Center Finder Jig
8,154
137
13
Simple center finder.
Step 1: MDF
Cut two pieces of MDF.
Step 2: Glue
Glue and clamp them at a right angle.
Step 3: Screw
Reinforce the joint with screws and check for square.
Step 4: Angle
Cut a right angled triangle piece of MDF.
Step 5: Glue
Glue and clamp in place.
Step 6: Pivot Screw
Before the glue dries insert one screw to reinforce and to pivot. Check the 45 degree angle and adjust appropriately, then insert a second screw.
Step 7: Seal
Seal the edges of the MDF with glue and give the piece a coat of shellac to prevent moisture from warping the shape.
Step 8: Find the Center
    • Weaving Challenge
      Weaving Challenge
    • Organization Contest
    • Pie Contest
      Pie Contest
    13 Discussions
    jeanniel1
    1 year ago
    Oh why didn't I have this before I lathed a bunch of dense foam? So simple and handy. Thanks!
    CXYyuppie
    1 year ago
    Good job and nice write up. This is a handy little jig. I just made one last week out of Spanish Cedar. I used Lexan for my diagonal piece. Very convenient for find centers on your work piece to put in a lathe. I thought about scribing measurements on the diagonal but then I thought I was just being OCD about a simple project. Just be careful where you store this jig, too much humidity will make it swell & could throw it out of square. Once again, great job!
    kohalabeeman
    1 year ago
    Aloha,
    Its simple and easy . Many should find it very useful .
    MDF is good , if you have it . The dust from it can be harmful , so watch out . A more lasting model even in MDF could be made with its edges sealed with crazy glue to make the edges more tough or just make it out of Carbon Graphite .
    But simple is always Good .
    Aloha from Oahu ,
    Mark Baker
    Nate5b
    1 year ago
    Nice and simple, I like it. Thanks for sharing!
    TerriK2
    1 year ago
    Didn't I read somewhere, recently, that a large percentage of speed squares are significantly inaccurate? I suppose that's not critical unless you're using this jig for, say, machining to close tolerances, which you wouldn't. But MDF edges aren't going to be, or stay, all that accurate either, so for a quick and temporary tool perhaps it doesn't matter. Just wanted to pass the speed square issue along.
    Yonatan24TerriK2
    Reply 1 year ago
    Heard of that too. But there's a simple way to check if they're off - Google it.
    Quantumdust
    1 year ago
    I needed one of these since about 50 years ago. What took you so long ? :-)
    pgs070947
    1 year ago
    Another one?
    The old tricks are usually the best, but full marks for trying. I don't know who invented the first one, but Pythagoras might have had a hand in it.
    If you need to leave the screws in, why not countersink and leave them flush? Just being picky, but something to snag on.
    djpolymathpgs070947
    Reply 1 year ago
    I did eventually countersinked the screws. Just got a little ahead of myself with posting the instructable.
    splatticus2
    1 year ago
    Clever jig. Now, rather than have the three edges intersect exactly, if there is a slight gap between the intersection of the two square edges and the 45° edge, then lines drawn or scratched on the dowel end can go right through its center. I know this isn't critical, since if at least three lines are drawn, then the center of the area between those lines will be easy to hit, but hey.
    AnthonyB80
    1 year ago
    Excellent in its simplicity
    gm280
    1 year ago
    Simple and complete. Nothing else to ask for. Good project.
