Chia Seed Mask
5,337
16
Ch..Ch....Chia. I know you remember the cheesy commercials and I know I am not the only one that secretly wanted a chia pet sheep. But little did I know that the commercial that I saw only during Christmas time when I was kid is now very popular as an adult to use in skin care and to ingest. Ch.. Ch...Chia!
Chia seeds have around since 3500 BC, Aztecs were the first to be known to eat them.Chia seeds are found inside of the flower of Salvia hispanic, a member of the mint family that grows in desert areas.
Chia seeds are high in alpha-lipoic acids. Alpha-lipoic acid is known to help minimize fine lines, wrinkles and enlarged pores, while encouraging healthy cellular function and increasing radiance in the skin. Chia seeds are considered the richest botanical source of omega-3 fatty acids found in nature. The fatty acids encourages the formation of collagen and elastin, which support skin structure and helps maintain moisture levels.
The coolest thing about chia seeds is that when you add liquid they expand, it's like a magic show!!!
This mask is extremely hydrating and can also be used as for exfoliation, after you cleanse your skin put this mask on. Give it a try.
Ingredients
3 tablespoon of chia seeds
2 tablespoons of water
2 tablespoon of honey
1 tablespoon of extra virgin Olive oil
Small whisk
Container
Directions
1) Get 3 tablespoons of chia seeds in a small container and add about 2 tablespoon of cold water into it. Leave the seeds to soak in the water for about 30 minutes. After every 10 minutes mix a little and you will see that after soaking water all the seeds will change into gel.
2) Once the chia seeds are of a gel consistency add 2 tablespoons of honey and 1 tablespoon of EVOO.
3) Whisk together and put on face.
4) You can also rub on skin because it gives great exfoliation or you can leave on as a mask (leave on for 10 minutes).
Supplies:
Step 1: Ingredients
Ingredients
Small whisk
Container
Step 2: Watch Them Expand! Nature's Original Magic Trick.
Get 3 tablespoons of chia seeds in a small container and add about 2 tablespoon of cold water into it. Leave the seeds to soak in the water for about 30 minutes. After every 10 minutes mix a little and you will see the seeds change into gel.
Step 3: Add a Little Honey...... Honey ;)
Once the chia seeds are of a gel consistency add 2 tablespoons of honey, honey will add moisture, it's a great humectant and antibacterial. It will add another layer of softness to your skin.
Step 4: Whisk Baby Whisk!!!
Whisk together making sure the honey and chia seeds are completely mixed.You can also rub on skin because it gives great exfoliation or you can leave on as a mask (leave on for 10 minutes). Wash it off with warm water and use your favorite moisturizer. Your skin will be baby soft.
    • Arduino Contest 2019
    • Classroom Science Contest
    2 Discussions
    Skin Beauty Fairy
    4 years ago
    It feels so soft!! Let me know how your skin feels.
