Champagne Cork Chewbacca
6,894
198
13
This is another Star Wars corky, voted by other users in my Yoda Instructable. I tried to make this as accurate as possible, but the fur I used wasn't ideal for the job, so it didn't turn out as well as I expected. Anyways, here's how I did it.
Step 1: Supplies
Supplies:
  • Chamagne cork
  • Extra piece of cork
  • Small black pins
  • Artificial brown fur
  • Aluminium tape
  • Light brown fabric
  • Needle nosed pliers
  • Craft knife
  • Brown and black permanent markers
  • UHU glue
  • Scissors
  • Chisel-tip soldering iron
Step 2: Modifying the Cork
Unlike most other corkies, Chewbacca, being a Wookiee, has animalistic features. It would have been very difficult to achieve the proper look with a cork with straight sides, so I carved away some of one side of the cork.
Also, glue/pin an extra disc of cork (from another champagne cork) to the bottom of the cork. This is to make the cork taller, as Wookiees are taller than most humans.
Step 3: Fur
The fur was the tricky part. Ideally, you would want a few different shades of brown, ranging from dark brown to dark blonde. The face should really be blonde, but all I had was this brown fur, so I had to work with that.
Start off by glueing a strip of fur across the top. Make sure that the direction of the fur is away from the face, as shown above. Add more strips of fur to the sides of the head until the entire top is covered in fur. Next, glue a thicker strip of fur and glue it around the body. This step could also have been done first, it doesn't really make a difference. Glue a further strip to the bottom of the face, with the fur direction towards the bottom. Cover any gaps with fur to make the cork completely covered.
Step 4: Face
For the eyes, I used a couple of black plastic pins. Shorten the pins to about a centimeter so that they won't poke out the back of the cork. Then, use a black permanent marker to give them a shiny black color.
Use a third pin for the nose. Instead of leaving it as it is, however, shave away a bit of the sides to give it a triangular shape, to make it look like a nose. If you can, color the pin brown instead of black.
At first I was going to just leave the mouth out completely, but then I realized that my cork resembled more of a dog than a Wookiee. The solution for the mouth didn't turn out to be as complicated as I had thought it would be. Use a chisel-tip soldering iron to burn away a section of the fur of the face, as shown above. You might want to practice this with some scraps of fur glued to another cork, just to make sure that it works and that you don't end up ruining your cork (this is why it's important to use artificial fur, not real fur).
To make the teeth, cut out two small bits of paper as shown above, and glue them to the top and bottom of the mouth. Cover them up a little with some more fur.
Step 5: Utility Belt and Pouch
Finally, the belt. Cut a narrow strip of light brown fabric, long enough to reach around the cork diagonally. Then, stick small squares of aluminium tape along the length of the strip and draw a line across all of the squares with a brown permanent marker (see last image). To make the pouch, cut out a small rectangle of the same fabric and glue it as shown above. Attach it to the utility belt.
Step 6: Done
If I were to make another Star Wars Corky, who would you want it to be? Write your suggestions or ideas for other corks in the comments below.
    • Jewelry Challenge
      Jewelry Challenge
    • Tape Contest
      Tape Contest
    • Trash to Treasure
      Trash to Treasure
    13 Discussions
    ttowngirl
    4 years ago
    Since Chewy is so tall, you could use 2 corks with a pin in the middle to connect them. The second or bottom cork is covered in fur and has a blaster.
    sjroth
    Reply 5 years ago on Introduction
    Thanks! I was actually thinking of adding a crossbow, but couldn't find a good way to make it.
    Carsman6665
    5 years ago
    Can you make Elizabeth from bioshock infinite?
    AJD42
    5 years ago
    Can u please do a minion regular or purple please :)
    Archer2500
    Nice job,as always. I've been checking for a new post for ages, and the day I didn't check was the day you posted this. But, as usual, I couldn't afford half the materials to make a single corky even if I sold everything I owned.
    P.S I liked your old profile picture better.
    as9
    5 years ago
    CHEWBACCA!!!!
    Crzywnch
    5 years ago
    An R2D2 corkie or an Ewok corkie
    Do you have a special shelf that fits the corks nicely? If so, you should post it :) or if you decide to make on, you should post it :)
    The one I use at the moment isn't perfect, but it works. I'll definitely post a picture if I make a new one (I might even add some LED lighting).
    martipeka
    5 years ago on Step 6
    Love, love, love your Chewie corkie! An R2D2 would be great?
