CREATING a FIGURE ARMATURE FOR SCULPTURE
375,318
429
35
About: 3D Character/ Concept Artist
The armature is a fundamental part of the sculpture. In very basic terms it is the skeleton or support structure that will hold your clay as you sculpt the figure. It is important not to take short cuts or work hastily without proper planning, as this will result in much unnecessary frustration later on.
For beginners an armature can seem complicated and overwhelming not knowing where to begin. This is a simple system that works quite well and can make an armature in a relatively short amount of time (usually 30 minutes for a 12" armature!)
There are some clays out there that are self-supporting and therefore do not require they use of a support armature. These materials are clay/wax hybrids that are light in weight and fairly rigid when cool like Castilene, which will be covered in another segment.
Supplies:
Step 1: PROPORTIONS
Once you have established your scale you will need to establish what proportions to use. This will depend in large part with the type of character you will be sculpting; for example a male super hero will have different proportions when compared to an average adult male. In a similar fashion a male super hero will differ in proportion to a female super hero as female characters tend to look better with longer legs and shorter torsos then their male counterparts.
Also a child will be quite different in proportion to an adult& so on and so forth. Proportion can make a figure more or less heroic according to how many heads tall he/she is. For our purposes proportions are measured by using the head as the unit of measurement. From this unit we can find the measurements for the rest of the body. The average human being is 7 1/2 heads tall meaning that if you were to divide the person using the measurement of their head you would find that it would fit 7 1/2 times their body in height. From this there are other measurements that we can find but for the time being this is really the most important aspect you need to understand.
For sculpting you will find that 7 1/2 heads tall, although correct, can make a figure reduced to scale look a little dumpy. This is simply an illusion caused by the fact that you are sculpting something at a reduced scale from the real thing. This is especially true for female figures. In fact you can extend the legs on female figures a little to make sure they look graceful and elegant. In the end though proportion comes down to personal tastes so once you learn how proportion works you can then modify it to achieve the results that most appeal to you.
Step 2: THE PROPORTION CHART
A proportion chart is very much like a map showing you where to go. It really makes your life a lot easier when building the armature and can be a very simple sketch like a basic stick figure. The main thing is that it be fairly accurate when it comes to the head proportions as mentioned previously. By creating this proportion chart you will relieve yourself of many headaches later on during the clay stage where mistakes in proportion caused by the armature become very difficult to fix. Things like the armature poking out of the hip area, or an arm being to short or too long, can all be avoided by laying out the armature over a proportion chart beforehand. Be patient with this step and take your time to get it right or it will make your sculpture a frustrating experience later on!
When you draw your proportion chart make sure you draw it the same size as the figure you intend to make. For example a 12" figure will require a 12" tall chart; an 18" figure will require an 18" tall chart, so on and so forth. You will need to lay down the armature wire over this chart so it is important that the chart be of the correct size.
Follow the chart below [see photo] to help you draw your own. Alternatively you could search the net for a proportion chart with equal results. Then simply scale the chart to the correct size (using photo editing software or a photocopier).
For this example we are going to use a proportion of 8 heads tall. This will keep our figure more realistic but not dumpy or too elongated. If you wanted to create a more heroic figure, like a larger then life super hero, then 9 heads (or more) would be even better.
One last thing to mention is that you should make (or find) a proportion chart for a female figure and one for a male figure, as the body structure between the two genders is not the same. If you were to use a male chart for a female figure often you would find that your girl would look a little on the manly side (having wider shoulders and a narrow hip area) when in fact you would want the opposite (females have wider hips and narrower shoulders then men). It helps if you treat male and female figures as though there were two entirely different creatures to ensure you have men that are manly and women that are feminine and graceful. It is good to have a very different mindset when approaching each individual gender.
WHAT YOU WILL NEED:
-1/8th aluminium armature wire
-1/16th aluminium armature wire
-Small gauge galvanized steel wire (18 gauge or thinner is best)
-Wire cutters
-Pliers
-Apoxie putty (Aves Studio)
-A base made from plywood or similar
-A Marker (Sharpie)
Step 3: PLANNING THE ARMATURE
In this step I'm going to explain the process of making an armature to use as your framework for applying clay to flesh out the actual sculpture. In this case I am using a female figure for this tutorial but this method works for any type of figure that has human (or human-like) physiognomy.
The armature requires a bit of planning, time and patience in order to make correctly but is really not that difficult once you know the process. The wire we are using for the main structure of the armature is going to be the 1/8th thick armature wire because it is strong enough to support the weight of the clay while at the same time is malleable enough to be easily bent into shape not to mention straightforward to cut with wire cutters or a hack saw later on to divide the sculpture.
You sometimes hear about using metal coat hangers you get from the dry clear instead of aluminium armature wire because it is cheap and readily available. Its true that if you really have no other choice then a metal hanger is fine but it is strongly advised against using it because it can be really difficult to work with and is more of a nuisance then anything in the end and definitely not easy to cut apart once your model is finished. Sometimes what is cheaper is not necessarily better!
It is vital that the armature is correctly proportioned and sturdy enough to hold-up your clay and not move around while you work (or flop over!) while allowing you to make pose adjustments later on.
Basically if your armature is incorrect, or disproportioned, then the whole sculpture will be out of whack from the get go and you will have an extremely frustrating time making it work. An armature that is properly constructed will actually aid you during sculpting while a poorly made one will make you want to quit or, in some cases, cause you to throw your work against a wall (this is not recommended of course!).
You can often dictate, based on the armature, how well your sculpture will look the end. I noticed that many beginners tend to overlook this stage only to find themselves with major headaches later on during the sculpting phase.
Bottom line: make sure you make your armature properly: it's worth the effort!
Once I have decided on a character and pose that I want to sculpt I have to decide at what scale I'd like to make the sculpture. In this case I will make a female figure 12" tall (roughly 1/6th scale). Because she is a realistic figure I am using a template I found in a book that is suitable for this type of human figure (a proportion of 8 heads tall roughly).
You wouldn't want to use a template with irregular human or cartoon proportions on this piece, as it wouldn't look right. In fact proportion has a lot of influence on how you want your character to be perceived by the observer and should be carefully considered before making the armature. There are many books that cover proportion and its affects (like "Drawing the Marvel Way") so I won't be touching upon that here.
Once I have my template, I carefully re-size it to the measurement (I use Photoshop but a similar imaging editor will work too or you can use a photocopying machine) I want my final sculpture to be, in this case, 12" tall (from head to feet). I then select a suitable armature wire size which, in this case I used 1/8th armature wire (available at most art stores), but you could even use 1/16th armature wire braided together as well (which ends up being 1/8th thick).
The main thing you want to look at is that the armature provides enough support for the modelling process but, at the same time, won't be too large to poke out or not allow for enough material to be laid onto it. The biggest concern for me is making sure it won't deform too easily when I'm applying clay: there is nothing more frustrating then a wobbly armature!
Step 4: MAKING THE ARMATURE PIECES
Once I've selected my wire I carefully lay it over my template. I then proceed to mark the joints (like elbows, shoulders, knees, bottom of feet, etc.) with a Sharpie and then carefully bend it according to my guide (make sure you don't miss this marking step as it will be important later on for posing!).
I make sure I leave at least 1" of length at the bottom of the feet so I can embed the armature into a piece of wood later on: this will serve as a stable base for sculpting. I use one piece of wire, bent accordingly, for the legs, torso and arms (I make two of these).
I then use a single length of wire for the spine/neck/head area (see photo).
Once I am satisfied with my pieces I then take a fine gauge wire (available from most hardware stores) and carefully wrap the three pieces together.
I do my best to wrap them fairly tight so they won't move around on me too much. It's OK if they move a round a little bit as we will set them in place later on. The main thing is that the pieces don't come apart or become too loose.
At this stage the armature won't necessarily reflect the pose of my reference material: that is OK! I'm going to make the pose adjustments later on. It is important that you lay down your armature onto a frontal orthographic view or you could end up with distortions later on. Once you have a good solid armature that is orthographic and balanced then the posing can be done after. As you will see we are going to set up the armature so that the posing will be easier while sculpting.
Step 5: FIXING AND MOUNTING THE PARTS
Now I have my armature together in a temporary fashion, but sturdy enough to allow me to mount it onto the wooden base, I carefully try to pose my piece so that it is close to my reference art as possible. Make sure you use pliers placed on your marked joints to make the bends (you want them to be crisp!) because if you try to bend them simply with your fingers you won't have a hard edge to serve as leverage and you will end up with "spaghetti" looking limbs.
Remember that your real joints bend at specific points (remember those marks you made with the Sharpie?!) so you want to make sure you are bending your wire in a similar fashion and NOT like a wet noodle (unless you are sculpting Rubber-man of course).
Once I'm satisfied with my pose (or close enough: I can always tweak it later on), I mark my piece of wood with a Sharpie where the foot pegs will go (I do this by placing my armature over my piece of wood in the approximate pose). I then take my trusty drill and make my holes using a 1/8th drill bit (the same size as my armature wire). If you have access to a drill press then that is better as your holes will be at right angles.
A regular hand drill works great too though!
Step 6: FINAL STEPS
If you were using a different armature wire, like 3/16", then you would use a 3/16th drill bit. Don't try to use the wrong bit (go out and buy one if you don't have it already) or the armature wire won't fit snug and will wobble and give you problems later on! Another reason you want the wire to fit snug is to avoid gluing it down since you want to be able to remove your sculpture once its done to then place it onto a more permanent base for displaying or for molding purposes.
Using my reference I can continue posing the wire until I'm satisfied (or close enough) the pose I'm after. It is normal to tweak the pose during the clay stages as well, which is why you want to use an armature that is sturdy, yet flexible enough, to allow tweaks as during the clay stage.
Optional step:
Using Apoxie Sculpt putty (non-toxic epoxy putty made for artists: cures to a rock hard surface in a few hours!) to make bones can be beneficial for sculptors that want to make sure they bend their armature only at specific points (such as a joint).
By locking down the armature with Apoxie Sculpt (or similar putty) your armature will behave much like a real body would and not make spaghetti bends in your work.
I proceed to place it on the wire to act like "bones". I make sure I leave the joints free though because I want to be able to freely tweak the pose during sculpting.
Remember this putty cures to a rock hard finish so there won't be any flexibility where it is placed! This is good because when you are sculpting, and you want to tweak the pose, you will only be able to bend the armature according to the joints (like a real skeleton) because they were left exposed. The last thing you would want to do is to use pliers when you have clay on your piece. The putty takes care of this, as it will only bend at predetermined points!
I continue to putty the figure making sure I don't bulk her up too much (keep it skinny!) or I may find myself with areas of putty poking through the clay. This is true especially for smaller scale female figures (like this one). At 1/4 scale you have a bit more "meat" to work with. As you can see (left) I also made a small ball of putty to serve as a head support. In some cases it may be ideal to make the head removable. All you would have to do is use a piece of brass tubing that fits over the 1/8th wires snugly (but not too tight!). Instead of making the ball of putty on the actual armature wire, you would make it on the brass tube (still following your initial guide of course) and you would keep the centre armature wire straight. This way you can simply remove the head with ease (just make sure the tubing isn't too tight!).
Once you are done puttying all that is left to do is let the material sit and cure (usually a couple of hours depending on the temperature/climate).
If you don't want to wait you can use a heat gun or hair dryer on a LOW setting to speed up the process (a high setting would cause it to bubble and expand or burn!).
One thing to note is that the putty will become soft when heated and could tend to sag (it gets harder as it cools) so I tend to heat it up in waves allowing it to cool a bit in between...
Well that's about it! Of course this isn't the only way of making an armature, every artist has their own method, but this has worked for me. Of course please feel free to tweak the process so that it works best for you!
    • Party Challenge
      Party Challenge
    • Woodworking Contest
      Woodworking Contest
    • Arduino Contest 2019
    35 Discussions
    SharonasaurusX
    2 years ago
    Hi, I was wondering what method you used to attach the finished model to its display base?
    Tystarr
    10 years ago on Introduction
    So when you're done modeling do you clip the wires off the base to put the fugure in a kiln?
    Setti Fine ArtTystarr
    No- I bake it on the base as shown in the pics. I should clarify that super sculpy you use your home oven. It is a polymer clay not a conventional water clay. Most people like to use it for maquette work because after baking it becomes hard and paintable so for a one off you don't need to make a mold and you have something permanent to display. You can't actually use a wire armature if you were to fire water clay as it would make it crack and explode but it is perfectly fine for baking super sculpy which is done at really low heat in your home oven.
    Hi I'm doing a 3D comtep craft BA, its infuriating as I'm on a course that allows me to do clay modelling (in Terrotta or White St.Thomas clay) but they do not have anyone to specifically teach modelling. I'm going nuts searching the net, while having to try to work out how to do this myself. So I was interested in how you make an armature but i need to find out how to make an armature that supports water based clays with the end result being kiln fired and how you would remove a figure from an armature before firing ?? And for for a larger more lifesize figure would a large armature be made of jointed gas piping and the figure cut off the armature in sections and hollowed out? Is this something you have done before and if so any tips or advice please? Welcome advce on usefull books ,websites etc really struggling to know best to do this..badly need help... Many Thanks , Sam.
    AMKR
    4 years ago on Step 2
    This is great for clay sculptures - but Id imagine Id need a much sturdier armature for a metal / found object type creation right? How would I go about building (or buying) a skeleton to build around for something that heavy? Any help would be appreciated (I also want to be move able/somewhat pose-able as well - and to not be top heavy/etc etc)
    Ernext
    this is awesome for the base, what do you to sculpt the figure? i use cold porcelain
    melliott11
    5 years ago on Introduction
    Getting a glimpse of this process is fascinating, thank you.
    haydendelioncourt
    5 years ago on Step 6
    was the Apoxie Sculpt the only clay that you used? Would polymer clay work?
    woodNfish
    6 years ago on Introduction
    Many figure drawing books have proportion charts and you could probably photocopy one from a library book if you wanted, but the proportions shown in the drawing for this instructable are not realistic. The legs are at least 1/3 too long, but just right for teenage boys who read comics.
    locoxellas
    10 years ago on Step 2
    could you give me a link where i could download the THE PROPORTION CHART of a woman so i could print it in scale? thanks in advance!!!
    amayer
    Can you clarify what gauge wire you are using as the "1/8th aluminum armature wire" and the gauge for the "1/16th aluminum armature wire"? Also is there a downside to using another type of non-rusting metal wire for the armature ie. brass or copper?
    mnpazanamayer
    Reply 9 years ago on Step 2
    I'm not the author, but I'll take a stab at this-
    I'd say don't worry too much about exact gauges. If you can find something that eyeballs at a similar thickness, it'll work just as well.
    In my experiece, copper and brass wires have a springyness that makes them less ideal. When pressure is applied to the clay with a tool, a copper or brass armature tends to give and then spring back instead of holding stiffly in position, making sculpting more difficult. Brass is stronger than copper or aluminum, but in armature terms that just means it will flex further than copper before bending.
    Aluminum by contrast has almost no "spring", though the trade off is it does actually bend easier (i.e. where copper would flex before bending, aluminum just bends right away), so you sometimes have to use a slightly thicker gauge than you might with copper or brass.
    mlcorson
    9 years ago on Introduction
    This is probably one of the most useful techniques I have learned. The use use of Apoxie is just brilliant! Thanks for sharing.
    Xombie Doll
    9 years ago on Step 6
    what is the name of the book in the background?
    Ouchimoo
    9 years ago on Step 3
    "Drawing the Marvel Way" reminds me of overly bustful females. Then you use as as a sample? lol! In seriousness though, isn't 8 heads above average height?
    SharonBugs
    10 years ago on Step 6
    Thank you for your tutorial. I have now learnt what's an amarture, how to start, and what to do for my Indian Dancer figurine. You are so much more helpful and informative than my scultpture class instructor!!
    pumpkinman
    amazing musculature. And the face is astounding, for how long have you been doing this?
