Cement Skulls!!!
29,653
243
17
I've been wanting to do some cement sculptures for a while now. I wanted a fairly simple,
yet still cool, design for my first project. After looking through Thingiverse I found
http://www.thingiverse.com/thing:36110 by macouno. It is simplified but has all the major
features that make up a skull. It was also complex enough that I got to learn a little bit
about Autodesk Inventor's Mold Making features to help me figure out the parting lines.
(this is NOT a tutorial for Inventor Mold Design, I only learned a little to get me
through the steps of making my parting lines).
I used:
TechShop San Jose!
Autodesk Inventor
Thingiverse
MakerBot Replicator
Cut3D
ShopBot
MDF
Filler Primer
Lacquer
Silicone Spray lubricant
gorilla tape
Quikrete
Bar clamps
Deadblow hammer
sand paper and files
Durhams waterputty
Step 1: Design the Mold
After I downloaded the .stl file from Thingiverse I opened it in Autodesk Inventor 2013.
Using the mesh enabler (found here: http://labs.autodesk.com/utilities/inventor_mesh)
I converted the skull to a solid. Then I made a cube, totally surrounding the skull with
one side flush to the base (a new solid). Using the combine feature I cut the skull out of
the cube, leaving a hollow cavity. On the base of the cube I did a simple sketch to make
split lines for the 3 part mold. I also made a split line on the back side. And lastly,
the most complex parting ling was made on the side wall. First I split the side to make a
front and back. Then split the back side in half to make the three parts.
Once the three parts were made I used Create Mold Design to analyze each part of the mold
to determine if there were any undercuts. Since I eyeballed the parting line on the side
wall I knew that if any changes needed to be made all I would need to do was edit the
sketch that made that split. In Mold Design, using Adjust Orientation, I selected the face
where the skull will be removed and looked to see if any undercuts were detected (they
apear as blue faces). Once everything was green I was mostly satisfied.
Many thanks to macouno for posting Lisa the skull to Thingiverse.
found here:  http://www.thingiverse.com/thing:36110
Step 2: 3D Print Test
Before I went to the large scale skull I decided to make a smaller version as a sanity
check, and I also wanted a small mold as well. I 3D printed all three mold parts and
made a small cement skull. This confirmed the Mold Design analysis, and I was ready to
move onto the ShopBot for the bigger mold.
Step 3: ShopBot
Using Cut3D I made the tool paths for my larger size mold. I cut and glued MDF into
2 inch blocks. I had to do each part in two sections, so after cutting six pieces
I had all the parts to my mold cut out.
Step 4: Assemble Mold
I applied glue and clamped all the parts of my mold to get my three parts together.
Using Durhams water putty, sand paper, and files I cleaned up and smoothed out any
imperfections.
Step 5: Seal Mold
After the molds were glued and smoothed out I used Filler Primer to create a base layer.
I did some light sanding after applying a few generous coatings. Then I used a spray
Lacquer to create a smooth, hard, shiny durable surface.
Step 6: Fill Mold
The mold is now complete. Using bar clamps, and a some gorilla tape to seal the parting
lines, I secured my three part mold, ready to accept the Quikrete. I mixed up a batch
poured it into my mold, and attempted to shake out as much of the bubbles as I could.
After a day or two to cure I busted open the mold, and I had a pretty sweet cement skull!
    • Tape Contest
      Tape Contest
    • Gardening Contest
      Gardening Contest
    • Trash to Treasure
      Trash to Treasure
    17 Discussions
    TSSJ-ryancdawisconsin
    Reply 1 year ago
    gunna make another one for a friend... maybe i can make more ;)
    send me message if you're intereseted
    Ah yes, this instructable is exactly what I've been looking for! Thank you!
    J-Five
    6 years ago on Introduction
    Cool!!!
    At least your tring to get a-head in life.
    wilwrk4tls
    6 years ago on Step 6
    I'm not sure how you shook the mold, but if you shook it by hand... Something I saw on TV for getting bubbles out (without actually using a concrete vibrator in the concrete) was to use a sawzall (or a jigsaw may work) without a blade in it, and put the shoe of the saw on the side of the mold and run it. This will vibrate the cement pretty well and help to remove the bubbles.
    What version of Inventor did you use that has the mold tools?
    BeoWulfe
    Those pesky kids will think twice before molesting my lawn once I've installed my mountain of skulls retaining wall!! MUAHAHAHAA!!!
    stringstretcherlsf
    Reply 6 years ago on Introduction
    correct, and it is as simple as holding a vibrating palm sander against the mold when pouring slowly, or on the mixing container before pouring.
    An easy way to remove the air bubbles when fulling mold is to use a palm sander, without sand paper, against the side of the mold. Nice project. Cheers!
    You've made some good looking "background" skulls. I think you might be able to use these as an edging for a lawn or embedded into a fireplace.
    dreamberry
    i MUST make a concrete skull for my yard. i WILL make a concrete skull for my yard. I am so serious about this.
