Cheap Drill Press DIY
37,119
434
7
I decided to build a drill press for 12$.
I have mostly used design by Izzy Swan he have pretty good build videos: His YouTube Channel
Here You can see the video of my final product : https://youtu.be/Ogf9JVEOmrY
Now I can drill bunch of 90deg holes.. but why?
Thank you,
Step 1: Materials and Tools
Materials:
1.Use your old corded drill or buy the cheapest one:
Example HF coupon for 12$ Drill: coupon
2. hose clamp
3. Scrap wood
4. Wood Screws
Tools
1.Table Saw (Can be done with a any saw, but have to changed little bit).
2. Drill.
3.Safety Glasses.
Step 2: Aseembly
Create a slide by sandwiching wood pieces together.
Use paper as a shims between the wood.
Wax the sliding surfaces.
Step 3: Assebbly
Secure the drill into the sliding carriage.
Take a square and make sure that the drill bit is 90deg to the surface. Use wedges if needed.
Add Handle and a spring to allow better pushing and returning.
    • Gardening Contest
      Gardening Contest
    • Arduino Contest 2019
    • Trash to Treasure
      Trash to Treasure
    7 Discussions
    kukopia
    1 year ago
    All to vague to be of any use
    Yomismo62
    3 years ago on Introduction
    Hello you can clarify complementing your project, such as holding the drill. Since in all three phases you have here, no clarifies
    sagariwa
    thanks. you've been very helpful with your photos and description plus the link to the video. til the next project then.
    handroid7Elliot Lord
    Reply 3 years ago on Introduction
    Thank you,
    The reals instructions are:
    You need to take a look at your drill..make a holder for it.
    You need to buy/make sliding mechanism.
    Attach them together :)
    Its pretty easy to make.. hard part is to alight it and also make it stable.
