Carpenter Themed Fathers Day Coat Rack
26,331
595
30
About: Just a normal guy trying to make it in life .Good paying job but mindless sometimes .I enjoy making things in my garage to keep my mind going .. Its fun making something new but its more fun taking somethi...
This is my coat rack i made with a carpenter theme. For the wood i used a 1x12x6 oak board,Five claw hammers and two quick squares.
Step 1: Materials
(1) 1x12x6 piece of red oak
(2) Five  claw hammers
(3) Two quick squares
Step 2: Cutting the Oak Wood Boards
Step 1 ~ I decided to cut the oak  rack boards 9 inches wide by 3 feet long.
Step 2 ~I used a 1/2 inch round over router bit to bevel the edges.
Step 3 ~ I measured  in 3/8 of a inch on the top board and drew a line down the edge of the board for the screws
Step 4~  I drilled seven  1/8inch   holes And installed the black specialty screws to assemble the rack.
Step 3: Claw Hammer Configuration
Step 1 ~ Find the right height and angle for the claw hammer.
Step 2 ~  Mark and cut the hammer handle.
Step 3 ~ Pre fit the hammer head  to the board and make sure its the angle and height you desire then cut the other four hammer handles.
Step 4: Assembling the Hammer Heads
Step 1~ Pre drill the hammer heads with a 7/32 drill bit.
Step 2 ~ Pre drill the board with a 1/4 inch drill bit.
Step 4~  I used 1 1/2 inch long by 1/4 inch tap con screws assemble the hammer heads to the board.
Step 5: Assembling the Quick Squares
Step 1~ I marked and  drilled (4)  3/16 inch holes in each quick square.
Step 2~ Assemble the quick squares to the board with # 6  Screws
Step 6: Protective Finish
Step 1~I like using this Minwax Polycrylic water base for the protective finish because it drys fast and doesnt have a odor.
Step 2~ Mount to a wall and enjoy your Carpenter themed coat rack.
Father's Day Contest
First Prize in the
3 People Made This Project!
  • Arduino Contest 2019
  • Trash to Treasure
    Trash to Treasure
  • Tape Contest
    Tape Contest
30 Discussions
craftvideos
2 years ago
I do not understand ... you guys can use other kind of hook too. That will be less costly and easy to use.
I think your idea is wrong you have to make sure the hammer rests on the wood . I made this few days back :)
GlennPruett
5 years ago
I made this for our pastor that is a carpenter also awesome project
cdog557
5 years ago
I've made like 20of them for my family.
I had not seen this project until I saw the finalist in the Father's day contest. This is what I call pure creative genius :). AWESOME. Thank you for sharing.
