How to Accurately Calibrate Your 3D Printer
193,762
277
80
**Update July 28, 2016**
I've made another Instuctable that builds off this one. Instead of using tape to mark a location, a laser pointer can be used to achieve a higher precision calibration. So once you read through this one and understand the process, check out the follow-up HERE
One of the steepest learning curves when starting with 3D printing is learning how to calibrate all the motors accurately. The good news is that once you know how to calibrate one motor of the printer, the rest are pretty well the same. The following instructable shows you how to accurately calibrate your printer using minimal filament (filament is only needed to calibrate the motor that feeds the filament through the hotend).
I'll be using a Printrbot simple and Repetier for this instructable, but you should be able to follow along with any printer and software combination.
This instructable assumes you got your printer running, it just needs fine tuning.
Here's what you'll need
-3D printer with software to run it
-Digital Calipers
-Ruler (about 40cm should be good)
-Tape
-Filament
-A pencil and a pad of paper can come in handy too.
Step 1: Step 1: Setup
After opening Repetier and connecting your 3D printer, select the manual control tab. Next turn off easy mode and hit the toggle log button(if you're using the most recent version of Repetier), then type into the G-Code: “M501” then press enter or hit send (a bunch of information will be added to your log, at the bottom of the screen)
Scroll up through the log until you see something like this “echo: M92 X__ Y__ Z___ E__.” Make a note of this line of code somewhere because we will be referring back to it often. The M92 values tell the stepper motors how many steps to take when you ask it to move any given distance. In my case I got M92 X80.2 Y80 Z2044 E104.
We'll work on calibrating one motor at a time, starting with the one that controls the X-axis.
Step 2: Step 2: Calibrating X-Axis
Measuring values of X-axis
Start by homing your X axis and raising the Z axis out of the way. (picture 1)
Take a piece of tape (less flexible tape is preferred, so it doesn't sag) and place it on the printerbed parallel to another point of the printer that won't move when you move the X-axis. (picture 2)
In Repetier tell your printer to move its X-axis. I like to start with 70mm (assuming you're using a 100x100x100mm printbed). If you choose to move your X-axis further, you should have less margin for error, but you don't want to go too far and over shoot your printers capabilities. Use another piece of tape at the same marker point you used before moving the X-axis. This is where your printer thinks 70mm is. (picture 3) We'll call this measurement the "Desired movement."
Now use your digital calipers to measure what the "True measurement" is for the X-axis (picture 4)
If you measure 70mm perfect, your X-axis is calibrated. Chances are you didn't get exactly 70mm on your first try though. Make note of the measurement you took. In my case I got 70.87mm.
Calculations for calibrating X-axis
We need 3 variables to calibrate our X-axis. First we need the 'Current M92 value' for X we made a note of in step one. Then we need the two measurements we just took. With these three variables we'll be solving for a 'New M92 value.'
Current M92 value = 80.2
Desired movement = 70mm
Actual movement = 70.87mm
Here's a formula you can use to solve for the New M92 value
New M92 value = Desired movement / Actual movement * Current M92 value
70/70.87 = .987724002 (New M92 value should be 98.77% of the Current M92 value)
80.2*.987724002 = 79.22 = New M92 value
Our New M92 value is 79.22. This makes sense because our New M92 value is less than the Current M92 value(80.2), because we overshot our goal of moving the X-axis 70mm. Now let's move on to the next step and learn how to input the New M92 value.
inputting New M92 Value for X
First type in your G:code for your New M92 value like so : “M92 X79.22” then press enter (picture5)
Then type In G:code: “M500” and press enter. (this saves your changed setting).
Type “M501” in your Gcode and scroll up in your log and make sure your new M92 for X has been saved.
If so, you can return to the beginning of this step and double check that your X-axis is now calibrated. If it is, GOOD JOB!! if not, try again. When you get that done let's move onto the Y Axis.
Step 3: Step 3: Calibrating Y-axis
Measuring values for Y-axis
This is pretty similar to what we've already done. The only real difference is finding another place to stick your tape to mark how far the Y-axis moves. First home your X,Y&Z-axes. Next move your X-axis over until it lines up with the most outside part of your printer arm(picture1). Place a piece of tape on the Y-axis over a point marked on the X-axis(picture 2). Tell Repetier to move the Y-axis 70mm. Now mark that point with a piece of tape and measure the true distance between those points (picture3). I got 69.8mm, which isn't far enough. With these two measurements and our current M92 value for Y, we can now solve for our New M92 value.
Calculation for the Y-Axis and inputting data
Actual movement = 69.8
Current movement = 80
Use our same formula from step 3 to solve for our Y-axis motor.
Desired movement/Actual movement * Current M92 value = New M92 value
70/69.8 = 1.00286533 (New M92 value should be 100.29% of the Current M92 value)
New M92 value = 1.00286533* 80 = 80.23
Now let's input that number. In G:code type your New M92 value like so : “M92 Y80.23” then press enter. Next type “M500” in G:code and press enter. (this saves your changed setting). Then in Gcode type : “M501” and scroll up in your log and make sure your new M92 Value has been saved. If so, you can return to the beginning of this step and double check that your Y-axis is now calibrated. If so, great! If not, try again. Next we'll be working on the Z axis.
Step 4: Step 4: Calibratnig Z-axis
Measuring Z-axis
Instead of using the digital calipers for the Z-axis, we'll be using a ruler. First home your XY&Z axes. Next put your ruler perpendicular to your printbed, alongside the printer. Move your eye so it's level with the printer and make note of a particular point of your printer (I like to use the tallest part of the printers arm). Make sure when you take your measurements, your eye is level with the point your measuring. I measured 17.7cm. Now tell your printer to raise 100mm. Take a look at how far your printer has actually moved. Mine moved to about 27.75cm. If we subtract the second measurement from the first (27.75-17.7cm) we get 10.05cm or 100.5mm. So we've slightly overshot our goal of 100mm.
Calculating and inputting new value for the Z-axis:
Again we use our same formula from step 3 to solve for our Z-axis motor.
Desired movement = 100
Actual movement = 100.5
Current M92 value = 2044
Input measurement/Actual measurement * Old M92 value = New M92 value
100/100.3 = .995024876
New M92 value = 995024876* 2044 = 2033.83
Now let's input that New M92 value: in G:code type your New M92 value like so : “M92 Z2037.89” then press enter. In G:code type: “M500” then press enter. (this saves your changed setting). In Gcode type : “M501” Now scroll up in your log and make sure your new M92 Value has been saved. If so, you can return to the beginning of this step and double check that your Z-axis is now calibrated. If so Great job! Only one more motor to go!
Step 5: Step 5: Calibrating Extruder
Measuring E value:
Now we'll measure and calibrate how much filament comes out of your extruder. First heat up your hotend to the recommended temperature for your filament. Next use a pencil to mark a few cm up on the filament (you can use tape to mark it instead, just don't forget about removing it before it gets jammed in your extruder). Measure how far away the mark is from the extruder. Then tell the printer to extrude 10mm of filament. Measure the distance again.
Subtract your first measurement from your second to find your actual measurement. I got 2.9-1.83 = 1.07cm or 10.7mm
If you got 10mm, then great your E value is calibrated. If not continue to find your new M92 value.
Calculating New M92 E value:
Again we use our same formula from step 2 to solve for our Y-axis.
Input measurement = 10
Actual measurement = 10.7
Old M92 value = 104
Desired measurement/Actual measurement * Current M92 value = New M92 value
10/10.7 =.934579...
New M92 value = 104*.934579... = 97.20
Now let's input that New M92 value: in G:code type your New M92 value like so : “M92 E97.2” then press enter. In G:code type: “M500” then press enter. (this saves your changed setting). In Gcode type : “M501” Now scroll up in your log and make sure your new M92 Value has been saved. If so, you can return to the start of this step and double check that your extruder is now calibrated. If so Great job, Your finished!
2 People Made This Project!
  • Trash to Treasure
    Trash to Treasure
  • Tape Contest
    Tape Contest
  • Arduino Contest 2019
80 Discussions
dashawk
Question 7 months ago
Hi, do you have a tutorial for the 3D Printer that you are using in this instructables on how to build it?
dashawkmrakuaku
Reply 4 months ago
thanks you for providing these resources.
mrakuakud32loser23g
Answer 4 months ago
I can think of 3 ways to calibrate your printer (4 if you have a self calibrating printer). Probably the easiest way is described in my tutorials. The next easiest way would be to do it in the Arduino IDE when you flash your marlin software to your printer (this will take awhile cause you have to flash your printer with every change you make). The most tedious way is to create a sliced file of a print and then manually enter lines of code to do whatever changes you need. I'm not exactly sure what you're asking and if what I just said made you more confused. What kind of printer are you using?
mviljoen2
10 months ago on Step 5
Give this man a bells!
Shot bru! You have no idea how much I struggled. There are lots of Marlin tutorials out there. The very very first thing before you try anything at all with your newly built printer is to calibrate the motors. Mine was Waaaaaaayyyyyyyyyy off. Not knowing what I was doing I incremented the bed size to 475 before it got to the opposite end. Then I realized the motors are only moving half of what the LCD said because the bed is only 220mm. Thanks to your instructable. I managed to fix it. all of the axis-es were moving terribly slow, now they move much quicker to get from point A to B.
dz1sfb
10 months ago
Thank you for this simple clear instructable. I used your method to tune the axis in Marlin. I have had experience tuning Mach3 on my CNC machine before, but have not had to touch it afterwards over a decade.
Ken :)
SteveB452
1 year ago
Confused: You say "80.2*.987724002 = 79.22 = New M92 value" yet when you input it to your printer and save it you say "First type in your G:code for your New M92 value like so : “M92 X80.21” then press enter". Why are you entering X80.21 when you said the new value for x was 79.22?
mrakuakuSteveB452
Reply 1 year ago
I think you're right, I made a mistake... I'll update it now. Thanks!
RiteshB14
1 year ago
Is there any way to change the calibration value without using computer and save it?
The calibration values keep resetting back to default every time I switch the printer off and back on. The printer usb connection is not working properly.
mrakuakuRiteshB14
Reply 1 year ago
What kind of printer are you using and what printing software did you try from your computer?
On your computer go into your printing software settings.
First with your printer unplugged see what COM ports are available to connect to. Then plug in your computer and there should be a new 'COM port' available to connect to. Make sure you select the one that appears only when the printer is plugged in and turned on.
Next if you still can't connect to the printer, try changing the 'baud rate' (also in the printer software settings)... keep changing this and trying to connect to your printer until you find one that works.
RiteshB14mrakuaku
Reply 1 year ago
I am using a Tevo tarantula.
I got the printer connected, but I am still not able to save the value. The value reset after I switch the printer off and back on.
YanV4RiteshB14
Reply 1 year ago
Probably you are missing to store setting in EEPROM. Checked on web pages, Tevo Tarantula should have EEPROM enabled. Try to search menu for "Store setting" / "Load setting".
EEPROM is a permanent part of memory where printer can store such kind of data.
Dolon12
1 year ago
MrAkuAku,
Great explanation. I will do it as soon as I am able to get my newly assembled kit to print. I came to your instruction, because I am trying to fix the weird problem I have.
I move X, Y,Z axes to to limit switches before powering up. The go through the bed levelling process. As soon as I try to print the Z axes moves up 15mm and reset to zero. It then begins printing in midair!
What am I missing? Heaps of stuff on the internet, but still have not found a proper explanation. Is it the firmware or the slicer?
mrakuakuDolon12
Reply 1 year ago
It's difficult to say what the issue is without more information. What printer and slicing programs are you using? Did you change your Z-axis offset?
The command M212 deals with the Z offset. If you can connect your printer to your computer over USB, check what yours is currently set to by entering "M501" in the command line . If it's set to something like 15, then that's probably your issue, and you should start by setting it to 0. If it's set to 0, you can lower your offset by with -15 (although I'd lower it by small increments so you don't crash your printers nozzle into the print bed). you'll need to fine tune the number until you find the exact height for a good first layer.
Follow these steps to change your Z-offset.. (the offset number you use will depend on what M212 is currently set to and how much you need it to move)
1. enter the command "M212 Z-1" to lower your Z axis offset to -1mm
You can also raise your offset with a positive number "M212 Z0.5" this will raise the Z offset to 0.5mm... I would go with a smaller number first though and gradually bring it down. You'll need to save the command before you test it
2. Save your changes by entering "M500" into your command line.
3. Check to make sure your settings were saved with "M501"
If that problem happens with multiple slicers, then it's probably your issue, as M212 is saved on the printers eeprom (internal memory). If it only happens with one slicer, I'd look at your g-code to see if there is a command that tells your printers Z-axis to raise 15mm (something like G1 Z15). You can save a g-code file to your desktop and then open it with notepad to check.
Oh, and by moving xyz to limits, I assume you mean you have the printer home itself and that you're not physically moving them... right?
Dolon12mrakuaku
Reply 1 year ago
MrAkuAku,
Thanks so much for your reply.
The printer is a Flsun i3.
I think it is working properly now.
I did small print, but it is not sticking to bed properly.
I changed it to Auto Leveling now.
I think the problem might have been the firmware. i am totally new to 3D so its all very confusing.
I now use G28 to go home to X and Y. Then G29 to Autolevel and then print. I set the sensor to nearly same level as extruder nozzle. I have to fine tune and then use Z offset. But not sure how to enter the Z offset.
Use the LCd or Repetier Host.
mrakuakuDolon12
Reply 1 year ago
Your probe should be about 1mm higher than your printers nozzle, that way your nozzle won't crash into your print as it's printing.
If your printer has an adjust Z-offset option on the LCD, I would do it that way (I know Prusa i3Mk2 does). If it doesn't, then I'd recommend you connect your printer to your computer over USB then in the manual input tab of Repetier, change your M212 value as I outlined in the previous comment.
Other reasons your print might not be sticking,
make sure your printbed is flat... even with an autolevel probe, it still helps to have a level print bed. If you have your printer hooked up to your computer, when you send the G29 command to your printer you can see how much travel your Z axis is taking to trigger the auto probe.... you can compare these values and try and make them close to being equal.
What are you printing on, is your printbed heated? If so, is it getting too hot for the material your printing? If not, do you have blue painters tape down, and/or gluestick? Are you printing in PLA (I would suggest PLA as your first print material)? Are your temperature settings correct for the material your using? If the first layer sticks but nothing else, maybe you need to calibrate your Z axis or extruder... just somethings to consider
Dolon12mrakuaku
Reply 1 year ago
By trial and error I deduced, as you say that the probe needs to be a little higher than the nozzle. I had to modify the original bracket as it held the probe way to high!
I was not paying much attention to the LCd, as I was just focussed on communicating via Repetier Host.
There is a Z Offset in the LCD control. So I imagine I would need to do an Auto Level, then manually Touch the nozzle to the bed and just in that position activate the LCD Z offset as it does not have any means to enter digits.
I am also learning about the M commands, so will attempt to use them if all else fails.
M114 To Read position of the Axes
M212 Enter Z Offset
M500 To save Changes
M501 To confirm changes.
I have a heated bed, but the User manual suggests no heating for PLA. I am using the supplied masking tape on the bed.
Yes, the very first piece I tried stuck well to the bed but it looked like the extruder was too slow. Upper layers began to drift. Will need to fine tune it all.
mrakuakuDolon12
Reply 1 year ago
How do you navigate your LCD? Is there a spinny wheel thing that you can press in to click (digital encoder), or is it a touch screen? If it's a wheel thing, you should be able to start a print and on the first layer of the print select Z-offset and adjust until the nozzle is a good distance away from the print bed (that's how it is with Prusa i3 Mk2 at least).
What do you mean they drifted.. like if you tried to make a square it would look like stairs? It could be that your Z-axis isn't moving up enough between layers, and you nozzel is hitting your printed part causing X/Y, motors to skip... or it could be your X/Y axis tension belts are loose.... This is a good reference for trying to trouble shoot various issues:
https://www.simplify3d.com/support/print-quality-t...
Dolon12mrakuaku
Reply 1 year ago
The LCD is a Ramps Controller with the rotating knob. I used it to navigate to Z offset with the nozzle almost touching the bed. I think it worked as the print was successful. (See attached photo)
The part that "drifted" had overhangs, and support was insufficient. I think it started too far from the bed so the extrusion did not stick and was dragged around by the nozzle. It ended up like spagetti!
That is a great link. It will help me immensely.
