China Cabinet Lighting Upgrade With RGBW LEDs
302
About: ‚ÄčLocated in Minneapolis, Minnesota in the USA. Designing high quality LED controllers for personal and commercial use. All devices are designed and fabricated in the USA to high standards. With a competent s...
A simple project to improve a cabinet/hutch that was saved from the trash and restored. Its going to store fancy things, so why not add some fancy lights. Both for display of the items and for ambient lighting. This project is quite basic, each shelf has a length of RGB+W 12 volt LED strip, all 3 strips connect to a 4-channel LED controller. The NLED 16-Bit RGBW Lamp Controller, it features 4 outputs with 16-bit PWM resolution, USB connectivity, powerful customizable stand-alone color sequences using the software NLED Aurora Control, and a multi-use rotary encoder for controlling speeds, custom colors, and changing the color sequence. Perfect for stand-alone applications like this.
Northern Lights Electronic Design, LLC has a wide range of products for personal and professional projects. Featuring constant voltage controllers for 12 volt LED strip and a selection of pixel controllers for addressable pixel strips. The in house NLED Aurora Control software can be used to create stand-alone color sequences, or utilize one of the many data methods such as USB, DMX-512, TTL Serial, Bluetooth, or WiFi.
See the current product offerings at: www.northernlightselectronicdesign.com/products/
Supplies:
Step 1: Parts and Supplies
Parts:
Tools:
  • Electronics Tools(Soldering Iron, solder, wire stripper etc)
  • 7/8" Drill Bit
Step 2: Planning and LED Strands
Planned for one length of LED strip per shelf. Placed it near to the back so the light would be less direct outwards. Wires were ran up one side of the cabinet inside black split loom.
LED Strands:
  • Cut 3 lengths of LED strip to fit the shelves.
  • Estimated the lengths of the 3 sets of wires.
  • Used 4-strand ribbon cable for the colors RGBW, and a red stranded wire for the +12v
  • Prepared the strands and taped them up neatly.
  • Test fit and cut the split loom to length.
Shelves:
  • Marked and drilled 7/8" hole out of the back right corner of each of the 2 shelves that were removable.
  • Drilled a hole in the back right corner of the bottom shelf into the base of the cabinet.
Step 3: Installation
LED strip Installation:
  • Starting with the removable shelves, the correct LED strand was attached 4" away from the back of the shelf.
  • Used the permanent aluminum tape to secure the wires down neatly. Positioned towards the hole for the split loom.
  • The LED strand for the top of the cabinet was then installed, and taped neatly.
  • Ran the split loom from the top to the bottom of the cabinet. Inserting the LED strand wires neatly into it.
Controller and Power Supply: The controller will be mounted behind a drawer in the base of the cabinet. The power supply is external. There is no on/off switch for now.
  • A 5/8" hole was drilled through the back panel of the cabinet on the left side for the power supply cord.
  • The controller was wired up to the LED strands as described on the datasheet.
Step 4: Finished
Thanks for reading, please visit our store for Made In The USA LED Controllers and LED Products. And checkout our available Free Software.
Or find more projects that utilize NLED products on our Instructables Profile or the Projects Page on our website.
Subscribe on YouTube to get notified of new videos and projects.
Please Contact Us with any questions, comments, or bug reports.
NLED is available for embedded programming, firmware design, hardware design, product design, and consultation.
Please Contact Us to us today to discuss your customized solution for any LED or communication needs.
    • Party Challenge
      Party Challenge
    • Classroom Science Contest
    • Gardening Contest
      Gardening Contest
