Car Alternator to Cheap Motor
30,141
49
21
Hi,
This is my first instructables.
Because of my English i put more pictures and less words.
In this instructable i will try to explain how to convert car alternator to motor.
Supplies:
Step 1: Material Required
You will need:
- old car alternator
- servo tester
- Brushless ESC speed contorler
- 12V Battery
- 5V Power supply (old PC supply or some DC step-down)
Step 2: Disassembling
This is Bosch alternator from German cars in 1980.
First disassembl regler (two screws).
Then unscrew 4 screws from front (pulley) side.
After separating Stator and Rotor remove stator and diodes from housing (3 screws).
Cut off diodes from stator.
Step 3: Modifications
Isolate brushes.
I made this with angel grinder.
And solder some wires on both brush.
Step 4: Wiring and Assembling
I use PC power supply 5V for rotor, and car battery 12V for ESC (stator).
You can also use 12V on rotor, but motor will bi slow and spent 3 amps on rotor.
After wiring assemble everything back except diodes.
Some better ESC have switch for changing direction, but you can do manually switching two phase.
And that is all.
And one more think.
Please be careful, this is a powerful
motor and it can hurt you.
      • Woodworking Contest
        Woodworking Contest
      • Fandom Contest
        Fandom Contest
      • IoT Challenge
        IoT Challenge
      21 Discussions
      marxmellowAbangP
      Answer 2 months ago
      each of the three phases has two coils in series. The fourth wire comes from the center.
      ivosusakAbangP
      Answer 8 months ago
      Hi,
      Six wires comeout of the alternator or 6 coils?
      ShararrA
      3 months ago
      Hey, hows the max speed . does it have enough torque to run a bicycle . can i run it on more voltage
      danyro
      4 months ago
      i tried but failed, request you to assist
      SammyS46
      5 months ago on Step 4
      Pls I need someone who can convert it and send it to my country 'Nigeria'. I will pay.
      Call me. +2348131359270
      WalterT29
      Question 7 months ago
      Hey there, I have a question. I opened up my alternator and the rotor brush connection is typical, but my stator wiring has 4 wires coming out and they are all interconnected. All 4 have continuity among them. How should I wire this? Thanks in advance.
      Al AmineB
      Question 10 months ago
      Hello I don't know how to isoleate the brushes and remove links , can someone please explain in detail , or show image please
      I've read about people getting 1000W or more power from alternators modded like this. This is really a good idea for obtaining cheap motors for electric motorbike conversions.
      In idle speed consume 1,6 amps.
      When i put some load, speed little decrease and it can consume up 10 amps.
      Probably more, but my ampere meter can measure max 10 amps.
      1uglyman
      1 year ago
      I'm trying your experiment. My alternator has 4 wires,1 ground / neutral ( I believe).
      What would I do with the 4th wire?
      Thanks
      PS1181uglyman
      Reply 1 year ago
      Think of an alternator as three different phases. (3 coils)
      They can either be wired in delta or y (what the author calls "star") configuration. In the y configuration, you can have a fourth wire, which is the common center point. In an ideal world this should be 0 volts and is a no-connect.
      You'll need to use a multimeter to find out which one that is. The common point node should both:
      1) Have the least resistance to any other wire.
      2) Have the same resistance to all other wires.
      From there, the controller is smart enough to tell the difference.
      More info:
      http://modelaviation.com/inside-esc
      1uglyman
      Question 1 year ago on Step 2
      Thanks
      HarryH49
      1 year ago
      Hello, have you considered to replace the rotor coil with permanent neodymium magnets ?
      ivosusakHarryH49
      Reply 1 year ago
      Hi Harry,
      Well, on rotor coil i adjust torque and speed.
      Permanent neodymium magnets are excellent idea if we use alternator like alternator.
      In that case we do not need power supply to start generate current.
      MthokozisiN1
      1 year ago
      Hello, thank you so much. I managed to make the conversion but I was wondering if i can increase the power/torque by increasing the field voltage or current or increase the stator voltage to say 15 - 18 vdc as I'm using a 2-6s 30A esc.
      MthokozisiN1
      1 year ago
      Hi
      I made all the connections that connections using an esc( hsn30a by dys) but the alternator wouldnt run.
      ivosusakMthokozisiN1
      Reply 1 year ago
      Hey, it will work.
      Which voltage you use for rotor? Can you send me few photos on email ivosusak@gmail.com that i can see, and a bit description.
      gm280
      2 years ago
      Reversing the alternator into a motor is a nice project. And because there are no magnets inside, you have to make them via the windings. But it then becomes a electric motor. Nice project.
