Christmas Sleigh Bell- Polymer Clay (Fimo)
1,765
38
5
Very easy way to make a Christmas Sligh Bell with polymer clay!
Supplies:
Step 1:
Materials used in this project:
- Polymer clay (Fimo Soft)
- 1 small metalic bell
- 2 round cutters of the same size
- 1 styrofoam ball
- Aluminium wire
- 3D Liner
- Varnish (Optional).
Step 2:
Using the round cutter, make a mark on the clay.
Make 4 holes. From each hole make a small cut in direction to the center
Step 3:
Place the cutter over the clay and invert the position
With a styrofoam ball, gently make pressure with circular movements.
Remove the excess of clay around the cutter.
Place a small sleigh bell inside and make sure that it won't fall thru the holes.
Step 4:
For the top of the sleigh bell
Mark the clay with the cutter and make small holes.
Repeat the operation with the styrofoam ball, and remove the excess of clay around the cutter.
Align and join the the two pieces, with the little sleigh bell inside.
twist two rolls of white and red clay and place it around the two cutters, in the center, where the clay is exposed.
Bake it at 110°C/230°F, during 30 minutes.
Step 5:
After baking, remove the cutters.
Make a pendant with the wire.
Finaly decorate your sleigh bell with 3D-liner or with acrylic paint.
You can apply varnish to make it look more shiny (Optional)
Step 6:
Hope you enjoy and Happy Holidays!!! :D
    • Woodworking Contest
      Woodworking Contest
    • Gardening Contest
      Gardening Contest
    • Arduino Contest 2019
    5 Discussions
    Kawaii_kittin
    3 years ago
    So it needs to Fimo soft or can it be any clay ?
    violingirl
    4 years ago on Introduction
    This is great if you don't want bells that are silver or gold.
    seamster
    Whoa, this is impressive work!
    Love the inclusion of step-by-step instructions too! Nicely done, all around. Thank you!
    sandrartesseamster
    Reply 4 years ago on Introduction
    Hi seamster!! :D
    Thank you so much for your nice comment and motivation!!!
    I found out how to pull images from my videos (Thanks to MsSweetSatisfaction!), and now is much more easy!
    I'll edit the other instructables too ;)
