Caramel Rose Apple Pie
5,026
91
20
About: Hello and Welcome to In the Kitchen With Matt. I am your host Matt Taylor. My goal for the show is to teach you how to cook really good food at home for cheap. Eating out everyday can get expensive, but it d...
In this Instructable I will show you how to make a caramel rose apple pie. This creative apple pie recipe is pretty awesome and tastes so yummy. Want to learn how to make an apple pie? Why not turn up the creativity a bit and make it a caramel rose apple pie! :) I am sure you can impress your friends and family with this amazing pie. It is easy to do, if I can do it, you can do it, let's get baking!
Don't forget to follow me and check out my other posts!
If you like this please consider voting for it in the Pie Contest. :)
If you have any questions or comments leave them down below and I will get back to you as soon as I can.
Follow the steps below or watch the video tutorial or do both! :)
Step 1: Ingredients/Tools
Ingredients:
  • Water (about 2 cups)
  • 1 lemon
  • 4 large apples (I like to use Granny Smith, a good tart apple works great)
  • peeled and sliced thin
  • 1/2 cup brown sugar (100g)
  • 1/2 cup white granulated sugar (105g)
  • 1/2 tsp. of ground cinnamon (3g)
  • 1/2 tsp. of nutmeg (3g)
  • 1 pie crust (homemade or store bought)
  • 1/4 cup of heavy cream for caramel (60ml)
Tools:
The above links are affiliate links, clicking on them helps me to make more instructables. :)
Step 2: Lemon and Water
First let's squeeze out the lemon juice from our lemon and put it in with the water. I am using a manual juicer but you can use your hands too to squeeze the lemons. Just make sure to keep the seeds out of the water. :)
Step 3: Peel and Soak
Now let's peel those apples. I am using Granny Smith apples, but any tart apple will work. Use your favorite traditional apple pie apple, or experiment with other apples. Place the peeled apples in the lemon water. The lemon water will prevent the apples from turning brown.
Step 4: To Slice or Not to Slice
Now we need to slice up those apples. Here are a couple of methods I use. Use your knife and cut around the core, if you used a corer, skip that step. Then cut your apples thinly, no more then like 1/8th of an inch thick. If they are too thick they will have a hard time bending, but don't worry about it too much. really thin ones are good for creating the center rose. Another method is to use a mandolin slicer. If you don't core the apples first after wards you can dig out the core with a melon baller, but that takes more time do it that way. Mandolins are great for keeping every slice about the same thickness. Then place the slices of apple back in the lemon water until you are done with all the slices.
Step 5: Sugar and Spice Makes Everything Nice :)
Now in a medium bowl add your brown sugar, white granulated sugar, ground cinnamon, and nutmeg, then use a fork or whisk and mix them all together. If you don't have brown sugar, use all white sugar.
Step 6: Drain and Mix
Next let's drain our apples. Then pour the sugar mixture on top of the apples and with nice clean hands mix the apples in with the sugar until they are all coated. Let the apples sit for 30 minutes. This will allow a nice liquid to form on the bottom which will be the base for our caramel. :)
Step 7: Prep the Pie Crust
Now let's add our pie crust to a 9-inch cake pan or use a cast iron skillet. It's hard to use a normal pie pan for this because the walls are sloped too much. Then poke holes in the bottom of the crust with your fork. I am using a store bought pie crust for this but you can use a homemade crust. I already have an instructable that shows you how to make a homemade apple pie and pie crust from scratch, which you can find here:
https://www.instructables.com/id/Homemade-Apple-Pi...
After you are done with the holes, place the pie pan and crust in the fridge to chill, while we wait for our apples.
Step 8: Squeeze Them Apples!
After our apples have sat for 30 minutes let's grab a handful of them and squeeze the life, I mean juice out of them. Then place them in a separate bowl, leaving you with one bowl of awesome yummy sugary apple flavor liquid, and one bowl with fairly dry flimsy apples slices.
Step 9: Place Those Slices
Now let's place the apple slices in our pan, starting at the far outside of the pie and working towards the middle. Make sure to overlap the slices a little bit. Then roll up one or two apples slices and form the rose center piece. If you want to get extra creative leave the peel on the green apples and then use a red apple for the center....ooh that would be amazing. :)
Step 10: Fold, Cover, Bake
Now let's fold over the edges of our crust. It isn't necessary but I like to do it. Next cover the pie with some foil and bake the pie in a preheated oven at 375 F (190 C) for 30 minutes. Then take the foil off and bake for another 10 to 15 minutes, until the pie is golden brown on the edges of the crust and the apples slices will be slightly brown on the tops as well. Hurray we are done with the pie! Now let's make our caramel sauce.
Step 11: Pour, Boil, Reduce, Cream
At our stovetop with the burner at medium heat let's add our juice to a sauce pot. Let the mixture come to a boil and let it boil for 10 to 15 minutes until it reduces by about half. Then add in your heavy cream. Stir it well, then turn off the heat and let the caramel cool. It will be too runny right now, but will thicken as it cools.
Step 12: A La Mode? Yes Please!
Now take your caramel sauce and pour it over the top of your pie. You will only wind up using about 1/4th of it and can save the rest for toppings. Serve a slice with some ice cream and drizzle some caramel sauce on top. There go a creative way to make an apple pie. Enjoy! :)
Step 13: Video Tutorial
Now check out those steps in action by watching the video tutorial. :)
Pie Contest
This is an entry in the
Pie Contest
    • Jewelry Challenge
      Jewelry Challenge
    • Pie Contest
      Pie Contest
    • Fat Challenge
      Fat Challenge
    20 Discussions
    attosa
    22 days ago
    I made one of these last year and it looked so dumpy compared to this! I'm absolutely compelled to retry just to make mine half as beautiful as yours!
    thepoisonivy
    27 days ago
    This is beautiful!! Your instructions are wonderfully simple and that makes me want to make this!
    EmersonN6
    Question 27 days ago
    This is amazing... I'm just wondering what is Heavy Cream... I was not able to find something similar in my country... :-)
    relbattoEmersonN6
    Answer 27 days ago
    You probably DON'T have light cream, half and half, or coffee creamer either... .... not everything in this country understands cooking and tarte Tattan is at the head of the list... I understand that in California where Gluten is viewed with horror, you can hold up a liquor store with a bagel...I bet you can get real cream, which lets you stand a wooden spoon upright for a bit, and would consider anything less as a cheat. bottled water,sells for more than gasoline here.
    hahaha relbatto! I used to live in California, I moved in early 2006, but my parents still live there. Things have changed so much there, then when I grew up in the 80s and 90s. haha
    AnandM54
    27 days ago
    Wow superb documentation and pie taste also too yummy...!!
    tercero
    4 weeks ago
    THAT is a work of art my friend. Thanks for the inspiration. Something to bring to the in-laws for Easter dinner.
    Thank you so very much!! YES Make this and bring it to the in-laws for Easter dinner, I bet it will be a hit! :)
    Penolopy Bulnick
    4 weeks ago
    That is such a beautiful pie! And caramel and apples is just the best combination :D
