ChapStick LED Flashlight
219,191
540
92
This is an instructable on how to make a flashlight out of a ChapStick tube. After reading up on multiple LED instructables I thought it would be neat to make an original design that had not been done before. Since button cell batteries can be expensive, I went with an A23 (12V) battery that cost less than $2.00 for two.
Step 1: What You'll Need:
ChapStick Tube
Tactile Switch
A23 Battery (12V)
470-Ohm Resistor
10mm White LED (28,500mcd, 20mA, 3.5V)
Solder
Heat Shrink Tubing
Wire
"N" Battery Holder
J-B Weld
Step 2: Soldering the LED & Resistor
Cut the negative lead of the LED to 1/4" and solder the resistor to it. Shrink some heat shrink tubing over it and put both leads through the top of the ChapStick platform.
Step 3: Completing the Top Section
Cut the spring from the "N" battery holder (leaving the plastic portion it's attached to intact), and cut a 1/4" section from the bottom portion of the ChapStick. Insert the 1/4" section into the bottom of the platform, (this will help to make the base of the spring more stable. Slide the positive lead of the LED through the center of the spring, solder it to the base of the spring and then clip any remaining portion of the lead off.
Step 4: The Switch
Cut a square in the bottom portion large enough to put the tactile switch through. Position the switch to where the button sticks out just slightly past the bottom. After it's in place, J-B Weld the back side (the portion that goes up into the tube). After the J-B Weld dries, you can trim it up with a razor blade.
Step 5: Wiring the Switch
Scrape any remaining J-B Weld from the terminals of the tactile switch and solder a piece of wire to one end. In the picture shown, I had soldered the wire prior to putting J-B Weld over the switch, but either way will work. Cut a piece of plastic from the "N" battery holder (or anything else you happen to have lying around) and a piece of metal (I used a speaker terminal connector) to solder the other end of the tactile switch to. (You can actually use the bottom of the "N" battery holder for this portion. I messed mine up in the first attempt so I came up with this.) Super-glue the piece of plastic in the center of the leads of the tactile switch, (this will keep the base that the battery sits on from touching the other side of the tactile switch.) Solder the metal piece in place. (The plastic will probably melt a bit, but just make sure it doesn't prevent the bottom of the battery from making contact with metal portion.)
Step 6: Assembly
Put the top portion with the LED (finished in step 3) into the top of the ChapStick tube and push it all the way down until the wire is exposed. Cut the wire attached to the tactile switch short enough to where the length from the spring to the bottom portion is slightly less than the length of the battery when soldered. (This will force the battery to be slightly compressed against the spring and the base when inserted into the tube so that it will make good contact.) Solder the wires together and cover with heat shrink tubing. Slowly push the battery into the tube (which will raise the platform to the top) and snap the bottom of the tube in place and you're done.
Step 7: Let There Be Light!
If everything has gone according to plan, you should have light when you press down on the tactile switch.
And there you have it, the world's first ChapStick flashlight
The Instructables Book Contest
First Prize in the
5 People Made This Project!
  • Remix Contest
    Remix Contest
  • Build a Tool Contest
  • Pocket Sized Contest
92 Discussions
goldgriffin05
2 years ago
I also used a 3d printed end piece.
cth173
3 years ago
This is a great project I made with my students at school. I was wondering if anyone has any ideas for cutting the hole in the bottom for the switch? Mine always end up sloppy.
BCatcth173
Reply 3 years ago
A drill-press might help, or possibly a dremel. Either way it's a little tough with it being so small.
cth173
3 years ago
BCatDouglasS2
Reply 3 years ago on Introduction
Sorry, I picked up my of my supplies at a local Radio Shack and they are now out of business.
obscura
4 years ago
I made a sonic screwdriver using 2 Chapstick tubes and a dried out marker. I think when I remake it I'll make the bottom tube into a flashlight
phiddensices
4 years ago
nice project. I "invented" something similar in medical school in 1995. The equivalent of a doctor's pen light, used two chapstick tubes, small incandescent bulb and battery.
zackboston
5 years ago on Introduction
Our Eek! Electronics Explorers Klub in Boston chose this as their intro to electronics project and all of them successfully completed their flashlight! Thanks so much from the Learn 2 Teach, Teach 2 Learn Program. . . http://www.flickr.com/photos/28629285@N02/sets/72157638758463055
jrivas527
i can't find a 10 mm led light at radio shack. is it possible to use a 5mm led light with the 470 ohm resistor? can it take 12v?
BCatjrivas527
Reply 5 years ago on Introduction
This is a good instructable to help you with your question: https://www.instructables.com/id/Choosing-The-Resistor-To-Use-With-LEDs/
Adambowker98
6 years ago on Introduction
So, in step 5.... I didn't understand the instructions. Could you explain them a little better? I really want to build this.
BCatAdambowker98
Reply 6 years ago on Introduction
I just put a little piece of plastic down, between the two terminals of the tactile switch and soldered a metal tab (on top of the plastic) to one of the terminal connections on the tactile switch. Be careful because the plastic piece can melt. (This is the portion that the negative side of the battery will rest on.) The other terminal of the tactile switch has a piece of wire soldered to it (which you should actually do first.)
Clear as mud?
