CNC Robot Plotter
21,431
230
60
About: 55+ years in electronics, computers, and teaching ... now retired.
This instructable describes a CNC controlled robot plotter. The robot comprises two stepping motors with a pen-lift mounted midway between the wheels. Rotating the wheels in opposite directions causes the robot to pivot about the pen-tip. Rotating the wheels in the same direction causes the pen to draw a straight line. It has the following range of movements ... forward, reverse, rotate-left, and rotate-right.
In operation the robot rotates towards the next co-ordinate, calculates the number of steps, then moves. To speed things up, the robot is programmed to take the shortest turning angle before moving which means that it often draws while travelling in reverse.
Communication with the robot is via a bluetooth link. The robot accepts both keyboard commands and the g-code output from Inkscape.
If you are "into" watercolour painting then this device is able to transfer your sketch onto paper. Changing the SCALE changes the image size which means that you are not restricted to fixed paper dimensions.
Keep in mind that this robot is not a precision instrument. Having said that the results aren't too bad.
Step 1: Mounting Bracket
The mounting bracket was made from a 60mm strip of 18 gauge aluminium sheet. Aluminium was chosen for the bracket as it is light-weight and easy to work. A 3 mm drill was used for the small holes. Each of the larger holes started life as a 9 mm hole that was enlarged with the help of a "rat-tail" file.
The end-plates for the motors in the above photos are 56 mm x 60 mm spaced 110 mm apart when folded. This gave a Centre-to-centre wheel spacing of 141 mm. The Wheel-diameter for this robot is 65 mm. Record these dimensions as their Ratio (CWR) determines how many steps are needed to rotate the robot through 360 degrees.
If you look closely at the photos you will see a hack-saw cut on each of the wheel "skirts". The "sliver" of metal below each of these saw-cuts has been bent down ever so slightly such that:
  • the platform (bracket top) is level,
  • and the robot barely rocks.
It is important that the pen-lift mechanism is midway between, and in-line with, the wheels. Other than that the robot dimensions are not critical.
The pen-lift comprises a plastic medicine bottle that mounts through the aluminium bracket as shown. Holes are drilled through the lid and bottom for the pencil. The pen-lift disc comprises the end off an empty plastic hook-up-wire spool glued to the brass centre of a radio knob which has been drilled to fit the pencil. A small lead fishing sinker, suitably drilled, has been placed over the pencil to ensure contact with the paper at all times.
The robot is powered from six AA batteries mounted close to the wheels to minimize the load on the third support.
[Tip: Sheet aluminium can be cut without the need for a guillotine or tin-snips (which have a habit of deforming the metal). Heavily "score" both sides of the sheet along the cut-line using a steel ruler and a heavy-duty break-off-blade knife. Now place the score-line over the edge of a table and bend the sheet slightly downwards. Flip the sheet over and repeat. After a few bends the sheet will fracture along the entire length of the score-line leaving a straight edge.]
Step 2: Pen-lift and Shield
I experimented with the original cable-tie and opted instead for a plastic disc glued to the brass centre of a "radio-knob". The brass centre was drilled to fit the pen. The grub-screw allows precise positioning of the pen. The plastic disc was cut from the end of a spool of hook-up wire.
The pen-lift mechanism comprises a small servo that came with my original Arduino kit but any small servo that responds to 1mS and 2mS pulses spaced 20mS apart should work. The robot uses 1mS pulses for pen-up and 2mS pulses for pen-down.
The servo is attached to the medicine bottle with small cable ties. The servo horn lifts the plastic disc, and hence the pen, when a pen-up command is received. When a pen-down command is received the servo horn is well clear of the disc. The weight of the disc and brass fitting ensures that the pen remains in contact with the paper. A lead weight can be slipped over the pencil if you want "heavy" lines.
My entire circuit was constructed on an Arduino prototype shield. Unplug the shield whenever you wish to upload a sketch to your Arduino. Once your sketch has been uploaded remove the USB programming cable then replace the shield.
Battery power is fed to the Arduino via the "Vin" pin when the shield is attached. This allows rapid changes to be made to your software without running into battery and bluetooth conflicts.
Step 3: Circuit
All components are mounted on an arduino proto-shield.
The BJY48 steppers are connected to arduino pins A0..A3 and D8..D11
The pen-lift servo motor is connected to pin D3 which has been programmed to output 1mS (millisecond) and 2mS pulses at 20mS intervals.
The servo and stepping motors are powered from their own 5 volt 1 amp power supply.
The HC-06 bluetooth module is powered from the arduino.
The arduino is powered via the Vin pin.
With the exception of the HC-06 bluetooth module, which has a voltage divider comprising 1K2 and 2K2 ohm resistors to drop the bluetooth RX input voltage to 3.3 volts, all resistors are 560 ohms. The purpose of the 560 ohm resistors is to offer short-circuit protection to the arduino. They also make it easier to wire the shield.
Step 4: Software Design Notes
The .ino code for this project was developed using "codebender" at https://codebender.cc/. "Codebender" is a cloud based IDE (integrated development environment) which is free to use, has excellent debugging, and auto-detects your arduino.
The SCALE and CWR constants used in the code are determined by:
  • the robot dimensions,
  • the motor specification,
  • and your choice of "stepping mode".
Motor Specifications
The "28BYJ-48-5V Stepper Motors" used in this project have a "stride angle" of 5.625 degrees / 64 and a "speed variation ratio" of 64/1. This translates to 4096 possible steps for one turn of the output shaft but assumes that you are using a technique called "half-stepping".
How Stepper Motors Work
The "28BYJ-48-5V Stepper Motors" have four coils each with a shaped iron core that contains eight poles. Each of the four pole-pieces are displaced such that there are 32 poles spaced 360/32 = 11.25 degrees apart.
If we energize (step) one coil at a time (wave-stepping), or two coils at a time (full-stepping), the rotor will make one complete revolution in 32 steps. Since the internal gearing is 64/1, one turn of the output shaft requires 2048 steps.
Half-Stepping
This robot uses half-stepping.
Half-stepping is a technique whereby half-steps are created by alternately energizing a single coil, then two adjacent coils, thus doubling the number of steps from 32 to 64 for one turn of the rotor. This is the equivalent of 64 poles spaced 360/64 = 5.625 degrees apart (stride angle).
Since the internal gearing is 64/1, one turn of the output shaft requires 4096 steps.
The binary patterns for achieving half-stepping are documented in the move(){...} and rotate(){...} functions.
SCALE
SCALE calibrates the robot's forward and reverse motion.
Assuming a wheel diameter of 65 mm then the robot will move forward (or backward) PI*65/4096 = 0.04985 mm per step. To achieve 1 mm per step (Inkscape uses mm for its' co-ordinates) we must use a SCALE factor of 1/0.04985 = 20.0584. This means that the number of steps needed to travel between any two points is "distance* SCALE".
CWR
The CWR (Circle-diameter to Wheel-diameter Ratio) [1] is used to calibrate the robot's turn-angle. A high CWR offers greatest resolution and minimum cumulative error, but the downside is that it will take longer for the robot to turn.
Assuming that the robot wheels are spaced 130mm apart then the wheels must travel PI*130 = 408.4 mm for the robot to rotate 360 degrees. If the diameter of each wheel is 65mm then one turn of a wheel will move the robot PI*65 = 204.2 mm around the circle. For the wheels to travel the full circle distance they must turn 407.4/204.2 = 2.0 (twice).
This translates to a CWR of 2 and a resolution of 360/(CWR*4096) = 0.0439 degrees per step.
For greatest accuracy the SCALE and CWR should both use as many decimal places as possible.
[1]
The wheel-tracks form a circle when the robots turns 360 degrees. Since the wheel-tracks overlap the formula for CWR is:
CWR = wheel-spacing/wheel-diameter.
The GCODE Interpreter
The robot only responds to Inkscape commands starting with G00, G01, G02, and G03.
It ignores any F (feedrate) and Z (vertical position) codes as the robot can only travel at one speed, and the pen is always up for code G00 and down for all other codes. The I, and J ("biarc") codes used when plotting curves are also ignored.
The unused code M100 is used for the "MENU" (M for Menu).
Extra T-codes have been added for test purposes (T for Test)
The code for my interpreter was inspired by https://github.com/MarginallyClever/gcodecncdemo
Step 5: Installing the Robot Software
Switch-off then unplug the "motor / blue-tooth" shield. This achieves two things:
  • It removes the battery-pack while you program the arduino via your USB cable
  • It removes the HC-06 blue-tooth device as programming is NOT possible while the Blue-tooth module is connected. The reason for this is that you can't have two serial devices connected at the same time.
Copy the contents of "Arduino_CNC_Plotter.ino" into a new arduino sketch and upload it to your arduino. Unplug your USB cable once the software has been uploaded.
Reconnect the above shield ... your robot is "ready to roll".
Step 6: Setting Up Your Bluetooth
Before you can "talk" to the robot the HC-06 bluetooth module must be "paired" with your PC.
If your PC doesn't have blue-tooth then you need to purchase and install a Bluetooth USB dongle. The necessary drivers are contained within the dongle. Just plug it in and follow the on screen instructions.
The following sequence assumes that you are using Microsoft Windows 10.
Left-click "Start | Settings | Devices | Bluetooth". Your screen will display the bluetooth status of each device that can be connected. The bottom-left screen shot shows that the PC is currently aware of some bluetooth earphones.
Turn on the robot. The HC-06 bluetooth module will start flashing and the device will appear in the bluetooth window as shown in the centre-bottom screen shot.
Left-click "Ready to pair | Pair" and enter the password "1234" as shown in the top screen shot.
Left-click "Next" to pair the device. Your screen should now be similar to the lower-right screen shot which says "HC-06 Connected".
Step 7: Installing the Terminal Emulation Software
In order to "talk" to your robot you need a terminal emulation software package the purpose of which is to connect your keyboard to the robot, and send g-code files to the robot, via the bluetooth link.
My choice of terminal emulation software for this project is "Tera Term" as it is highly configurable. The software is free to use and the latest version is available from:
https://osdn.jp/projects/ttssh2/downloads/64798/term-4.90.exe
Double-click "teraterm-4.90.exe" from your "Download" folder and follow the on-screen instructions. Select the default settings. Left-click "Serial" then "OK" at the opening screen.
Configuring Teraterm
Before we can "talk" to the robot we must configure "Teraterm":
Step 1:
Left-click "Setup | Terminal" and set the screen values to:
Term size:
  • 160 x 48
  • Un-check the two boxes immediately below
New-line:
  • Receive: CR+LF
  • Transmit: CR+LF
Leave the rest of the screen with the default values.
Click "OK"
Step 2:
Left-click "Setup | Window" and set the screen values to:
  • Click "Reverse" (changes the screen background colour to white)
Click "OK"
Step 3:
Left-click "Setup | Font" and set the screen values to:
  • Font: Droid Sans Mono
  • Font style:: Regular
  • Size: 9
  • Script: Western
Click "OK"
Step 4:
Left-click "Setup | Serial" and set the screen values to:
  • Port: COM20
  • Baud rate: 9600
  • Data: 8 bit
  • Parity: none
  • Stop: 1 bit
  • Flow control: none
  • Transmit delay: 100 msec/char, 100 msec/line
Click "OK"
Close the warning screen "Cannot open COM20"
Notes:
  1. My blue-tooth uses COM20 for blue-tooth send and COM21 for blue-tooth receive. Your blue-tooth port numbers may differ.
  2. The transmit delays are to slow things down when using "File | Send ... ". The arduino seems to miss lines if you try speeding things up. "File | Send ..." seems reliable with the the values shown but feel free too experiment.
Step 5:
Left-click "Setup | Save setup ... " and left-click "Save"
Close Teraterm
Step 6:
Turn on your robot. The blue-tooth LED will start flashing.
Open Teraterm and wait for the message "COM20 - Tera Term VT" to appear in the top-left corner of the Teraterm screen. The blue-tooth LED should now be steady
Type "M100" without the quotes ... a menu should appear. The numbers 19: and 17: that appear on the screen are the Xon and Xoff handshaking codes from the arduino..
Congratulations ... your robot is now configured.
Step 8: Test Charts
The "Menu" contains two test charts.
T103 plots a simple square. All corners should meet. Adjust the CWR constant and recompile your code if they don't.
The theoretical CWR for my design was CWR = 141/65 = 2.169. Unfortunately the corners didn't quite meet. To reduce the calibration time I plotted two squares ... one with a CWR = 2 and the other with a CWR = 2.3. If you study the above photo you will see that ends of one square are "open" while the other ends "overlap". Measure the end-to-end distance for each of the squares and grab a sheet of graph paper. Draw a horizontal line with (in this case) 30 divisions labelled 2.0 through 2.3. Using as large a scale as possible, plot the "overlap" distance above the horizontal line and the "open" distance below the line. Connect these two points with a straight line and read off the CWR value at the point where the diagonal line cuts the CWR axis. For my robot this CWR point was 2.173 ... a difference of 0.004 !!
T104 plots a more complex test chart.
The Inkscape g-codes for this test chart are contained in the file "test_chart.gnc". The "biarc" "I","J" parameters shown in the code have been ignored which accounts for the segmented circle.
Step 9: Creating an Outline
The following procedure uses "Inkscape" and assumes that we wish to draw a flower from an image titled "flower.jpg".
Inkscape version 0.91 comes with gcode extensions and may be downloaded from http://www.inkscape.org Click "Downloads" and select the correct version for your computer.
Step 1: Open your image
Open Inkscape and select "File|Open|flower.jpg".
Choose the following options from the pop-up screen:
Image Import Type: ............ Embed
  • Image DPI: ......................... From file
  • Image Rendering Mode: ... None
  • OK
Step 2: Centre the image
Click F1 (or the top-left tool in the sidebar)
Click the image ... arrows will appear
Simultaneously press-and-hold your "ctrl" and "shift" keys then drag a corner-arrow inwards until the page outline appears. Your image is now centred.
Step 3: Scan your image
Select "Path | Trace Bitmap" then choose the following options from the pop-up screen:
  • colors
  • uncheck "stack scans"
  • repeat: update ... scan number ... update
  • click OK when you are happy with the number of scans
Close the pop-up by clicking the X in the top-right corner.
WARNING: Keep the number of scans to an absolute minimum to reduce the robot plotting time. Simple outlines are best.
Step 4: Create an outline
Select "Object | Fill and Stroke|". A pop-up with three menu-tabs will appear.
  • Select "Stroke paint" and click the box beside the X
  • Select "Fill" and click the X
Close the pop-up by clicking the X in the top-right corner. An outline is now superimposed over the image
Deselect your image by clicking outside of the page.
Now click inside the image. A message "Image: 512 x 768: embedded in root", or similar, will appear at the bottom of your screen.
Click "delete". Only the outline remains.
Step 5: Time-out
Time for a little exploring.
Click F2 (or the 2nd from top tool in the sidebar) and move the cursor over the outline. Note how the outline flashes red as the cursor passes over the different paths.
Now click the outline. Notice how a number of "nodes" appear. These "nodes" need to be converted into g-code co-ordinates but before we can do that we need to assign a reference co-ordinate to our page.
Step 6: Assign the page co-ordinates
Press F1 then click the outline.
Select "Layer | Add Layer" and click "Add" in the pop-up window. The g-code extensions that we are about to use require at least one layer ... even if it is blank !
Select "Extensions | Gcodetools | Orientation points". Choose "2-point mode" from the pop-up window and click "Apply".
Dismiss any warning messages.
Click "Close" to close the pop-up
The bottom-left corner of your page has been assigned the co-ordinates "0,0; 0,0; 0,0"
Step 7: Select a tool
Select "Extensions | Gcodetools | Tools library" and click:
  • cone
  • Apply
  • OK .... (to clear the warning)
  • Close
Press F1 and drag the green screen off the page outline.
Step 8: Adjust the tool and feed settings
This step is not required but has been included for completeness as it shows how to change the tool "diameter" and "feed" settings should you have a milling machine.
Click the "A" symbol in the sidebar then change the settings shown in the green screen from:
  • diameter: from 10 to diameter 3
  • feed: from 400 to 200
Step 9: Generate the g-code
Press F1
Select the image
Select "Extensions | Gcodetools | Path to Gcode | Preferences" and change:
  • File: flower.ncg .............................................(numerical control g-code filename)
  • Directory: C:\Users\yourname\Desktop ... (storage location for flower.ncg)
  • Z Safe Height: 10
Without leaving the pop-up window, select the "Path to Gcode" menu tab and click:
  • Apply ... (this may take a long time ... wait !!)
  • OK ....... (dismiss any warnings)
  • Close ... (once the code has been created)
If you examine the outline it now consists of blue arrow-heads (lower image).
Close Inkscape.
Step 10: Verify Your Code
https://nraynaud.github.io/webgcode/ is an online program for visualizing the image that your g-code will create. Simply drop your g-code onto the left-hand panel of the simulator and the corresponding visualization will appear on the right-hand side of your screen. The red lines show the tool-path and robot pen-lifts.
The "Path | Trace Bitmap" settings for the top image were:
  • "Colors"
  • "Scans: 8"
The "Path | Trace Bitmap" settings for the bottom image were:
  • "Edge detection"
  • "Threshold: 0.1"
Unless you need the detail always create a simple image.
Step 11: Sending an Inkscape File to the Robot
Let's assume that we want to send a file "Hello_World_0001.ngc" to the robot.
Step 1
Power up the robot.
Place the robot on the bottom-left corner of the drawing-page and point it towards 3 o'clock. This is the default starting position.
Open Teraterm and wait until the bluetooth light stops blinking. This indicates that you have a link.
Step 2
Check that the maximum X and maximum Y values in the file that you are about to send will fit on the page. For example the attached "Hello_World_0001.ngc" shows the maximum X value to be:
G00 X67.802776 Y18.530370
and the maximum Y value to be:
G01 X21.403899 Y45.125018 Z-1.000000
If you want your image to be larger than the above 67.802776 by 45.125018 mm then change the plot-size using the following menu options:
M100
T102 S3.5
This command sequence displays the menu, so that you can see the T-codes, then increases the image size 3.5 times (350%)
Step 2
Left-click "File | Send file ..."
"Browse" for the "Hello_World_0001.ngc" file.
Left-click "Open" . The file will now be sent to the robot line-by-line.
It's that simple ... happy plotting :)
Notes:
  • All MENU commands MUST be in upper-case.
  • The 19: and 17: shown in the above photo are the arduino handshaking codes (decimal) for "Xoff" and "Xon". The colons were added to improve the visual appearance. An Inkscape command follows each "Xon".
  • You should never see two X,Y co-ordinates in the same line. If this happens, increase the serial delay times from their current value of 100mS per character. Shorter delays may work ...
  • The "Hello World !" plot shows signs of cumulative error. Tweaking the CWR should fix this.
  Click here   to view my other instructables.
    • Tape Contest
      Tape Contest
    • Arduino Contest 2019
    • Trash to Treasure
      Trash to Treasure
    60 Discussions
    JijoS2
    Question 3 days ago
    The robot stops just after 2 lines of code is transmitted. Sometimes even the bluetooth module gets disconnected after these 2 lines are transmitted.
    1 answer
    lingibJijoS2
    Answer 3 days ago
    I am assuming that the robot plots a square when the "T103" test code is sent.
    If so the probable cause is likely to be with the "TeraTerm" software package. Unless you find the correct combination of delays, TeraTerm will send the next line of code before the robot is ready to receive it, at which point the robot will stop.
    The good news is that there are two solutions , both of which work ... replace Teraterm with either:
    - https://www.instructables.com/id/CNC-Gcode-Sender...
    - CoolTerm from http://rogermeier.blogspot.com/2011/09/update-coo...
    I wrote "CNC-Gcode-sender" to eliminate this software over-run problem. It works well.
    Since writing "CNC-Gcode-sender" I have come across "CoolTerm" written by Roger Meier. Details on how to install this freeware program may be found in Step 7, of my instructable https://www.instructables.com/id/Omni-Wheel-CNC-P... CoolTerm is easier to install than "CNC-Gcode-sender" ... I suggest that you try this first.
    I have no explanation as to why the bluetooth module gets disconnected? Try one of the above terminal programs ... hopefully the problem will sort itself ... it could simply be due to the plotter locking up due to code over-run.
    Be aware that the "https://www.instructables.com/id/CNC-Robot-Plotter/" is okay for simple drawings but will tend to drift when the drawings become more complex.
    There are several reasons for this:
    - The CWR ratio needs to be really accurate.
    - Mechanical backlash in the gears.
    - Changes in wheel spacing due to "end float".
    - Wheel slip
    - Rounding errors ... stepping motors can only take exact steps.
    Having said this one user finds this plotter accurate enough to outline model aircraft wings onto foam board.
    lingibJijoS2
    Answer 2 months ago
    The components for this project are mounted on a blank prototype board.
    A suitable prototype board is available from https://www.aliexpress.com/ ...just search for "Prototype PCB Expansion Board For Arduino"
    JijoS2
    Question 2 months ago on Introduction
    can you please provide the dimensions of the chassis. if it is to be 3D printed,can u please provide the stl file?
    1 answer
    lingibJijoS2
    Answer 2 months ago
    The dimensions of all metal-work are given in step 1.
    The dimensions of the platform that is attached to the metal-work is not critical. I used a scrap of acrylic sheet approximately 160mm x 110mm.
    There are no STL files for this project as it was made from readily available parts. If you do decide to 3D print this project pay particular attention to the chassis design ... it is critical that the wheel spacing does not alter.
    diegoec
    4 months ago
    me podrian pasar el codigo de este proyecto
    Could you pass the code of this project
    lingibdiegoec
    Reply 4 months ago
    The code, "Arduino_CNC_plotter.ino", is attached to Step 5: Installing the Robot Software.
    YG1144
    Question 11 months ago
    If i want to put Optical Endstop Light Control Limit Optical Switch in the robot to stop 2 stepper motors absolutely as ever i want. Do you have any ideal to make the Arduino code base on your old code for it?
    1 answer
    lingibYG1144
    Answer 11 months ago
    Software is not required if you remove the 5 volt supply to the motor(s) using a microswitch.
    The robot spends most of its time in a "process()" function. If you really need a software solution then consider writing an interrupt routine. This will eliminate any possible robot delays in responding to your sensors.
    Good luck :)
    ThanhL31
    Question 1 year ago
    In fact, i understood your code in processing 3. When i input the gcode file (.ngc) they appear in the command but the robot does nothing! Not like when t write "T102" or "T103" to make it draw!? Do you know how to solve the problem?
    ThanhL31ThanhL31
    Answer 1 year ago
    OK thanks for your advice! I tried and i thought I had already fixed the problem! The problem was about Xon and Xoff that the software did not send line by line to the Bluetooth and the robot did not run well! I had fixed that problem and also changed little the code based on yours! Thank you so much!
    lingibThanhL31
    Answer 1 year ago
    Your photos tell me that your robot is talking correctly to my G-code Sender ... well done :)
    You indicate that the robot is working correctly when you ask it to draw a "square" (T102) or a "target" (T103) which points to the G-code that the robot is receiving.
    If you look closely at the G-code in your second image you will notice:
    (1) the variation in X-axis movement is from X21..X29 which is a total of 9mm
    (2) and that the variation in Y-axis movement is from Y34..Y35 which is a total of 11mm.
    (3) in between these extremes the robot hardly moves.
    Download "test_chart.ngc" from step 8 of the instructable and send that to the robot. It should print the SAME test pattern that is built into the robot. (Rename the file to test_chart.ngc if the name changes during the download process.)
    Also you should be able to print a "square" if you enter each of the following command manually or enter them into a text editor then save the file as "test.ngc" (without the quotes).
    G00 X36 Y213
    G01 X173 Y213
    G01 X173 Y82
    G01 X36 Y82
    G01 X36 Y213
    G00 X20 Y00
    G00 X00 Y00
    When creating you own code it is important to verify it using the method shown in step 10.
    Once verified visually check whether you need to apply a scale factor to the plotter before sending the file.
    Hopefully this solves the problem ...
    ThanhL31
    Question 1 year ago
    Okay! I see your point but i cannot find how to connect bluetooth of the robot to the "Processing 3" software like using Tera Term. Can you show me how to do it?
    ThanhL31
    Question 1 year ago
    I follow all your instruction,however i guess when i send file .ncg to Tera Term, it transfers too fast so the robot cannot do the whole code-lines! It just do some of them ! How can i fix that?
    1 answer
    lingibThanhL31
    Answer 1 year ago
    Try using https://www.instructables.com/id/CNC-Gcode-Sender/
    CNC-Robot-Plotter was my first attempt at controlling something using bluetooth.
    I used Tera Term because it appeared to work providing the appropriate delays were added. These delays were to prevent the terminal missing the Xoff signal from the robot.
    The problem with delays is that they they slow the data transfer rate down to a crawl. For this reason I wrote my own gcode sender which I now use in all of my projects.
    https://www.instructables.com/id/CNC-Gcode-Sender/ is 100% reliable as an internal Xoff signal is generated within the G-code sender at the end of each Gcode line ... no further data is sent until the robot sends an Xon.
    This eliminates all latency issues and as a result the data transfer rate is as fast as your robot can handle.
    thanh duongl
    1 year ago
    I can not do step 7( Installing the Terminal Emulation Software) . The last part step 6 of it after i serial to the com bluetooth ,type "M100" and nothing appear! Can you show me more detail how to make it ! I already followed your instruction but it did not work at that step!
    Here is some step that i already followed you! Please help me fix it!
    lingibthanh duongl
    Reply 1 year ago
    Thank you for your interest in this instructable . I no longer have a working working robot ... the parts have been reused in later projects ... but the following checks should help isolate the problem.
    Things to check:
    1.
    Talk directly to the robot via your USB cable. Make sure the bluetooth module is unplugged ... power down before unplugging.
    Press the arduino reset button while your arduino Serial Monitor is running. A menu should appear. Now type M100 ... a second menu should scroll down the screen which indicates that the arduino code is okay.
    2.
    Unplug the USB cable and replace the bluetooth module ... the power must be off when you do this.
    Does an LED on the bluetooth module start flashing when power is applied to the robot ... it should.
    Does the LED stop flashing when you attempt connecting to the robot ... it should.
    Press the arduino reset button ... a menu should appear.
    If it doesn't measure the voltage on the arduino RX pin ... it should be around 3 volts.
    Bluetooth can be a problem ... delete the HC-06 from your PC and try reinstalling. Try pairing another bluetooth module ... I experienced one that wouldn't communicate even when the LED stopped flashing.
    Try another terminal emulator such as https://www.instructables.com/id/CNC-Gcode-Sender/.
    Hopefully the above tests will isolate your problem ...
    thanh duongllingib
    Reply 1 year ago
    Thank you ,sir! I made it However, i still wonder some problems with this robot. I want to make the robot after draw everything,it goes back to home-stay( a place at the beginning exactly) to ready for a new graph. Therefore if i want it to draw again the old graph,it can make a graph that can overlap the old one! In fact ,your instructions are really great because it can get back to the home-stay but not really because i see it turn an angle when i compare to the begin position.Do you have any ideal to make that get back exactly the home-stay?
