CPU Hand Warmer
2,694
8
Cold hands? Just make this Hand Warmer and your hands are warm very fast!
Supplies:
Step 1: Requirements
You will need:
An old CPU
An USB Cable
Pliers
Stripping Pliers
Tape
Step 2: Mount the Cables
Cut off the micro-usb plug.
Strip the cables and cut off the green and white cable.
Mount the cables as shown.
If you've got a Pentium 4, you should follow this instruction,most CPU's with that age are the same as this one, otherwise try different pins.
You can remove the other pins if you want.
Tape the cables with adhesive tape or duct tape.
Step 3: Done!
Connect the warmer to a power bar to make it portable.
Enjoy!
    • Fandom Contest
      Fandom Contest
    • Party Challenge
      Party Challenge
    • Gardening Contest
      Gardening Contest
    3 Discussions
    alexvpopescu
    3 years ago
    very cool project !!! but how do I find good pins to solder ? do I have to try randomly until my Pentium 3 becomes hot ?
    WingraMaxalexvpopescu
    Reply 3 years ago
    Use a multimeter to test if the pins are electrically connected. Than, run 5 volts into one pin and see how much comes out the other.
