Card Feeder for a Trading Card Machine
9,453
69
22
About: I'm a DIY enthusiasts and I like building stuff. I work with wood, acrylic, nonferrous metals, pc parts and all different electronic parts. ## If you always do what you’ve always done, you’ll always get what...
The Background
When I was young, I collected tons of trading cards, but for some years, the passion for collecting has been decreasing. In the meantime I have children and slowly but surely they also start to get interested in trading cards. So I'm back in the game. :)
Meanwhile, we have more than 10,000 cards. Most of them are from World of Warcraft, but we also have many others:
Some of our cards are sorted and protected in UltraPro 9-pocket pages and UltraPro Albums, but most of them "stored chaotically" in boxes. We tried to sort them by hand, but after a few days we gave up frustrated. Especially with these quantities, handling and administration is very laborious and time-consuming.
The Solution
A few months ago, I stumbled across an interesting article published in the MagPi Magazine Issue 71, Jul 2018. Michael Portera explained there how he built a Card Counter.
It was exactly the motivation and inspiration that I need. Which that said, I want to create a machine that can handle our trading card collection.
Some goals; Trading cards should automatically be
  • managed (Which cards do I have?, Which ones are missing?)
  • sorted (Block, Language, Set, Series, etc)
  • rated (How valuable are my cards?, How much money do I have to spend for a full set?)
  • traded (Buy and Sell)
Because of this ambitious goals, I decided to split the huge machine into 3 parts.
  1. Card Feeder - a machine which grab and transport a single card out of a card stack
  2. Card Scanner - a part where the cards will be analyzed
  3. Card Sorter - a machine which will sort and store the identified cards.
Let's do it!
In this instructable I will show you Part 1 - How to create the Card Feeder.
Step 1: Tools and Materials
Tools and Materials
I decided to create the Card Feeder out of cardboard. It's cheap and easy to handle.
Here's what I used:
Tools:
    • Cutter
    • Cutting mat
    • Ruler
    • Rubber bands
    • Scraper
    • Wire cutter and stripper
    • Screwdrivers
    • Pencil, markers
    • Sanding paper
    • Files
    • Acrylic paint and brushes
    • Hot glue gun
    • water-containing adhesives or solvent-containing adhesives.
    • Soldering iron and tin solder
    • Table saw
    Materials:
    Step 2: Prototyping
    Prototyping
    I would like to share with you my ideas, thought processes and decisions in the Prototyping and Design phase. In my opinion, this stage is the most fun part during a project. From nothing to a first idea.
    The Mechanism
    To understand the whole mechanism, I analyzed one of the best feeders that exists; a printer. It does exactly that what I need. I bought a cheap 8€ printer on eBay and disassembled it until I could take a closer look at the needed mechanism.
    I tested a lot:
    It worked perfect. To be honest I didn't expect that behavior, but even with the trading cards the mechanism was able to pull out only one card at a time.
    From my point of view the secret of the mechanism is:
    • an area which press the paper to the major roll
    • a second smaller roll which has direct contact to the major roll
    • the second and major roll are covered with rubber
    Tinkering
    It was time to copy the printer functionality. I made the 1st tests with a piece of IKEA cardboard to get a feeling for the sizes. Very simple and reduced to the feeding mechanism.
    After that I created the 2nd version with a container for the cards out of MDF. Very ugly, but it's working. While testing, I realized that:
    • I need some ramp for the cards which came out of the Card Feeder.
    • It's not necessary to have a separate container for the cards.
    In the 3rd version I switched back to cardboard, which I felt in love during the creation of this prototype. With the right tools and the right handling the material is sooooo great.
    Step 3: Design
    Design
    With the experiences from the 2nd and 3rd version and some thoughts about symmetry and equality, I created the final and 4th prototype on the computer. I've designed everything in Fusion360/Inventor and used all the built in functions like:
    • Rendering
    • Animation
    • Drawing
    I took the important measurements from the prototype with a caliper gauge and transferred them into the 2D sketch. All other measurements I made with the help of dependencies in Inventor and calculations. That's the reason for the strange dimensions. All angles and many distances are the same. The size of a Trading Card 63 x 88 mm was also a big factor in the design process.
    The basis of all further planning was the outside [2]. All other parts are oriented to it. The inside [1] is mainly for stabilization. Front [4] and back [5] prevent the cards from falling out. The ramp [3] serves as a slide for ejected cards. The cards are inserted into the machine via the top/back and placed on the card tray [10].
    [x] the numbers are references to the drawing
    Dimensions:
    • Outside 210,79 x 185,32mm
    • Inside 188,74 x 185,32mm
    • Front 73 x 84mm
    • Back 79 x 185,32mm
    • Card tray 70 x 67mm
    • Ramp 67 x 73mm
    Step 4: Basic Shape
    Basic Shape
    (You can find all pdf-files in the last step!)
    The individual shapes I had created during the design phase were printed on A3 paper. I glued them to a piece of 3mm corrugated cardboard. It is very important to apply glue and paper (scraps) on both sides. If not, the cardboard will bend. To be safe I put some weight on it during the dry time.
    I also would say (not sure at the moment) that water-containing adhesives will cause more bending that solvent-containing adhesives. Do you have here some experience?
    For a nice and clean look it is also important to distribute the adhesive evenly. Otherwise, bubbles will appear later. I used a spatula/brush to spread the glue.
    I doubled the backside for stabilization, which means I cut out two times the 3mm shape and glued them together. I also took care of the different orientations of the cardboard. A horizontal oriented outside will later be glue to a vertical oriented inside.
    After the drying time I cut out the shapes with a cutter and a ruler on my cutting mat. I worked my way through the process in several steps. Not the whole material at once!
    Step 5: Stabilization
    Stabilization
    After everything was cut out, I used my small table saw and cut some small strips out of a big piece of wood to stabilize the cardboard. These strips have to fit inside the cardboard, so they have to be very thin (around 2mm). It is also a good way to protect the corners and edges. As you can see in the pictures, I only stabilized the critical areas.
    I put them, with some glue, into the cardboard. After the glue was dry, I cut off the excessive wood with a wire cutter, so they are flush with the shape. I mounted everything together and hold it in place with a rubber band.
    For a better optical effect and additional stabilization, I filled the cardboard "holes" with some filler and sanded them. I also applied some black color to create a bit of contrast on the inside. (It is visible on a later picture)
    Step 6: Mechanical Parts
    Mechanical Parts
    Since I didn't want to disassemble the printer, I looked around for other components. I found what I was looking for in the Lego collection of my children.
    With Lego Technic components I copied the mechansim from inside the printer.
    I used a bunch of Lego Bushes and Lego Bushes 1/2 to hold each wheel or gear in place.
    The distance between the sides is determined by the width of the card tray. The 4 washers are spacers to achieve exactly this width with the axes.
    For the right pressure, between the wheels, I added two springs on the outside of the axis. Direct contact between the wheels is necessary.
    One secret and a very important part are the rubber bands on the main wheels. Without them it will not work very well. Each wheel has three rubber bands in an 120 degree angle.
    I made the card area flexible. It can be adjusted in height in relation to the major wheel. I did this with two M8 threaded rods and 4 M8 nuts.
    After that, I glued all parts together with some hot glue.
    Step 7: Electrical Parts
    Electrical Parts
    The whole Trading Card Machine will be managed by a Raspberry PI, even the Card Feeder.
    If you need some Raspberry PI basics => Raspberry PI Class
    A continuous rotation servo, which is connected to the Adafruit Servo Bonnet via a standard 3-pin female connector, will move the 40mm major wheels forward and so eject a card for the card stack. The Adafruit Servo Bonnet is mounted directly on the Raspberry PI.
    I glued a Lego 24 Tooth Gear to a servo arm and screwed everything onto the motor. The whole unit fits perfectly below the card tray. I mounted it with some hot glue. The Lego 24 Tooth Gear has contact with the Lego 40 Tooth Gear on the major axle.
    I soldered some wires to the Adafruit Micro Switch and "connected" it temporaly to the Raspberry PI. With the switch i can turn the servo On an Off.
    I connected an external 5V/10A power supply to the Adafruit Servo Bonnet terminal block to power the servo. At the moment the power supply is oversized, but it should be enough for the whole machine.
    Step 8: Coding
    Coding
    I used the Raspbian OS and the Adafruit Python PCA9685 lib to interact and control the Card Feeder.
    The Adafruit Servo Bonnet will "talk" via I2C to the Raspberry PI. Therefor I had to activate I2C in the Raspberry PI Kernel and install 2 packages.
    sudo apt-get install -y python-smbus
    sudo apt-get install -y i2c-tools
    My code is based on the Adafruit example. I used it out of the box, just implemented the Adafruit Micro Switch to turn the Card Feeder On and Off.
    Attention!
    I'm a coding noob, so there are better ways to write the code. It was good enough for my test, but I still have a lot to learn.
    # Simple demo of of the PCA9685 PWM servo/LED controller library.<br># This will move channel 0 from min to max position repeatedly.
    # Author: Tony DiCola
    # License: Public Domain
    from __future__ import division
    import time
    import RPi.GPIO as GPIO
    #import the PCA9685 module.
    import Adafruit_PCA9685
    #NEW
    GPIO.setmode(GPIO.BOARD)
    GPIO.setup(18, GPIO.IN, pull_up_down = GPIO.PUD_DOWN)
    # Uncomment to enable debug output.
    #import logging
    #logging.basicConfig(level=logging.DEBUG)
    # Initialise the PCA9685 using the default address (0x40).
    pwm = Adafruit_PCA9685.PCA9685()
    # Alternatively specify a different address and/or bus:
    #pwm = Adafruit_PCA9685.PCA9685(address=0x41, busnum=2)
    # Configure min and max servo pulse lengths
    servo_min = 385  # Min pulse length out of 4096
    servo_max = 407  # Max pulse length out of 4096
    # Helper function to make setting a servo pulse width simpler.
    def set_servo_pulse(channel, pulse):
        pulse_length = 1000000    # 1,000,000 us per second
        pulse_length //= 60       # 60 Hz
        print('{0}us per period'.format(pulse_length))
        pulse_length //= 4096     # 12 bits of resolution
        print('{0}us per bit'.format(pulse_length))
        pulse *= 1000
        pulse //= pulse_length
        pwm.set_pwm(channel, 0, pulse)
    # Set frequency to 60hz, good for servos.
    pwm.set_pwm_freq(60)
    print('Moving servo on channel 0, press Ctrl-C to quit...')
    while True:
        if GPIO.input(18) == GPIO.HIGH:
            pwm.set_pwm(0, 0, servo_max)
            time.sleep(1)
        else:
            pwm.set_pwm(0, 0, servo_min)
            time.sleep(1)
    Step 9: The End
    The End
    That's it!
    I've created a video. It's all about the Card Feeder building process. I hope you like it.
    To be honest, I would have expected a good to mediocre result at the beginning. But it's perfect. It never happened to me that either none card or more cards were fed at once. I am very surprised and pleased how well the whole thing works.
    I will use it as a Card Feeder for my Trading Card Machine. However, the principle can also be applied to other areas. Card Dispenser, Card Dealer, etc. Please let me know if you build a dealer for card or party games, blackjack machines or something else. I would like to see your ideas.
    I would appreciate any criticism, comments or improvements. Whether in relation to the Card Feeder, Photos, Skills or Writing/Language.
    I will move on to the next part of the Trading Card Machine; The Card Sorter. In my next update I will show you how I (will) built it.
    If you do not want to wait until the next update, you can see some news on Instagram.
    Thank you for taking time to read about my project!
    Have a great time.
    Servus and cu next time!
    Step 10: Attachment
    Here you can find all shapes as pdf-files. They have to be printed in an DIN A3 format.
    If you need anything else, feel free to ask!
      • Epilog X Contest
        Epilog X Contest
      • Comfort Food Challenge
      • Warm and Fuzzy Contest
      22 Discussions
      Schabenstolz
      5 weeks ago
      Great project and well documented. I'm looking forward to the next parts. :)
      theguymasamatoSchabenstolz
      Reply 5 weeks ago
      Hey, nice to hear from you!
      I am working on the second part and I hope that I can publish this year the article to this.
      What are you working on?
      cu
      Schabenstolztheguymasamato
      Reply 5 weeks ago
      Great! :D
      Its just a small project. I ordered a Mini-PCIE to USB adapter and a matching small USB stick. I would like to install it in my notebook. Possibly with an external on/off switch to save power eg. to boot the Linux Live System (Tails OS) "hidden" without a visible entry in the boot manager. A bit of a gimmick, but I didn't want to carry a USB stick around with me and booting from SD card didn't work. :x
      Good luck at the contest, you got my vote.
      cu :)
      Reply 4 weeks ago
      Sounds interesting. Share some pictures when you are finished. I would like to see it.
      Thanks for your vote. I appreciate it. There are lot of good articles in the contest. We will see.
      srilyk
      5 weeks ago
      This is fantastic! I've recently taken to using cardboard for prototyping and I <3 it
      theguymasamatosrilyk
      Reply 5 weeks ago
      Thanks.
      Cardboard is awesome. Before this project i never used it. But now,... I will try to create everything with cardboard. I also felt in love.
      jseager64
      6 weeks ago
      I have been thinking of this project for two years now. I have about 1/2 million baseball cards, some worth in the thousands, but I could not get past my fear that running the cards through using any type of "rolling" mechanism would decrease the value of the card because of rubber trails appearing after the scan is done. My thoughts now is to use a rolling ramp like you have here but once the card reaches the rubber rollers it would use a vacuum mechanism to move the card into the photo arena. Once the card is safely in place there would be a top and bottom cam run with a RaspberryPi to get both sides at the same time and forwarded to my computer. Nevertheless you actually did what I have been thinking about. I just don't want the mental and emotional pain of destroying the value of a card. I buy and sell quite a bit of baseball cards, hence the 1/2 million cards I have. OK fine call me a hoarder. As of right now I only provide stock images that someone else took but offer the potential buyer an actual scan from my 3 in 1 printer upon request as baseball card collectors want to look closly at the corners, edges and stains on the front and/or back.
      Any thoughts on this comment? You did a nice job by the way for cards other than cards that are worth 1000 times more than Yoogio (sp?) cards. Did you know that porn stars also have trading cards? I didn't until a few weeks ago by accident. Some of those cards go for $300+ each. I found that fascinating. And NO I have zero interest in trying to make a buck or two on anything related to porn or anything I wouldn't want my kids to find as kids know where everything hidden in the house CAN be found. :-)
      theguymasamatojseager64
      Reply 6 weeks ago
      First, thanks for your comment.
      I really like to discuss different options and ideas around a project. Great!
      In the intro I wrote about my “huge” collection, but that word fit better to yours.
      0.5 million WOW.
      Yes, I understand your fears. It is a torture for the cards and it is hard to watch, because the bending is quite a lot. But… I can not see any effects afterwards on the cards. On the other hand I used only scrap cards at the moment. If I would have very valuable cards I can not say if I would torture them with my machine.
      It’s made for the bulk process.
      Back in the days, when the idea grew in my mind I thought about possibilities to transport a card. This vacuum option was also on my list. But after the first test this idea failed. You can try this as well.
      I used a suction cup gun from my kids. The dart has a suction cup. I pressed it onto a card a lift it up. It works perfect and without any mechanical issues for the card, but (and this was the reason why this idea failed) it never happened the only one single card was lifted up. There are some physics behind, maybe static charge or static friction. I don’t know. But on every test two or even more cards were lifted up. Sometimes it lasts only a few seconds and the other cards fall down, but quite often even after minutes they are still stucked together.
      Maybe your baseball cards don’t have these problems.
      Maybe this problem can be solved with some air flow that will blow off all the additional cards.
      But I don't focused on this idea anymore .
      Pornstars trading cards? Interesting!
      No, I never heard of that.
      Yes you're right. Kids will find everything. :)
      jseager64theguymasamato
      Reply 6 weeks ago
      I woke up thinking that instead of sliding in cards on a ramp into the "darkroom" might be easier to do by dropping the cards one at a time down from the top vertically then the two Rpi cams can take the pic with it standing upright. After the pic is taken it could then be moved out of the "Darkroom" any number of ways. It seems to me that doing it that way would cut down on parts, meaning fewer items to replace WHEN they fail :-)
      Reply 6 weeks ago
      Yes, I totally agree. Gravity is the key to save money, mechanical and electrical parts.
      I will do this very similar in my machine. When the cards came out of the Card Feeder, they will slide down (because of gravity) to the Card Scanner. There the cards will be stopped and then (again with gravity) will slide down to the Card Sorter.
      In the past I tried some ideas on my desk. If the angle is too high, the cards will have too much speed and when they are braked sharply it will damage the edges. So vertically can be critical.
      How would you stop your cards to take a picture?
      jseager64jseager64
      Reply 6 weeks ago
      Your suction cup idea has some potential if you used a small pump about the size of an aquarium pump only that it sucks the card up with a vacuum, instead of pressing the cup to the card manually it would then pass over something like artificial grass cut really low. With new bbcards they tend to stick together. The artificall grass would prevent anything more than the top card to be picked up, slide just below the top of the grass to the drop ramp, and hopefully the grass will brush everything other than the single card with the suction preventing two and three card pickups (jams).
      jseager64jseager64
      Reply 6 weeks ago
      I was thinking more of a vacuum rolling, say stainless steel to get from point a (the pile of cards) to point B (insertion into the photo darkroom) and then point c (egress out into a pile gently.) There are some cards that just will not ever work in whatever the two of us think of in that there are Topps and Bowman Chrome cards that come out of the box with a bend in them, or curve if you will. Even if one were to get the picture into the "darkroom" the curvature of the card would make for some fairly unfocused images.
      Thank you for "re-inspiring" me to take up this thought process again. I LOVE making things. If I manage to put together a prototype I would eventually 3d printing as much as possible.
      If you keep thinking about it I promise to do the same and we can exchange notes. I am pretty well versed in everything Raspberry Pi's as I use several of them as timing, sensoring water status in our open air aquaponics greenhouse which is really easy to do living here in Florida. So anything I design and try to put together my pi's will have a significant role in the complete design.
      jon
      Reply 6 weeks ago
      The bending and curved problem was one reason why I switched to the mechanism with the wheels. It is not a big deal for the Card Feeder it can handle "curved" cards. But I know what you mean.
      Yes of course. We can share our thoughts and ideas.
      My machine is not finished yet, there is a lot to do.
      ronanry
      7 weeks ago
      What a huge project ! Great ambition... the least i can say is "you have some work to do man!"
      and i will follow it !
      theguymasamatoronanry
      Reply 7 weeks ago
      Thanks, dude!
      Yes you're right. There is still a lot to do, but I'm optimistic. Wherever it will end up, I have little doubt that it will be a hugely exciting and challenging project.
      Some parts do not even exist on paper. For example final design/look. :) We will see.
      cu
