS146
    Answer 1 year ago
    I'm not sure if it is stronger than using bendy ply. It was an incredibly strong chair. I chose the baltic birch because I liked the subtle grain, it was cheap, and I could pick it up locally.
    Brown6041
    3 years ago
    Great looking chair. How many sheets of ply did you use? and size?
    BG_instructs
    3 years ago
    Hi Kniegman,
    yes, glue everywhere, the mid section spacers i did cut in pieces to keep the weight low.
    This was an experiment based on a project for a Greenhouse, which was much larger, i copied and downscaled the structure. You can make large bended lighweight beams this way.
    It also allows you to use thicker material, so instead of 1/8 strips, you can use 1/4 thick material, as the inner spacers do not need ot be bended and hence less mechanical stress on the bended structure.
    warriorethos2
    3 years ago
    kniegmann, nice work on the chair, it looks store bought. Great results in your bends. The finish that you used lets the natural grains of the plywood show. Your photos and video are clear and easy to follow as well as your instructions. Good luck in the contest.
    BG_instructs
    3 years ago
    Great instructable, congrats.
    Have been experimenting with bending , gluing clamping last summer, made a small greenhouse, i used pine, 1 x 1/4 strips, about 4ft long each.
    The actual radius was very low, but to my surprise it really works.
    I was able to make a strong frame, gothic window shape really simple,fast and cheap.
    Just stapled clear plastic foil over it and done.
    I made that as i was trying to find out a method to get a bended frame for a teardrop trailer, and this will do the job perfectly.
    kniegmannBG_instructs
    Reply 3 years ago
    Very nice! I like your sacrificial table jig setup, looks like you have worked on a lot of projects. Did you glue on the spacers to get it to hold the bend?
    mormor
    3 years ago
    Nice project!
    Did you change the orientation of the layers when you laminated it together and how many layers did you end up with? What's the final thickness of say the seat? I really like the idea but have never tried it myself...
    kniegmannmormor
    Reply 3 years ago
    I used 1/8 inch baltic birch plywood, so the orientation of the layers already alternated. I used 4 layers of BB plywood so the final thickness was about half an inch.
    andrea biffi
    3 years ago
    that's a really cool design!
    sketchglass
    3 years ago
    Amazing documentation! Love it.
    bonielot
    3 years ago
    Nice job!
