Campaign Desk
31,756
811
19
About: Furniture hacker. Author of Guerilla Furniture Design, out now. Find me on Twitter and Instagram @objectguerilla.
A campaign desk is a nomadic writing table, popularized by officers of the British Empire in the colonial-minded 1800s. Wealthy officers, who often bought their commissions from the Crown (as opposed to actually training as soldiers), furnished their field tents with teak or mahogany chests, cots, and desks. Many designs featured clever friction fittings or break-down leg systems to keep the officer's possessions (and person) up off of the damp ground. A style evolved, heavy on brass and canvas fixtures, that has now become a commercialized "look" without any of the original core functionality.
This modern take on the campaign desk restores the portability and simplicity of the original campaign furniture. It also copies a structural strategy used by many early campaign desks. Instead of using an apron (a perimeter run of boards under a table to stiffen the top), desks were built as boxes that both held the writing supplies and acted as a self-contained structural unit. The sawhorses are a leaner, meaner update on the usual slapped-together shop workhorses, made from salvaged lumber. Offset legs make for simple overlay joinery and allow the finished units to nestle neatly together.
The result is an expansive, super-sleek command center for the modern knowledge worker. There's plenty of space for a king-sized monitor, scanner, secondary laptop, and all the other accessories of digital life.
Depending on the grade of plywood you choose, this whole desk can be made for about $50.
You will need these tools:
- Tape measure
- Square
- Pencil
- Table saw with dado blade set
- Cross cut sled
- Circular saw
- Drill/driver
- Chop saw
- Bandsaw
- Router or router table (optional)
- Clamps
- Straightedge
- Orbital sander
- Paintbrush
You will need these materials:
- 1 3/4" by 4x8 sheet of plywood, birch preferred
- Roughly 9' of reclaimed 2x4 material
- Spax screws for MDF
- Wood glue
- Brushing lacquer, polyurethane, or finish of your choice
- Furniture wax
Supplies:
Step 1: Desk Top Cuts
The main desk is made up of just four parts: the surface, two identical sides, and a back.
Start by cutting the surface. Use a circular saw and a clamped straightedge to cut it down to 66" long. Run the remaining piece through the table saw lengthwise to rip it to 28". The resultant piece should be 66" by 28".
The long offcut should be 20" x 66". Rip it half to 10" wide by 66" long. Set one piece aside for the back of the desk. Swap out the table saw blade for a dado set.
For the sides, use a crosscut sled and a dado sled to make a 1-5/8"-wide, 3/8"-deep dado down the center (at 33") of the remaining 66" x 10" offcut. Then cut in a 3/4"-wide, dado 4" up from one of the long sides of both pieces. All of the dados will interlock to make strong corners and stiffen the desk surface without the use of a more traditional apron.
Swap the dado set back in. Use a crosscut sled to cut the side piece in half (at 33"), right down the center of the short dado. Measure 10" from one end, and 5-3/4" up from the other (see picture for notes). Connect the marks, Cut the taper on the bandsaw. Made sure you make the sides as mirror images of one another.
I put in a shelf in one corner for a scanner. This is optional; if you want to do it, cut a 3/4" piece of leftover stock to 12" x 4" and two 1/2" pieces at 12" x 16" and 12" x 15-1/4".
Step 2: Desk Assembly
Before assembly, sand all the edges. I sanded all of the edges on a disc sander. This is not the ideal tool for a piece with so many long edges -- I would recommend a true edge sander at least 4' long. Then, smooth the surfaces with 120-grit sandpaper and an orbital sander. The birch ply was already decent quality and didn't need a lot of work; if you're working with a lower-grade plywood, start with 100-grit.
To assemble, lay glue in the dado on the back. Spread with your finger so it coats both the bottom and the shoulders of the dado evenly. Position the surface of the desk so the back edge is hanging over the table and push the back on so that the back edge of the desk surface is seated firmly in the dado. Use clamps and a mallet to persuade the pieces to fit together as necessary. Secure the back by pre-drilling and screwing with Spax MDF screws, which are designed to go into the end grain of plywood without splitting. I left the screws exposed; if you want a cleaner presentation, over-countersink the screws and plug with a dowel and some glue.
Repeat for the sides, taking care that the backs of the sides capture the edges of the back piece.
Add an optional shelf in the corner, and drill a cord hole in the center of the desk surface close to the back. Finish with two coats of lacquer and one coat of furniture wax.
Step 3: Sawhorse Cuts
These sawhorses were a collaboration with Professor Arman Mizani, manager of the Surface Project at the Station North Tool Library.
We made the legs with reclaimed pine 2x6s. To neaten up the wood, take a 1/4" off of each side of your stock with the table saw. Then, using the chop saw, cut into 28" blanks at a 5 degree miter. The miters should be parallel to one another. Make 4 blanks.
Using tapered legs makes for a sleeker, better-looking sawhorse and is more materially efficient, allowing for two legs to be made out of each blank. These taper from 1-1/2" at one end to 3-1/2" at the other. Make a pencil mark across one end at 1-1/2" in from one edge. Do the same at the other end, from the opposite edge. Connect the marks. Set the taper leg jig up to cut that line straight. There are lots of ways to make taper-leg jigs; here's a good simple one. Split all the blanks in half.
An optional, but nice step, is to run all the edges through a router table with a chamfer or roundover bit to clean up any splinters.
Last, make 2 top plates by running 24" blanks through the table saw set at a 5 degree miter. The bevels should be opposite one another and take off as little material as possible.
Step 4: Sawhorse Assembly
Lay one leg on top of another with some wood glue in between. Line them up so the fat ends line up perfectly one on top of another with the cut miters flush. Secure with at least two counter-sunk 3" drywall screws or similar, staggered vertically. I actually used some galvanized hex-head roofing screws because they were salvaged (and free), but deck screws, machine bolts, or lag bolts would all work. Assemble four A-frames this way.
Stand one set of A-frames up. Secure the top plate flush to the top of the A-frame with glue and screws. The end of the top plate should be flush with the outside surface of the A-frame. Repeat on the other side with the other A-frame. The finished pair should be able to nest together, one set of legs fitting into the other.
These sawhorses are plenty sturdy for this lightweight desk, but the lack of bottom brace or trestle make them susceptible to some lateral instability.
To assemble desk, put it on the ground upside down. Screw the sawhorses onto the bottom with two 2" drywall screws each. With a friend, flip over carefully without pausing to rest on the legs at an angle.
Sit down and get to work!
  • Fandom Contest
    Fandom Contest
  • IoT Challenge
    IoT Challenge
  • Party Challenge
    Party Challenge
19 Discussions
JayeshK
Question 5 months ago
how stable is this desk? if it wasn't position against a wall would it wobble back & forth?
static
2 years ago
I first learn of the concept of campaign furniture from a project published in Popular Mechanics or Popular Science. Since my copy has long vanished, I always searching out similar projects. While your completed project looks great but the design isn't for me. For myself I'm sure the legs would prove a trip hazard, along with something my knees an toes will bump into while working at the desk. where I actually am looking for something that's portable to be deployed in the field With this I have visions of computer and radio, and other electronc equipment tumbling to the ground.
YYCTom
2 years ago
This is a great looking desk and very easy to build. Great use of material with little waste as well. I built a prototype using construction grade plywood and 2 X 6s to work out the details and customize the proportions. Worked great, but I suggest that the instruction to cut the bevel for the legs at 5° is incorrect. See the photo attached for a comparison of what a 5° bevel versus a 15° bevel looks like. I think the author may have intended to say 15°.
dobiegr
3 years ago
Very smart! - I appreciate the simple design of the legs, but I'd be tempted to build something which folded flat, had a spar at the bottom of each pair running front-to back, and a rope across the way to stop them spaying if anyone was drunk enough to climb on the table!
symbiont
3 years ago
Don't the legs get in the way of chairs, vacuums, and stuff?
dpmakestuffsymbiont
Reply 3 years ago
No more than a desk with filing cabinets or your kitchen table..
ggarnierdpmakestuff
Reply 3 years ago
Could the inner leg of each of the four pairs be made vertical to reduce chair/knee interference?
eng_Andy
3 years ago
When I saw the first pictures and mentions of nomadic furniture, I thought those legs were going to fold or disassemble and fit inside the table's form factor for transport. Using glue seems like a bit of a let-down. If anyone makes a barrel-nut & bolt version of this I'd love to see it.
Rockhead82
3 years ago
I have longed for a Campaign Desk ever since I saw the reproduction of Stonewall Jackson's at the VMI* Museum http://www.vmi.edu/VMI_Museum/13087/ some 15 years ago.
Alas, the $4,695 price + s/h dissuaded me.
But now that I have seen this - I love its simplicity and the fact that I** can build it.
Thank you so very much for posting this beautiful project.
S/F
DS
* I am a VMI Alum
** Okay, so I can build it with help from several friends. :) I have Parkinson's from A-Orange.
Andrew Sleigh
3 years ago
I just discovered this book about campaign furniture which might be interesting for those who want to know more about this style: http://lostartpress.com/collections/books/products/campaign-furniture
MooCowandPinkie
3 years ago
Wow, this is a sophisticated, functional AND SLEEK table. I love it. Great job! Thank you for sharing.
Gadgeman87
3 years ago
THAT is a nice desk! Well done
wrsexton
3 years ago
OUTSTANDING! And true to the original intent! Very well done! Look forward to seeing you interpret other classic pieces.
ehawkins
3 years ago
What an elegantly simple and functional piece. Thank you.
CraftAndu
3 years ago
Awesome build, I love it!
dtextor
3 years ago
Beautiful and simplistic. You have my votes! Having read all the Sharpe Novels by Cornwell I feel I really have to build something similar, albeit smaller. It would go very well alongside an old school field cot for creative naps.
old-folding-camp-cot-WWII-vintage-wood-canvas-army-cot-portable-field-gear-camping-bed-Laurel-Leaf-Farm-item-no-s81248-2.jpg
josh
3 years ago
Wow! I like this project. I may have to make myself one!
everbret
3 years ago
Very elegant and neat. I might just have to try this one.
SirBritton
3 years ago
I really like the saw horse legs on this table. It really adds a lot of character.
