Capturing the Solar Analemma With Pinhole Photography
7,502
92
18
This Instructable is about capturing the figure eight shape traced by the sun in the sky over the course of a year. This is called the solar analemma. The figure eight is caused by two things. First, the Earth has a tilted axis. This causes the sun to appear higher or lower in the sky throughout the seasons. Second, the Earth's orbit around the sun is not perfectly circular but slightly elliptical. This causes the sun to shift slightly east or west in the sky at different times of the year. Put the two effects together and you get the figure 8.
People have traced the analemma for centuries by noting the position of the shadow of a pointer or the projected image of the sun at the same hour each day. More recently, people have used film and digital cameras to record the sun's position and then composite the various exposures into a single image. Both the historical and modern techniques have the disadvantage of generally requiring a person to be at the same place and time each day, or at least every few days at a minimum, over the course of a year. This is problematic for most of us!
I had been taking solargraphs, pinhole pictures showing the streak of the sun across the sky each day for extended periods, for some time when I ran across a technique for using the pinhole camera to capture a solar analemma. What you see here is a record of my attempts. I assume the reader is somewhat familiar with the concept of pinhole cameras and solargraphs. If not, please check out this link for a quick intro to the topic.
Step 1: Capturing a Solargraph
With most pinhole solargraphs, the camera is fixed in position for days, weeks or months and left open 24/7. The daily track of the sun across the field of view makes a streak on the photo paper inside the camera. At the end of the period, the paper is removed in a darkened room and scanned on a flatbed scanner. The intense sunlight changes the chemistry in the photo paper, leaving a faint visible negative image. After scanning, you invert the colors and apply a strong contrast stretch to bring out the image. The paper chemistry reacts differently to different temperatures, humidity, and light levels. The colors seen here are not added; they are what came out of the original image after inverting and stretching.
Step 2: Creating the Analemma Camera
My analemma camera is very simple. It's just a long box made of 1/4" foam board. Inside is a half cylinder focal plane in the "back" of the camera big enough for a standard 8"x10" piece of black and white photo paper. I like matte paper as it seems to be less prone to stray reflections bouncing around inside the camera. As you can see, the inside is painted flat black. In the front of the camera, offset high, is my pinhole. You need to consider how high in the sky your summer sun will get and place the pinhole accordingly so that the summer sun will project through the pinhole and still hit the photo paper. If you live in the tropics (between latitude +/- 23.5 degrees), your sun will reach or go past vertical. In that case, you'll need to angle your camera back to capture the whole image.
What makes this camera different from a standard solargraph camera is the rotating mask on the top. I used a cheap electric clock with an AC - DC adapter / battery to power it. Most of the time it runs off the house current but if there is a power outage the rechargeable battery keeps it running. I made a disk of light card stock and marked it in 5-minute intervals on the back so I could keep rough track of the time of day. starting at the noon hour, I cut a notch that was 2-minutes wide. I glued the mask to the minute hand of the clock so that once an hour the sweep of the minute hand carries the notch in front of the pinhole and creates a 2-minute exposure. I had to play with the balance of the mask at first since the cheap electric clock wasn't strong enough to turn it with a slight imbalance in its weight distribution.
Step 3: Considerations on Pinhole Aperture
The analemma camera requires a very wide field of view to capture the full vertical sweep of the sun's path over a year. I use a bit of an aluminum soda can with a pinhole punched into it. My first attempt, however, didn't account for the thickness of the aluminum relative to the size of the hole. As you can see in my image, I only caught the bottom of the analemma because the thickness of the aluminum cut off the higher-angle light rays. For my second attempt, I sanded the aluminum very thin using fine sandpaper. It is much more like aluminum tissue now and very fragile. However, it gives a much wider field of view.
Step 4: Waiting...
Once you have your camera built, loaded, sealed and placed (I set mine in a south-facing upstairs window in a spare bedroom), it's a waiting game. I started my image on New Year's Eve 2015 and let it run for a full year, opening it up on New Year's Eve 2016. The hardest part of waiting was trying to make sure the camera didn't get bumped during house cleaning!
Step 5: Opening Your Camera
After the year's time, I opened my camera. The image here is what the photo paper looked like as it came out of the camera. Each figure 8 marks the position of the sun at a particular hour of the day. Each dot is the 2-minute exposure at that hour. On one of the equinoxes i stopped the mask in the open position to capture the full streak of the sun on that day. You can see a scatter of points in the lower part of the figures where my clockworks malfunctioned and didn't keep correct time. After a couple of weeks I noticed the time was off and reset it for the rest of the year. The tallest figure is the noon hour. The camera flips the image so the right side of this negative represents the dawn hours from 7:00 A.M. onward. My final image takes the negative, inverts the colors and flips it right to left. I thin applied a strong contrast stretch to it. I captured 9 complete or partial analemmas in this shot.
Step 6: Final Thoughts
I hope this Instructable inspires you to try your hand at making a solargraph and ultimately to try and capture an analemma.
Some considerations to keep in mind: You need someplace where your camera can see the sun, won't be disturbed for a full year, and is weather protected. Having a way to check the mechanism periodically is helpful to ensure you don't waste much of a year on a broken clock drive. You might consider doing a partial exposure, say a month or so, to check the process and make sure your camera is working correctly before you go for the year-long effort. No matter what you end up with, have fun with it! And when someone asks you how long your exposure was, you can honestly tell them it's on the order of 17,500 minutes!
Space Challenge
Runner Up in the
Space Challenge
    • Tape Contest
      Tape Contest
    • Trash to Treasure
      Trash to Treasure
    • Arduino Contest 2019
    18 Discussions
    makendo
    10 months ago
    spectacular image, brilliantly conceived
    SteveR295BernWozny
    Reply 10 months ago
    Ilford matte B/W, IIRC. Regardless of the brand, I use matte finish. I would suggest playing with "normal" solargraphs to test out various papers if you want to. Even a couple of days would show streaks and give an idea of how sensitive each paper is.
    jmacuk
    10 months ago
    Nicely done! Can see this as a great project for either astronomy or photography classes!
    SteveR295jmacuk
    Reply 10 months ago
    I agree! I'll be teaching an astronomy elective next spring at my high school and we'll do at least basic solargraphs to show how the path of the sun changes through the season.
    Vonkiedoël
    11 months ago
    Take that, Flat Earth Society!
    Steve, it would be nice to know how far away from the equator your observations were taken and in which hemisphere. Maybe then someone from a similar latitude, but opposite hemisphere can also do it and compare it with your image...
    Very cool project, man.
    SteveR295Vonkiedoël
    Reply 10 months ago
    I'm in the northern hemisphere at about 38-39 degrees north latitude. The camera was tilted back just a smidge, maybe five degrees?
    jrobb6
    10 months ago on Step 6
    Very cool. It looks like you can get an idea of cloudy days, too. I once worked at a museum that painted the figure-8's on a parking lot cast from a shadow of the top of a flagpole, except they calculated the analemma and painted it without waiting for a year. --- So, one slot at noon (on the hour hand) would give you just one figure 8 for the year, Yes? To see many 8's across as you illustrate, you need the slot on the minute hand as you said. I could also see 2 slots on opposite sides of the minute-hand disc to give even more 8's. Great project!
    SteveR295jrobb6
    Reply 10 months ago
    Yes, the mask pasted to the hour hand would give you just one analemma at that hour. Multiple notches with the mask on the minute hand would give you more closely spaced analemmas. However, you have to be careful unless you want them to overlap. I think that even 30 minutes is too close.
    obillo
    10 months ago on Step 2
    "figure eight shape traced by the sun" ??? I thought it was the earth that moved. Now much confused.
    SteveR295obillo
    Reply 10 months ago
    The Earth is moving. What you're seeing is the apparent position of the sun in the sky at that hour throughout the year. The tilt of the Earth's axis and it's non-circular orbit around the sun add up to make the apparent solar position shift throughout the year.
    imprettymuchaloser
    Question 10 months ago on Step 5
    Are there any special considerations when opening the camera? I'm not a photographer, but I'd hate to spend a year on this and then find out I ruined the whole thing with the wrong type of light bulb or something.
    1 answer
    SteveR295imprettymuchaloser
    Answer 10 months ago
    The main thing is to be in a dimmed room with your scanner ready to go. The image does not fade immediately and can stand some degree of room light but any extra light will progressively degrade the image over time. I get my scanner all set up, dim the lights, open the camera, and scan it quickly. Then I wrap the paper negative in a light-proof wrapper for longer storage.
    LotfiB1
    10 months ago
    If you are looking for 8 shaped curves, I can send you C/C++ code that computes such curves for sundials: http://baghli.com/cs/
    Matlek
    11 months ago
    Excellent project!
    EdM63
    11 months ago
    awesome
    Gadisha
    11 months ago
    Wow the result looks so cool! Thanks for sharing.
