Cat Laser Tower
10,397
159
11
About: Making the most of things by making the most out of things.
Cats share few defining traits with humans, but love of lasers is definitely one of them.
Often, my cat's enthusiasm for 'chase the laser' continues long after my own enjoyment of 'look how silly the cat is' has ended, so I turned to technology to find an answer.
The cat laser tower is the purr-fect solution for a lazy cat owner like me. The Arduino powered laser tower (which can double as a scratching post) zips a red dot randomly around the floor for you, allowing you to sit back and enjoy the ridiculous antics of your feline friend.
It's easy and cheap to build, requires no soldering and only very simple coding. I don't know who had more fun, the cat, or everyone watching the cat.
NOTE: This project uses a laser and lasers can be dangerous. As we're using one which is no more powerful than your standard laser pointer, your (and your cat's) blink reflex should prevent any serious damage to your eyes (just please don't stare right at it). However, it is still something to be aware of, please only do this if you feel comfortable with it.
Happy making!
Step 1: What You Need
To make the tower:
1 x Plate (for the base)
2 x Pringles tube
1 x piece of hessian or burlap material
1 x clear plastic pot
1 x small piece of polystyrene or similar
Duct tape (in the picture there is glue and gloves, duct tape is much better)
To make the laser:
1 x Arduino Nano (or other Arduino compatible board)
1 x servo
1 x laser module (like this one)
1 x USB power bank (anything like this)
1 x USB to micro USB cable (power bank to Arduino)
3 x male to female jumper wires (servo to Arduino)
2 x female to female jumper wires (laser to Arduino)
Step 2: Electronics
First, connect up all your parts and wires as shown in the diagram above.
Using the male to female jumper wires, connect the wires of the servo to the Arduino. The brown wire should go to GND, the red to 5V and the orange (which will carry the signal) to D5.
Using the female to female jumper wires, connect the laser module to the Arduino. The pin nearest the "-" should go to GND and the pin nearest the "S" should go to D6. There is a pin in the middle which we won't use in this project.
Next we need to mount the laser on the servo. To get the right angle, so that the laser would point to the floor instead of the wall, I used a small piece of polystyrene cut into a triangle. Initially, I tried using super glue to attach the laser module to the polystyrene, but it just melted into a weird gluey paste and got everywhere. Learn from my mistakes, use tape.
You can always readjust the angle once you've got it running and test out what works best for your tower, but I found a steep angle worked quite well.
Step 3: Arduino Code
Next we need to program the Arduino.
This is the code I used. As long as you have used the same input/output pins as I did, this should work fine without modification.
 * Cat scratching post laser turret.
 * Pin 6 to 'S' pin on module.
 * Ground pin to '-' on module.
#include <Servo.h>
// pin constants
#define LASER_PIN 6
#define SERVO_PIN 5
// declare servo objects
Servo servo1;
// Random number
int randNumber;
void setup() {
  Serial.begin(9600);
  // if analog input pin 0 is unconnected, random analog
  // noise will cause the call to randomSeed() to generate
  // different seed numbers each time the sketch runs.
  // randomSeed() will then shuffle the random function.
  randomSeed(analogRead(0));
  // set pinmodes
  pinMode(LASER_PIN, OUTPUT);
  // initialise servo objects
  servo1.attach(SERVO_PIN);
void loop() {
  // make sure the laser is on
  digitalWrite(LASER_PIN, HIGH);
  // print a random number from 0 to 180
  randNumber = random(180);
  Serial.println(randNumber);
  // write position to servo
  servo1.write(randNumber);
  // sets time between movements. Change this to make the laser
  // pause for a shorter or longer time
  delay(800);
Step 4: Building the Cat Tower
I modeled the laser tower on a scratching post, so that it wouldn't look out of place in the corner of the living room and also so that my cat could scratch it if he wanted.
The Pringles tubes, when duct-taped together, make up the body of the tower and a nice heavy plate makes the base. Having a heavy and wide base helps stop the cat being able to push it over and you can normally get a good cheap plate from a charity shop.
To make it good for scratching, I used hessian for a covering. First I cut a square that would easily cover the plate, then cut a cross in the centre. This can then slide down the Pringles tubes and cover the plate to leave no gaps. The excess can be tucked underneath and taped down on the underside.
Another piece of hessian is used to cover the tower. Initially I wanted to use glue to give it a clean looking finish, but I found that super glue wasn't very effective so I turned to the old fail safe of duct tape. Before wrapping up the tower completely, the electronics need to be installed, as you will need to cut a small hole in the tube.
Step 5: Installing the Electronics
First, the USB power bank needs to be secured to the inside of the tube. This was the the most fiddly part of the project, even with my small hands I found it tricky to manipulate things inside a Pringles tube with any finesse.
The power bank is taped to the inside wall of the tube and a hole is cut in the cardboard where the on/off button is located. I found that when I tried to press the button, the whole power bank would move backwards as the tape wasn't quite tight enough. To fix this problem, I took a wooden toothpick (any straight object will do), cut it to the right size and wedged it behind the power bank. This meant I could put quite a bit of pressure on the button and it puts less strain on the tape holding it up.
The Arduino nano is light enough that it can just dangle inside the tube and the servo-laser unit can be mounted on the top of the power bank. I positioned the laser to be in the centre of the tube rather than the edge, as I knew I would be covering it up with the transparent pot and I wanted to give it enough room to swivel around with the wires coming out of the back.
Now that everything is installed, the rest of the hessian can be wrapped around the tube. Any excess at the top can be tucked into the inside of the tube and taped down to make it neat. Again, my initial plan was to use glue to secure the hessian, but I ended up using clear tape (which is hard to see in the pictures).
I decided not to cut a hole in the hessian where the button was, as mine lights up when it is on and I quite liked the effect. To make sure I knew where it was, I marked the square with pen.
Step 6: Cat-proofing
Cats are notoriously curious creatures and we don't want any electronics getting pawed at or eaten, so some cat-proofing measures are essential.
A clear pot is secured around the top using duct tape (where would I be without it), making sure that the laser has enough room to swivel around inside.
This can always be removed when you need to charge up the power bank and replaced as necessary.
Step 7: Testing
Now for the fun part...tormenting the cat.
I hope this project brings you and your cats as much enjoyment as it did for me and Max.
Have fun!
Animal Innovations Contest
Runner Up in the
    • Tape Contest
      Tape Contest
    • Jewelry Challenge
      Jewelry Challenge
    • Trash to Treasure
      Trash to Treasure
    11 Discussions
    Vesa Seppänen
    3 years ago
    Nice!
    I've been planning something like that. My idea is to use a string and hang the device from the ceiling with as much unstability as possible. No tower needed. Also any servo movements should introduce string movements, adding randomness (sort of) to the path of the laser point.
    simontorres
    3 years ago
    I'm concerned about the safety of your cat. Lasers are quite dangerous and given the configuration it might happen that the cat looks directly into the laser beam producing some permanent damage. Is a very good idea though, in fact I'm thinking to put LEDs to a similar tower I'm planing to do. Keep an eye in your cat's vision or/and try another configuration where the cat is not looking directly into the beam.
    Best regards.
    snowbiscuitsimontorres
    Reply 3 years ago
    You're right, it's definitely something to be aware of. As we're dealing with visible light and fairly low power, the risks are quite minimal, but I've added a disclaimer to the intro, so people will be aware of any risks and only build it if they feel comfortable. Thanks :)
    Maniacy
    3 years ago
    It's hilarious and probably a lot of fun for the cat. Please if you attempt to build this do take into account that the chance of lasting eye damage is greater the more powerful the laser is and the longer the cat plays with the laser.
    snowbiscuitManiacy
    Reply 3 years ago
    Very good point. Using a steep angle on the laser helps prevent this (as he has to get right between the dot and the tower and face the other way), but it's still something to be aware of. I recommend supervising laser-fun-time activities.
    paqrat
    3 years ago
    I'd be concerned that somehow the laser would hit the cat in the eye. I don't want to be responsible for blinding my cat, even if only temporarily.
    cclark63
    3 years ago
    Try hot glue instead of tape. Superglue has that affect on alot of plastic and foam materials.
    JulianAzz
    3 years ago
    I Love this, Great idea!!!
    iKotkin
    3 years ago
    love this!
