Cauliflower Rice
19,197
115
14
A quick and easy method to make your own cauliflower rice at home. Cauliflower rice has become increasingly popular substitute to more traditional rices like brown, white or jasmine. It has also been a common base ingredient in gluten free dishes like Cauliflower Crust Pizza Dough or Cauliflower Tortillas. I have also begun to see cauliflower rice for sale in stores like Trader Joes, which was shocking since it is so easy to make at home with just a simple blender or cheese grater.
Follow along to learn how to make reliable cauliflower rice using two different methods.
Step 1: Things You'll Need
Gather the following items:
  • A head of cauliflower
  • A sharp knife with a larger blade
  • Cutting board
  • Cheese Grater (Method #1)
  • Food Processor (Method #2)
  • Paper towels or a dish towel
Step 2: Quarter Your Cauliflower
Using a sharp knife cut your head of cauliflower into quarters.
Step 3: Remove the Greenery
Start by breaking off the green cauliflower leaves from your cauliflower quarters as they will not become a part of your final rice product. I personally like to save them, adding them to salads or stir frys later.
Step 4: Method #1
This is the most time consuming method out of the two shown in this Instructable. I personally prefer this method because of the final texture and shape of the cauliflower rice but it will take you a considerable amount of time in comparison to the second method.
Grate each quarter section of your cauliflower against the coarsest setting on your cheese grater. Take your time and go slow as cauliflower tends to crumble a bit and you'll want to watch out for the safety of your fingers. Repeat with each quarter section until your entire head of cauliflower has been grated.
Step 5: Method #2
This second method is fast and efficient. Use it when you're short on time and need a quick and reliable result. I have found that food processors and blenders do not always produce uniform cauliflower rice pieces throughout the rice. It could also very easily be my blender/food processor as well.
To utilize this method, you'll need to first chop your cauliflower quarters into smaller segments that will fit into your food processor. Once chopped, place them into your food processor and pulse/blend your cauliflower until you reach a uniform consistency and size with your cauliflower rice. You may need to work in batches depending on the size of your food processor.
Step 6: Quality Control
Remove any larger chunks or florets of cauliflower from your cauliflower rice. Place them back into the food processor to reprocess and grind until they are the same size as the "rice" you've already created.
Step 7: Drain Your Rice
Cauliflower as a vegetable, like most, has a high water content. You'll want to draw out some of that water by placing a paper towel folded on a dinner plate. Evenly spread a thin layer of your cauliflower rice, or a portion of your cauliflower rice on to the paper towel. You do not want a thick layer because it will be easier to have the paper towel wick away moisture with increased contact surface area with the rice.
Once you've set up your first layer you likely have rice left over. Lay down another paper towel and another layer of cauliflower rice. Continue this layering technique until all of your rice has been layered. The final layer should be a paper towel. Place another dinner plate on top of the entire stack to add some weight. Allow your stack to sit and absorb moisture for 10-20 minutes then flip the entire stack--I do so by placing a hand on each dinner plate, applying pressure to press them together and then gently and carefully flip the stack. Allow your rice to dehydrate for another 10-20 minutes. You may need to change out the paper towels. Continue this method until your rice has drenched the paper towels.
Step 8: You're Done
You're done! I've place the rice from method #1 (cheese grater) on the left hand side of the photo and the rice from method #2 (food processor) on the right hand side of the photo to give a visual side by side comparison of the final product. Again, as I mentioned earlier in the Instructable, I prefer the texture, shape and size of the rice produced using the cheese grater, but using the food processor method is noticeably faster and time efficient in comparison.
You can store your cauliflower rice in the fridge for up to a week. Use it raw in salads to add a deliciously sweet crunch or sauté it in a fry pan with a teaspoon of oil to create the base for a fried cauliflower rice. I sautéed mine, added some lime juice, cilantro and some avocado. You've now got a blank canvas for so many dishes so get creative!
  • Pie Contest
    Pie Contest
  • Fat Challenge
    Fat Challenge
  • Jewelry Challenge
    Jewelry Challenge
14 Discussions
lzang46
2 years ago
METHOD 3:
Instead of skinning your knuckles on the box grater or ending up with caulflower purée using your food processer, try a French "Mouli*"
It's a 3-leg standing grater with interchangeable horizontal round blades*, a moon shaped 'box' to hold the food, a simple moon shaped lever to push the food down, and an easy crank to move the blade. Takes no more than half the time of the box grater (with no 'ouch') and much less to clean than the processor.
Do a quick search on Ebay; plastic ones are newer and stronger. Blades vary by the side of the holes.
lazemaple
2 years ago
My food processor has a large hole grater disk - would this not produce the same effect as hand grating?
MariánF8
2 years ago
So Creative. I'd never imagine this.
TexM1
2 years ago
Great instructable! Enjoyable read. I too prefer the grater method to food processors, in general. I eat the stalk, as-is, but many folks will only eat the florets.... proof positive that there really are "weird" people in the universe! LOL Humor aside, this is one way to prepare the stalk and they'll never know! It's a sin to waste what it truly useful.
ataylor26
2 years ago
Outstanding. I'm on Low Carb / High Fat and this will be a great addition to my repertoire!
jerryi6
2 years ago
I've done this and it is as good as the store based versions. I actually use the cauliflower two ways. I cut off the florets and use them traditionally. Next, I take all the stalks and "rice" them in a food processor as described. Gives me the best use of the vegetable and I can't tell the rice was only from the stalks.
spatial guy
2 years ago
Heard about it, and being low carb wanted to give it a go. Now with your instructable...guess what is going on the table tonight! Excellent, thank you.
gadsden
2 years ago
Great idea! There so many ways to use this "rice". Thanks!
needles1975
2 years ago
Yum. I'm on Atkins and suggest this diet to many of my patients so this is a great idea!!
Jack of Most Trades
2 years ago
We have this often and just love it! Stir-fried, roasted on the grill with other veggies and EVOO until it starts to brown, and as a replacement for rice in a slaw with sweet/sour dressing. Yummy!
Lozchik
2 years ago
Nice idea :) I haven't even heard of this, but this'll be nice to vary up dishes. I was looking for a non-rice GF grain and an excuse to eat more cauliflower. This solves both problems ;)
EvelynC30
2 years ago
I made this often to control my carb intake. I, too, prefered the grater. the food provesor leaves a thinner texture.
sclements3
2 years ago
Such a great idea! I wish I had this technique when I was a vegetarian lol I'll still be using it though. Thanks for sharing :)
