Carbon-Fiber Electric Skateboard Deck
40,231
394
32
About: I'm a highschooler who is interested in technology, science, and engineering. In my spare time I work on projects that allow me to learn new skills and concepts.
Since converting a longboard or skateboard to electric will add significant weight, it is necessary to keep all of the components as light as possible to begin with. Carbon-fiber is an ultra-strong, ultra-lightweight composite building material, and it can be used to significantly increase the strength, and decrease the weight of a skateboard deck.
While it might sound daunting to work with carbon-fiber, it is actually very easy with some prior research (it is very similar to fiber-glassing). This deck has plywood supports for the trucks, and an integrated compartment for the electronics, which adds structural support and increases the clearance under the deck.
Additionally, by making your own carbon-fiber deck, you will be saving yourself a lot of money! An already-made carbon-fiber deck for electric skateboard will set you back about $500! If you buy in bulk, this deck costs only about $75, not including labor.
Step 1: Watch the Video Tutorial!
Watch this quick video to learn more about the carbon-fiber deck, and the electric skateboard that it was used for!
Step 2: Build the Foam Core
The first and most important step to making a carbon-fiber skateboard deck is to make your entire deck out of some cross-linked PVC foam. This stuff is far more durable than regular foam, and it going to be necessary to create a light-weight deck (an all carbon-fiber board is possible, but it is not as light).
The foam I used was scrap from my dad's catamaran project; it was 3/8" thick, and it was sold under the brand name "H100 Divinycell Plain, 6lb./cu.ft.". Thanks to fiberglass supplies for providing the materials for this project; those guys are awesome!
In order to make the deck shape, you will need to glue, sand, and carve this foam into the shape you want. The two most important features are the plywood supports around the trucks, and the two long foam pieces of foam that span the length of the deck. The plywood supports are crucial for holding the trucks (if you used just foam, the screws would rip out). The two long supporting pieces of foam (3/8" thick) make up the electronics compartment, but they also add a lot of support!
I assembled the pieces with silicone-based glue and screws at first, and then I took the screws out when the glue dried. The type of glue is not critical to the strength of your deck, since the carbon-fiber is going to hold everything in place, and provide the actual structural support (although the foam helps out a lot!).
I have attached a ton of reference pictures with this step (33). Check them out, words can't explain it as well.
Step 3: Stick the Carbon-Fiber Onto the Foam Core
Use some spray on adhesive to stick the carbon-fiber onto the foam core. I used two layers on top, and two and a half layers on the bottom of the deck (an extra little bit around the electronics compartment). The carbon fiber was this "Carbon/Basalt Dual Twill 12k 20oz 11.5'' WIDE / board building material +". It used to be sold on fiberglass supplies, but now there are only similar fabrics available. I used about 16 feet of this carbon fiber (including excess).
When you use the spray adhesive (I used some 3M drywall adhesive), make sure to get the carbon-fiber into all of the nooks and crannies. It will stretch a lot, but if you do it carefully (wear gloves) it will retain the weave. Again, there's lots of reference pictures in this step.
Step 4: Apply Epoxy
Use a stirring rod to mix up some generic two-part epoxy. The more you mix, the faster the epoxy tends to cure. You are going to need to use about the same weight of epoxy as you have carbon fiber, in order to cover the top and bottom of your deck using a squeegee. Make sure to use plenty of plastic to keep your work-area clean. Do not soak the carbon-fiber, as the vacuum bag will help dissipate the epoxy evenly throughout the deck.
Step 5: Vacuum Bag Until the Resin Cures
After you have distributed epoxy over the surface of the deck as evenly as possible, place the deck in a strong vacuum bag for at least 24 hours. We used a converted air-compressor to make our vacuum, but people have had good results with a manual vacuum pump as well.
Make sure you spread the bag around the deck as evenly as possible. You need to make sure there is good contact on all surfaces and bends, and you don't want too many "epoxy lines" forming after the resin cures. If you want to reuse your vacuum bag, a good tip is to place some paper towel near the suction line/adapter. It will stop any epoxy from being sucked into your pump/opening.
After the resin cures, take the deck out, use a jigsaw to trim the excess, then sand down the entire deck. Don't worry if it doesn't look shiny, you will need a clear coat and polish to make it shiny.
Step 6: Make the Lid
Now that your deck is in it's rough shape, I suggest you make the lid for the electronics compartment before applying a layer of clear coat to the deck (if you are making an electric skateboard, not if it's a regular deck).
In order to make the lid, you must fill the compartment with foam. This doesn't have to be the high-strength foam used for the foam core, it can be regular squishy foam as well. Once you have filled the compartment with foam, sand it down until it is flush, or slightly above the sides of the deck.
Then comes the carbon-fiber again; put a layer of thin plastic on top of the electronics compartment and foam, place 2-4 layers of carbon-fiber and/or fiberglass on top of the plastic, then apply more epoxy (1:1 ratio of weight of carbon-fiber to epoxy), and vacuum bag until cured. This method works with many different composite cloths, and it is similar to vacuum forming plastics.
After the lid is cured, carefully cut it to size using a jig-saw and sandpaper.
Step 7: Drill the Holes/Apply Griptape
The last step are the finishing touches. In order to make your deck and lid shiny, you will need to use fine-grit sandpaper to sand everything down, and then apply several layers of clear coat (I got mine from Home Depot, any generic spay-on clearcoat will do).
Additionally, if your deck does not come out as smooth as you would like it to, you can always sand the imperfections and evenly spread epoxy onto them. This will level out your deck.
In order to hold the lid down, you will need to drill holes through the lid and into the deck. I used metal threaded inserts, and used epoxy to hold them inside the deck. Then it was a matter of attaching a rubber/foam gasket made out of sticky foam to the lid, then securing the lid to the deck with bolts.
You will also need to drill holes for the trucks with a drill, and apply your choice of griptape!
Step 8: V6.0 Fiberglass Deck
As you might have noticed, there were pictures of two decks throughout this Instructable! That's because one deck was covered in carbon-fiber, and the other was covered in fiberglass! The steps to working with carbon-fiber are really similar to the ones for working with fiberglass!
While the carbon-fiber deck is cooler, stronger, and lighter, the fiberglass deck is much cheaper, and I will be using the fiberglass one for my v6.0 electric skateboard! You can see from the images that the fiberglass board has plenty of flex, while the carbon-fiber board has next to none!
You can also use different types/style of fabrics for your build. The cloth above is a type of fiberglass and can be used for decorative purposes!
Summer Fun Contest 2016
Grand Prize in the
    • Trash to Treasure
      Trash to Treasure
    • Gardening Contest
      Gardening Contest
    • Tape Contest
      Tape Contest
    32 Discussions
    smcneese
    1 year ago
    Vlad, another great project!
    I plan on building a carbon fiber deck for the electric skateboard I built my
    son following your original project. Did you do both layers of carbon fiber on
    both sides at the same time or one layer at a time putting it in the vacuum bag
    and letting it dry between layers? If both layers were done at the same
    time did you spray glue between the layers or put a layer of cf and then thin
    layer of epoxy and then next layer of cf and another thin layer of epoxy?
    Also, any reason you didn't wrap the edges of the board instead of pinching and
    trimming at the edge?
    Thank you,
    Steve
    AkiK8
    1 year ago
    What motor are you using?
    respy06
    2 years ago
    can you link some files for the 3d printed spacers?
    ThomasN62respy06
    Reply 2 years ago
    You can get spacers that are almost the same from http://www.enertionboards.com/
    dizzyeskimos
    2 years ago
    Are there any starter kits for carbon fiber and a vacuum bag that you would recommend, or fiber glass too?
    Kinnishian
    2 years ago
    The type of foam used is harder to source than others- do you think you'd find regular pink EPS acceptable? I assume almost all the strength comes from the CF skin, but I could be wrong.
    Any tips for cheap sourcing of carbon fiber and fiberglass materials? I've never found a good source.
    Scollins055Kinnishian
    Reply 2 years ago
    I don't know much about sourcing, however I do know a little about the core material. If you are looking for strength you want to go with a material that is strong in compression. Which means it doesn't squish easily. I would suggest going with something other than EPS foam but I have never tested it as a core material. Honeycomb nomex, for example is what aerospace companies use in their products but you shouldn't have to go that far. Some denser foam like EPO should work
    KinnishianScollins055
    Reply 2 years ago
    Perhaps I would be fine with just some compression material near the center of the board, where the edges should have less issue with buckling or anything. Good point there I hadn't though much.
    To be honest I was thinking of XPS not EPS, that was a mistake. EPS is fairly soft, XPS is soft but not as bad.
    Honeycomb materials are too pricey for me :P:)
    skrubolKinnishian
    Reply 2 years ago
    XPS = eXtruded Polystyrene (pink or blue wall board insullation) and EPS = Expanded Polystyrene? (usually white, like disposable coolers and rigid packing material.)
    comsa42Kinnishian
    Reply 2 years ago
    Like Scollins055 said, if you want strength you gotta go with a material that is difficult to compress. Pink EPS is softer than the material I used, and I wouldn't recommend trying it to be honest. The strength comes from the CF, but the farther apart the layers are, the stronger your deck will be. So if you use soft foam and it gets squished, then your deck will have less strength.
    I buy all of my stuff from fiberglass supplies down in Washington since it's nearby and cheap. I saw some of the same CF on eBay but it was maybe 1.5 times the price.
    Kinnishiancomsa42
    Reply 2 years ago
    EPS won't squish under vacuum - the only squishing after vacuuming is if the carbon fiber deforms. I am not familiar enough with CF layup, but I think really it would be OK to remove much of the interior material and compensate with thicker CF. My ideal would be to remove much of the foam core and even fit electronics and batteries in a cavity.
    Dunno, this instructable is very inspiring! I think I'll go for it in october when have more time. I was bummed that my original longboard I bought was stolen, and the replacement I couldn't bear to pay much for was noticably lower quality of a ride. Maybe DIY is the way to go :D
    Benne
    2 years ago
    Beautiful work, both the board and the instructable! I already have batteries and a SK3 motor laying around, so I should probably make one as well :).
    JedDog1999
    2 years ago
    Will you post all the electronics for this board, or is it the same as your other boards?
    comsa42JedDog1999
    Reply 2 years ago
    It's pretty much the same except the charging system. Use my old board schematics as reference, as well as my new charging system instructable!
    BerkayO
    2 years ago
    How much does it weigh?
    BTW: Great video and Instructable I hope you keep up the work !
    Tvixen
    2 years ago
    Nice project with a touch of perfection. Looks very easy to do for everyone ;)
    comsa42Tvixen
    Reply 2 years ago
    Thank you! Hope it gets others to biuld it as well!
    QuanQPham
    2 years ago
    You mentioned two layers of Unidirectional Carbon. It is clearly not unidirectional but a woven cloth. Did you have the Unidirectinal carbon underneath the woven materials?
    comsa42QuanQPham
    Reply 2 years ago
    Not in this deck, but in my other deck I used unidirectional fiberglass under the top layers; that's why I said unidirectional!
