Cardapult the Business Card Catapult
150,108
531
218
After seeing the business cards with gears a few months back (normal and planetary), I started thinking about what else could be made to fit in a business card. I wanted something unique and memorable that could represent me and my creativity. What I came up with was a business card that can convert into a rubber band powered desktop catapult.
Here is a PDF of the Instructable that includes all the secondary images and annotations.
Here is a video that shows how it works.
Another video of assembly to help if you are having trouble working out some of the steps.
If you want to build one and don't care as much about the appearance you can try the quicker and easier method.
Step 1: Things You'll Need
Some thick card stock , perforated business card paper, or anything just as stiff that you can cut easily
Hobby knife
Hole punch
Glue
Small rubber bands
Something heavy and flat (like a large book)
Cardapult design (attached in following steps)
Printer
Other stuff that may come in handy:
Scissors
Fingernail clippers
Toothpicks
Something heavy and hard (like a hammer)
For the paper I had a hard time finding anything thick enough locally except for the perforated sheets for DIY business cards. These will work, but alignment is more difficult since the edge of the card is already made. You'll need something about .012" or thicker. Which corresponds to 90 lb Cover and 140 lb Index (card stock). If you are just making these for fun then old folders or thin cardboard product packaging will work great as well.
I tried a few different glues and the best I found for these purposes was an Elmer's Craft Bond Glue Pen
Step 2: Print Card Text
Use the word document template as a guide for where the text will line up on the cards. Of course you don't want to print the background image itself so there a few ways you can keep it from printing. (For Office '03 probably similar in others)
Go to Tools>Options>Print and make sure "Drawing Objects" is unchecked.
Or get to the same screen by hitting Options at the bottom of the File>Print dialog
Or just delete the background image after you have things lined up the way you like
Free download link on next step includes this template
Step 3: Cut Card Parts
Well if you are going to do more than a couple of these then you probably don't want to do it by hand. I was considering trying to make my own dies, but then I found the Quickutz Silhouette for $99 shipped and that was completely worth it. (Found it at ohmycrafts.com, but they are out of stock now)
If you have a similar cutting machine that uses the Robo Master software then you can just grab the attached .gsd files.
If you have a laser cutter or other kind of cutting machine or just want to tweak the design then I'm also attaching the Inkscape .svg files. Inkscape has a lot of output options, so you should be able to get it in whatever format you need from there.
If you are cutting by hand then get out your scissors and hobby knife and figure out the method that is best for you. Here are a few approaches you might consider:
Print designs on sheets and cut along the lines one at a time.
Print it out once and make template pieces that you can either trace or use as a cutting guide.
Glue sections of paper together before cutting them with either of the two methods above
Note that I've purposely made the holes and axles 1/4" so they can be cut with a standard hole punch.
There are three different files
Insides = full sheet of the inside components
Outsides = full sheet of the outside components
Combined = 6 inside components and 4 outside components. Enough to make two cards if you are cutting the parts out individually.
Since Instructables now requires a Pro account to download files, I've uploaded them to my site so you can still download them for free. Download here
Step 4: Glue Inside Parts Together
First you'll want to glue the inside components together. Try to line up the edges the best you can. The inside is 3 layers thick except for the arm with the holes in it which is only 2 layers to provide some clearance. The legs are only glued together on the last 1/2" so that they can expand apart after they extend.
Also glue together 3 layers of scrap material that you can cut later use for the axles, don't bother trying the glue the actual little circles you cut out together.
Let the glue dry enough that you are sure they won't slide around anymore.
My gluing technique was to pour out a small puddle of the glue on a piece of scrap material and then use a toothpick to scoop up the glue and spread it evenly over the surface of the part. After you get the layers together then put them under a large book to make sure they dry flat.
Step 5: Glue Insides to Back Face
Now you just glue your inside parts to the back part of your card. The alignment locations are straightforward.
The large L piece lines up in the corner and flush against the notch on the other side.
The skinny piece lines up against the bottom edge of the card. Personally I've started trimming about 1/16" off of a short edge so you don't have to be as exact with the side to side alignment.
The odd shape piece goes on the smaller part of the outside face with the long edge aligned against the edge of the card.
Again give the glue some time to dry before proceeding.
Step 6: Glue on Axles
Use a hole punch to punch circles out of your 3 layer piece of scrap. Test the circles in the holes of your 2 layer arm. If they don't turn freely in the holes then use fingernail clippers to trim around the edges.
Place the arm in the small piece you assembled last step and trace the hole location. Carefully glue the circle over your trace marks and carefully do some double checking that the arm will still line up correctly and also make sure you're not gluing the arm to anything.
Repeat with the lower hole. You'll need the upper component in place to make sure the lateral alignment is correct, but vertically the arm should be against the edge of the large L piece.
Again letting the glue dry some before proceeding is recommended.
Step 7: Glue Front Face
This step is pretty strait-forward. Make sure you get the axles glued well and be careful not to glue the arm to anything. Remember it has to pivot freely.
Glue needs to be applied to every inside component that is glued to the back face. The same things that were glued in steps 5 and 6 are glued all at once in this step. The legs can be slid into place after letting this step dry for a little bit.
Step 8: Glue Small Bits
Now for the small bits. The bits on the arm and legs are hard to get on there without some bonding to the edges around them. I just came back with a hobby knife after the part dried and carefully cut around the edges before trying to break the components free.
Step 9: Cut Rubber Band Grooves
Now use a hole punch to cut some small grooves on the arm and bottom edge of the card for the rubber band. This would probably work much smoother with a heavy duty hole punch, but if you are like me and all you have is a hand-held 6 page punch then trying to do this by hand will bend the punch out of alignment. To work around this you can make sure everything is lined up, squeeze the punch firmly to keep it in place, set the end on a hard desk and smack it with a hammer. This seems to cut it OK, but just be sure not to miss.
Step 10: Build an Army
If you're going to actually give these out then you need to make more than just one or two. I took about a week to make 10 of them. I built them simultaneously, doing about 1 step each night for all 10 of them as I watched TV.
Step 11: Go Green
So many things come in thin cardboard packaging that it is not hard to find materials to recycle into a cardapult. Below is an example of one made out of cereal boxes. I left the images on just for fun, but you can also remove the printed skin (peels of pretty easily) and put the smooth side face out with your own text on it.
Step 12: Have Fun
Check out the video in the intro to see it in action.
Thanks to everyone who voted for me in the Epilog Challenge and the Klutz Rubber Band Powered Contest.
First Prize in the
Klutz Rubber Band-Powered Contest
Second Prize in the
Epilog Challenge
  • Fandom Contest
    Fandom Contest
  • Party Challenge
    Party Challenge
218 Discussions
diecutdarla
4 years ago
I'd love to see an instructable/file for your penny shooter card. Especially now that you're no longer taking custom orders. :)
Your instructables/files/concepts are fantastic
clidediecutdarla
Reply 4 years ago
Thanks, diecutdarla. The template file for the Penny Shooter can be found on Thingiverse http://www.thingiverse.com/thing:1581
msun8
4 years ago on Introduction
Do you actually give this to people as a business card? What a great first impression.
Adambowker98
6 years ago on Introduction
I downloaded the PDF but I'm confused on how to cut it. I know you cut on the solid lines but what about the dotted?
clideseanthesheep101
Stronger paper, stronger glue, or weaker rubber band.
You could also try the newer version which has a stronger design for the arm and axles http://www.thingiverse.com/thing:3530
seanthesheep101clide
Ok I'll try that but my card is really thick and when i say the arm breaks i mean where in the arm theres the angle is where it breaks.
But yeah your second card looks really different and futuristic, it looks cool.
The bit where you cut out the little bits for moving the legs out is so hard it's taking ne ages to do it. Oh and pls do an instructable on the penny shooter.
Yep, those bits can be difficult. I don't have detailed instructions for the Penny Shooter, but the design files and a quick overview can be found here http://www.thingiverse.com/thing:1581
I also live in Australia so I made the holes big enough (or small enough I don't know) for ten cent pieces :)
I'm working on the penny shooter right now and when I'm done I'll put it on instructables. And my cardapult got glued together in one spot but I fixed it. It is so annoying that I don't have the special cutter thing because my dad has some really thick card and so the cardapult only needed I layer and us really thick.
clide
9 years ago on Step 3
Just one layer for each side.
