Cassette MP3 Player
235,598
1,337
92
About: Hi, my name is Britt Michelsen, I'm a Chemical Engineer especially interested in Computational Fluid Dynamics. To balance all the theoretical work I like to make stuff in my free time.
In this instructable I am going to show you how to house a MP3 player in a cassette tape. I had the idea to build this quite some time ago, but while I was still waiting for the parts to arrive, instructable member lonesoulsurfer posted his version here.
So I decided to concentrate on other stuff and somehow forgot about it. After moving recently, the parts fell into my hands and decided to give this project an other shot, since my approach is quite different from lonesoulsurfers. My idea was to actually use the cassette tape wheels as buttons to select the songs and adjust the volume.
The cassette I used for this was broken and I decided to give it a new, more modern life.
Btw. I know that you can buy cassette MP3 players e.g. here or here, but I wanted to build one that looks completely like a normal cassette.
Step 1: What You Need
Materials:
  • Cassette (that is held together with screws)
  • Block USB MP3 Player (e.g. from amazon.com or a lot cheaper from ebay)
  • Glue (jb weld, faster setting 2 component glue)
  • Enameled copper wire (e.g. from amazon.com)
  • Two M3x20mm screws
  • Micro SD/TF card (max. 8GB)
  • Solder
  • 4 miniature snap action switches (e.g. from digikey)
  • Shipping labels (if you would like to change the label)
Tools:
  • Soldering iron
  • Rework station (not a 100% necessary, but certainly helpful)
  • Sharp knife
  • Screw driver
  • Diamond file
Step 2: Take the MP3 Player Apart
Start by taking the MP3 player apart. The bottom can easily be lifted off with anything sharp. There is a single screw next to the SD card, holding the board in place. Unscrew it and take everything out of the shell.
Remove the sticker from the buttons and unsolder the battery. You will also have to remove the audio plug, the on/off switch and the micro USB jack. A rework station is certainly helpful in fulfilling this task. Make sure to keep all the unsoldered parts, you will need them later on.
Step 3: Preparing the Cassette
Take the cassette apart in order for it to house all the components. Afterwards you will have to create the openings for the headphone plug, the USB jack and the switch. I decided to place the opening for the audio plug at the side of the cassette, so that I would be able to carry it around in my trouser pocket and to use the two already existing holes at the top of the cassette for the other two components.
Step 4: Creating the Push Buttons
I decided to keep the magnetic tape, because removing it felt as if something was missing. Since I couldn't fit it in there entirely, I had to cut it to the correct size. To prevent the tape from unreeling, I used quick setting two component glue, as shown in the pictures. Before you do so, cut off an around 10 cm long piece, since you will need it later on.
Cut a small slot into the wheels and glue the screws into them (You don't have to cut the screw heads off, like I did). You can of course use any other type of pin, but I found that a M3 screw has the perfect size.
As you see in last step, the space is very restricted. You will have to cut some of the plastic from the wheels in order for them to fit (as shown in the pictures). Remember that you will have to move them later on, so make sure that you are able to do so. Afterwards glue the miniature snap action switches in place so that they can be operated by the pin. Connect them to the board, as shown in the pictures. If you have not worked with enameled copper wire before, don't worry it is quite easy to use. Simply use solder to burn the protective layer away. If you are still unsure, it is explained in this video.
Step 5: Assemble Everything
Solder everything back in place as shown in the picture. Make sure that the SD card fits and that everything moves fine. Use the JB weld to hold everything in place.
After the JB weld is set, glue the magnetic tape you prepared before back in place, as shown in the second picture. Make sure, that the wheel can sill be moved without any interference. Use the 10 cm piece of tape that you saved before and glue it to the two small wheels at the bottom of the cassette.
Screw the cassette back together and change the label, if you want to. Songs can by added with an USB cable, so you don't have to open the cassette every time.
I added a pdf of the label I made so that you can make your own Guardians of the Galaxy version. Upload the Guardians of the Galaxy: Awesome Mix Vol. 1 and you are ready to safe the universe.
Remix Contest
First Prize in the
Remix Contest
Tech Contest
First Prize in the
Tech Contest
3 People Made This Project!
  • Trash to Treasure
    Trash to Treasure
  • Arduino Contest 2019
  • Tape Contest
    Tape Contest
92 Discussions
parisusa
2 years ago
I'm a teen of the 1980's so I think this is SO fun!
BarronD1
3 years ago
How did you cut the Magnetic Tape, I am confused about that, and I wanted to make it this week! Any info will be greatly appreciated!
BrittLivBarronD1
Reply 3 years ago
Hi, I used an utility knife. Admittedly it was a bit tricky. Good luck!
BarronD1BrittLiv
Reply 3 years ago
So all it was was good old fashioned elbow grease, thanks!
FelisC
3 years ago
Awesome!
devicemodder
3 years ago
Take it a step further and stick it inside on e of those car cassette adapters. That way, if you have a car with a cassette player, it will play this .
phantomfsoc
4 years ago on Introduction
Looks cool, does this mp3 player start playing as soon as its powered up or do you need to press play?
AlinaBaba
Hey guys, i was just about to build this really nice mp3 player, i even have almost all componets but, when I started to plan the whole thing I just could not figure out whre the Play/Pause Buttion is. I figured that the action switches that you operate with the wheels are for volume up/down and next/previous song. The on/off switch is on top of the tape, but I cant finde the on/off button/switch. Can someone help me?
eluvatar
Thanks for sharing. I ordered all the stuff and started making it. However after a few hours I broke one of the pins on the mini USB port, at that point I gave up. props for what you did though. Very small solder points on the usb port.
jpm021990
Does anyone have a schematic or an explanation of which wires get soldered to where? There are 3 prongs on the headphone jack and I am unsure of which 2 to solder
EpicMinecrafter870
4 years ago
This is.......umm........wasteful and.............................................
AndrewB14
You could do this with an iPod shuffle and use the earbuds inline remote as the controller. That way you wouldn't have to solder all those control points. Im going to attempt that today.
This is a really amazing design/layout!
I was thinking of giving it a go but was looking for an alternative to the micro switches you have listed. I found one of similar size and was wondering if it would do as a stand-in? ([12.8 x 6.5 x 5.8mm] Registered as a "Sub Miniature Lever Micro Switch") Sorry if a bother but: When looking for guidance, look to the masters :)
Raitis
The more I look at this the more I appreciate how well thought out it actually is with the visible tape and wheels for control. That's a James Bond level of disguise. :)
