Camper in a Box
201,679
1,079
44
About: Tinkerer from childhood on. After my retirement, together with my wife, fully committed to creative production. I prefer simple solutions for non-existing problems.
DIY Camperbox for a mini MPV
With the Camperbox you can make within minutes a mini camper from a mini mpv. The camperbox has all the ingredients for enjoyable camping. You can sleep in the car on a foldable duo bed. So, passing the night in a city or in the wild is no problem.
Making the box is fun and using it is even better. Just with common tools and some wood- and metal skills you can do it; provided that you have a suitable car. With this Instructable I hope to encourage you to make your own camperbox. Not much space is needed. I made the box on a surface of 10 square foot (10 sq. ft. atelier). In an open veranda all the building was done. No workbech is needed. I used only a small table with a vise. So, minimal conditions for maximum results.
Video
Features:
- A kitchenunit with gas cooker, gas bottle and space for pots and food.
- Jerrycans with tap, a kitchen sink, space for plates cutlery and cups
- The lid of the box can be folded down as kitchen table.
- A 12V diy fridge and a 12V powerunit with 3 sockets and 1 USB port.
- Storing space for a first aid box, pull rope, lamp, oil, air pump, etc.
- Storing space for 2 foldable chairs and a foldable table.
- A foldable bed soil of 1.90m by 1.12m. The matress is 2m by 1.20m.
- The Camper Box size is 1.12m wide x 0.7m deep x 0.40m high.
I drive a Renault Kangoo from the year 2001. It's family from the Citroen Berlingo, Volkswagen Caddy, Fiat Doblo, Ford T Connect, etc. The idea of a camperbox is not new. You can buy this kind of boxes for between 1500 and 3000 euro by different companies through Europe. There are also private persons making there version, most without building plan. This 'Camper in a Box' costs about 200 euro, exclusive content; cooker, fridge, chairs, etc. Everyone can buy that equipment depending money and taste. You can freely customize size and partition of the box. It took me about 2 weeks to make the camper box but this includes the making of a video, foto's, and a step by step building guide.
Step 1: In the Beginning
A flightcase construction is strong, light and easy to build. In the beginning you need to measure the right dimensions of the camperbox. Do you have an other mini mpv; dimensions can differ. This project shows more the construction steps and the way the case is put together. I made the box of lightweight birch multiplex board and alluminium angular profile. All is nailed together with pop rivets. The back and front side, the left and right side and all the partitions are placed between the top and bottom board. That is easy to measure and to construct. Sawing the board I left to the professional of the diy market. Take care inside the box I use different thicknesses board. Put first bottom, left, right and back side together. Then make all the partitions with kitchen devices. All is open and easily accessible. Next make the top side and then the trunk lid at the front side. The cuttingplan pdf for download.
Step 2: Camperbox Construction
Cutting aluminium profiles is precision work. Use a pair of compasses, square, level, scribing iron, caliper, big and small metal saw, a course and a fine metal file, blind rivet pliers, electric drill and jigsaw. Pre-drill first the holes in the alu strips before drilling in the wood. Round the sharp edges with a file that is save and looks nice. Foto's and video showing the process clearly.
Step 3: The Kitchen Drawer
The sides of the kitchen drawer are of 10mm thick multiplex. Make the width of the drawer according to the width of the gas stove. Use construction glue with screws for strong connections. Connect the tray guides first on the side's and then fix the drawer in. It is a nice sound coming from good rolling slides. Keep some space above the stove for a support beam. Having a wind shield is more comfortable and save. Check the pressure regulator and the flexible gas tube before installing.
Step 4: Making the Layout
The question is; what is important to carry with you in the camperbox? That is a question of personal taste and needs. So, you have to buy first the parts before making the lay-out. In my case I choose for 2 jerrycans with tap, 2 plastic bowls for cleaning and washing, 2 chairs and a small table. Because the camperbox is deep, you can easily put 2 jerrycans and bowls behind each other. The chairs I had to shorten a bit. The storing space behind the fridge is accessible from the back, as the rear seat is folded down.
Step 5: The Fridge
I decided to make diy fridge with door and good isolation. It is fun to hack a consumer product and customize it. I took the top of a 12V cooling/warming box and placed it in the back of the fridge. Styropor foam at 4 sides and at the door and you got a 'real' fridge. Only the sound of the closing real fridge door is missing. Important is the beer stays cold on hot days! I covered the styropor with thin isolation material. This is easy to clean by liquid spillage. Important is the outlet for the hot air from the cooling unit. I made a tube to an opening at the right side. A foto shows below the cooling unit the black tube. First you have to cut a hole that fits the unit.
Step 6: The Bed Base
The bed base are 2 boards between aluminium T- profiles. You have to cut the 3 pieces for each side. Connect first the piece's on top of the box, then the first bed soil board of 2 by 4 feet can be made to measure and folded out. Then the second board can be installed. When you watch the foto's and video you see the folding system. It was the part what took most of the finding-out time and was made within an hour. It is good to round sharp edges from wood and alu profile. A flat air mattress on top of the bed base is the last I can use. The bed base is supported against sag by strips. The construction uses simple methods to save weight by using thin as possible board.
Step 7: Conclusion
The only part missing are the curtains to blind the windows when sleeping. This is for later. For a good and save air refreshment during night I placed an air in-outlet dome on top of the car. With an electric fan mounted at the dome more fresh air can circulate. The test with the camperbox was positive. When passing the car you even don't see the box is in. The total back window is free even with some luggage on top. My wife followed 'the making of' with interest. Also the process of publishing an Instructable she followed over the last days. I got a good response of friends who like to have one but missed an appropriate car. Using a tent in combination with the mini camper is recommendable, it extends the camp space and protects for sun, rain and wind. I think I keep this box in the back of my car, that feels now like RV-ing all the time. Any place where my car can come is a potential camp place. Travel light; use a camperbox.
    • IoT Challenge
      IoT Challenge
    • Classroom Science Contest
    • Party Challenge
      Party Challenge
    44 Discussions
    Anne-SophieC
    6 months ago on Step 1
    Hello! It seems the cutting plan in pdf isn't available. Do someone has it?
    Thanks in advance
    IamWeAnne-SophieC
    Reply 6 months ago
    Sorry, I deleted my Dropbox. You can stretch the second photo and read and print all the sizes and measures.
    1vevercka
    7 months ago
    Hi ,
    thanks for the excellent instructions. I'm wondering if you screwed up the main box into the floor for security reasons? I have a Berlingo 2006 and considering about the conversion according to your instructions. Thank you very much!
    Syavas
    11 months ago
    Thanks,
    rkelley7
    1 year ago
    Pop rivets? New to me. Beautiful job.
    HaoliJ
    1 year ago
    Really interesting and informative. Thanks for sharing
    techitone
    1 year ago
    Great work. Going to make one for my VW T5 Van ;)
    AutumnM23
    2 years ago
    Your camper is wonderful! Its very inspiring. I am trying to design my 1997 MPV into a camper van. I was wondering what the height of your sleeping area is? Would you recommend that height?
    Thanks so much!
    Autumn
    Rensina
    2 years ago
    Fantastic design!! I live in Australia and have been looking for a design for the back of my Land Rover Defender (ex Australian army with canvas canopy). I love your design. Thank you. I am going to make it. Rensina
    ukwanderer
    2 years ago
    Great instructions. I use a similar idea without sleeping platform. It was made in a hurry to fit in my Landrover Discovery. That was about 10 years ago. It sat outside under a tarp for three years and I used it for a recent holiday in Scotland. Mine was painted in a very practical waterbased black paint. Its an easy paint to add to whenever it needs tidying up.
    I used it last week in the back of a citroen Picasso. The only changes I made were two drawers at the bottom for cutlery etc. I see under your bowl that you do not have a shelf. This Is easy enought to add too provided you have the height above bowl to waterbottle. Cut a piece of plywood to fit in space. Use your brilliant idea with the aluminium angle to trap it down. Might need to put a couple of coins to make spacers. These you can take out after riveting. Could cut a couple of holes near the front corners . These are for putting a finger in to pull shelf out.
    You can get bowls that collapse for space saving.
    I also use a duracell inverter for charging phones or laptops whilst driving only. Add on a 12v kettle even though I have two burner gas rings and a also a 12v lunchbox oven and your good to go.
    Marty2b
    2 years ago
    Brilliant! Just bought a 2002 Berlingo 2l hdi. Will definitely be doing this. Many,many thanks and for the terrific video.
    burntbob
    4 years ago on Introduction
    Awesome instructable and loved the video and the musical background. very practical ideas
    runner406
    4 years ago
    that is awesome
    steamdroid
    4 years ago
    Great job! I googled Maastricht and believe it is a beautiful place. Enjoy!
    janw
    Nice build, Berto! I have the same type of MPV and if I didn't had my VW T2 camper, I surely would build this as it is super practical.
    IdahoDavid
    Well done and very adaptable for different kinds of vehicles. This would work for a number of US-made SUVs and crossovers.
    Megazord
    This is awesome ! I'm building my camperbox for a similar car and your tutorial gave me a lot of ideas. Thanks !
    IamWeMegazord
    Reply 4 years ago on Introduction
    Thanks, you appreciate the project. Spreading ideas is more important than a precise reconstruction. Success with your camperbox!
