Christmas Leftover Rum Balls
984
36
4
It is the same story every christmas...lots of delightful cookies, candy and more. Everyone has had enough of them over the last few days and now they remain there untouched.
What a shame what a waste.
No IT'S NOT; IF YOU REFURBISH THEM INTO GORGEOUS MOIST RUMBALLS ...all ready to go at new years party in a new look.
So lets wave the magic wand:::.......::::::::
Supplies:
Step 1: Materials:
leftover:
cookies
cake leftovers
candy (preferably same flavored)
nuts((unsalted or spiced)
raisins
Nutella(1-2Tbsp)
RUM or Whiskey
a bar of tempering chocolate or melting chocolate chips for the coating
WELL, there is no proportion to the ingredients all depends on what you have at hand, just make sure that the cookie and cake crumbs outnumber the rest of the ingredients.
Step 2:
1.In a small bowl soak the raisins in rum , so that the rum covers them all up- overnight.
2. put the Cookies, candy, and nuts in a ziplock plastic bag seal it and run it over with a rolling pin, crushing all the cookies and candy and nuts into tiny pieces.
Open the ziplock bag and pour out the contents into a mixing bowl.
3. Drain the Raisins and add them to the bowl. MIX
4.Add 1-2 Tbsp of nutella to the mixture.
5. pour the rum into the mixture little by little to completely moisten the mixture. Then using your hands knead it to form a dough like mixture. you can add some more rum if it is too hard. The dough should be formable yet a bit crumbly.
6. using your hands press the dough into small balls and lay them on a greased paper onto a flat plate.
Place this plate in the freezer for them to harden for around 30 mins to an hour min.
Step 3: Making the Final Coating.
Tempering in a microwave:
run over the slab of tempering chocolate with a rolling pin to crush it into small pieces. In case of using chocolate chips skip this step.
put the chocolate bits in a microwave poof bowl and heat on a maximum for 20 secs.
remove and stir.
repeat this process till all chocolate has melted into a smooth clump less batter.
Remove the rumballs from the freezer. and whilst still frozen dip each ball into the chocolate batter with a pincer
or a fork and then place it back on to the parchment paper.
Garnish if necessary with crushed nuts silver balls or sprinkle as per you choice or leave them just plain.
Your family and friends will fall over over in love with the same cookie/candy now soaked and disguised as
RUM BALLS
cheers!!
Step 4:
Remove the rumballs from the freezer and whilst still frozen dip each ball into the chocolate batter with a pincer
See to see that it is evenly coated and covered.
Your family and friends will fall over over in love with the same cookie/candy now soaked and disguised as RUM BALLS
CHEERS!
    • Arduino Contest 2019
    • Classroom Science Contest
    • Woodworking Contest
      Woodworking Contest
    4 Discussions
    RiffifiSunglowart
    Reply 3 years ago
    because it looks yummy, wasn't it enough explicit? :)
    SunglowartRiffifi
    Reply 3 years ago
    Thanks... Of course i did get it. I just made the comment at the wrong place looks like ... Sorry?
