Chopping Board
13,795
159
19
About: Appreciate what you've got, every day will bring something new.
You know, for chopping stuff.
Has a strainer for straining stuff that you chopped
Step 1: Cut Wood
The board is made up of smaller pieces of oak.
Edges a sanded, holes drilled for the dowels, glued and clamped.
Step 2: Cut Out Waste Wood
Run outside edges through a router to round off the corners.
Pencil outline the strainer.
Scroll saw out the strainer hole.
Router the edge to match the inside corner of the strainer. Note how the strainer sits in to the board and is flush with the chopping surface.
Step 3: Finish Up
Router out board where it meets the lips of the sink, to help it stay in place and not fall in the sink.
Sand board with the grain.
Condition wood with butchers block oil.
Go chop stuff.
    • Trash to Treasure
      Trash to Treasure
    • Jewelry Challenge
      Jewelry Challenge
    • Tape Contest
      Tape Contest
    19 Discussions
    HollyMann
    6 years ago on Introduction
    i LOVE this...I would buy one if these were sold in stores...
    ejarrell
    Does it matter about the width of the wood? I notice in your picture you have several skinnier pieces and a few of thicker pieces. Could they all be the same size?
    How did the wood start out? Did you buy it from the hardware store or was it scraps?
    What is your method for getting the holes for the dowels to all line up?
    Thanks!! This is a really great instructable! :)
    thunk
    11 years ago on Introduction
    I've seen commercial boards with a decorative groove near the edge. DON'T do that to yours, otherwise you can't scrape the food easily from board to target (e.g. pot / pan / bin) because it gets stuck in the groove.
    rickharristhunk
    Reply 6 years ago on Introduction
    It's a blood groove or juice groove to take the meat juices off into a pan.
    I always oil my boards with normal cooking oil as I have plenty at home.
    camp6ell
    how's it holding up, now that it's been several months?
    rashfreedom
    12 years ago
    Very nice instructable, you can also use mineral oil which is available at any drugstore and most grocery stores. It will be in the laxative section.
    samrashfreedom
    Reply 12 years ago
    I think you can also get that at bike shops. It is often used for hydraulic oil in disc brakes.
    rashfreedomsam
    Reply 12 years ago
    You are correct but I dont think you can use the drug store kind for your bike needs. I read that it gums up over time. The drug store kind is designed for human consumption the bike stuff might not be.
    samrashfreedom
    Reply 12 years ago
    I agree, the bike stuff, is probably not designed for human consumption, but I have heard it being used as a laxative in a pinch. (on a camping trip)
    sam
    12 years ago
    Sweet! I find that kind of project is really satisfying. The sweet smell of wood and oils... What is butchers block oil? On chopping boards I've made, I used tung oil, is it the same thing? Here's some I made for christmas.
    rashfreedomsam
    Reply 12 years ago
    Tung oil is not the same thing, you do not want to use it on food grade items. Some danish oils are food safe they say on them if they are.
    samrashfreedom
    Reply 12 years ago
    hmm.. I guess its a bit late now, but in the future, I'll get some different oils.
    hatsuli
    12 years ago
    "holes drilled for the dowels"... care to elaborate on that part? :)
    radiorentalhatsuli
    Reply 12 years ago
    I decided to strengthen the board by joining the individual pieces with dowels. Note in the images on the second step each piece has a hole and a corresponding stud, or dowel as they are properly known. The dowels might not be necessary, I make the board to practice a few woodworking techniques.
    Tool Using Animal
    12 years ago
    very well done. but a little skimpy on details if someone's not an experienced woodworker. for instance what kind of glue did you use?
    radiorentalTool Using Animal
    Reply 12 years ago
    Glue: Titebone 3 Ultimate Well, thats what you should use, not what I used. I'm not an experienced woodworker. Tools that will make this job a lot easier router with selection of bits Belt sander Scroll saw table or chop or miter saw. set square pencil Yes you're right on the details, anything else I can fill you in on?
    theRIAAradiorental
    Reply 12 years ago
    outdoor elmers would be fine, the instructions were the perfect length. you could cut slits in the boards to hold more glue.. but that might be overkill
    evy-wevy
    12 years ago
    wow! what a great chopping board! good job!
