Christmas Story Bunny Costume
109,054
170
73
About: I got an old sewing machine when I was just a kid, and I've been hooked on making stuff ever since. My name is Sam and I'm a community manager here at Instructables.
My brother-in-law needed a costume to wear to his family's Christmas party and asked me to make him Ralphie's deranged Easter bunny/pink nightmare costume.
I couldn't pass this up.
You can buy a similar costume online for $100, but where's the fun in that? This only cost around $30. Plus a lot of hours of course, but it was worth it.
(That's me with my best attempt at an unhappy Ralphie-scowl.)
Supplies:
Step 1: In Case You've Been Living Under a Rock...
Step 2: Pattern
When I sew stuff, I enjoy making up my own patterns.
But making up patterns isn't what most people would consider fun, so I've included a PDF with scale drawings on graph paper of all the pattern pieces, along with some construction details that might be helpful. You'll still have to lay everything out full scale, but I figured someone who was willing to do the work would find it useful.
The body section is just a big floppy jumpsuit, so I didn't need a terribly precise pattern for it. The hood pattern, however, took a little more effort and required some trial and error before I came up with the right shape.
This pattern is designed for anyone around 6 feet or so, and upwards of 200 pounds. Skinny people can adjust it accordingly. Or eat more.
Step 3: Body and Sleeves
The body section is made from two pieces. The pattern is laid out so the sides are on a fold, which eliminates the long unnecessary seams on the sides.
The two body pieces are joined with a seam along the back, down to the crotch.
The two sides of each sleeve are sewed together along the bottom. The half-sewn sleeves are pinned to, and then sewed into the sleeve openings on the body section. (This process is upside down to how most sleeves are attached to shirts.)
A seam is made across the tops of the sleeves and each shoulder.
Step 4: Ears
Each ear is made from two pieces of fabric.  The back pink piece is slightly bigger than the front red piece, but the seams are made keeping the edges even.  When turned right-side-out, this makes the back of the ear curl around the front slightly.
To increase this effect, I added a pleat down the middle of each ear.
Step 5: Wiring the Ears
The ears needed to be adjustable, but stiff enough to hold their shape. To do this, I used some plastic coated copper wire from the hardware store that felt like it had the right amount of flexibility.
About three feet of wire was used for each ear. It was bent in half, inserted into the ears, and lashed in place with waxed dental floss. Hand sewing with waxed dental floss makes things really secure. I'm not sure where I picked this trick up, but I use it a lot.
The two loose ends of wire were wrapped tight with masking tape.
Step 6: Hood, and Attaching Ears to It
The hood pieces are sewn together, with the ears carefully sewn in place as well. These were placed about four inches back from the front.
When the needle got close to the wires, the machine was hand-turned and the fabric adjusted so the needle went over the wires without hitting them.
The inner hood lining was sewn together and sewn in place, but only along the front of the hood.
Step 7: Ear Support Structure
I struggled with this step for a while, trying to figure out the best way to do it.
For the ears to stand up straight, yet still be sturdy and adjustable, I concluded that I needed to make an under-structure to attach them to.
This under-structure was made from stiff cardboard, hanger wire, and masking tape.  The wires from the bottom of the ears were bent as needed to keep them upright, and hot glued to the cardboard piece.
Step 8: Hood Padding
Batting was added to create some padding in the hood and help conceal the cardboard ear support piece. Pieces of batting were spot hot glued around and to the cardboard, and to each other.
The lining was then pulled over the batting/cardboard structure, and the outer hood layer was stitched to the lining along the existing seams. The hood was then closed up with a seam around the bottom.
Step 9: Attach Hood and Zipper, Finish Legs and Sleeves
The hood was attached to the body section, and the front tabs of the hood were trimmed even with the front opening of the body section where the zipper was to be attached.  Then the zipper was installed.
Legs and sleeves were finished. Elastic was added to the sleeve cuffs.
This photo may give you an idea of the beastly mass of pink fleece I was wrangling at this point.
Not pleasant.
Step 10: Fluffy White Tail
A fluffy white tail was made and safety pinned in place.  (It's removable in case you need to sit down.)
Step 11: Mittens
Mittens were made using an oven mitt as a pattern.
Step 12: Slipper Ears
I bought some fake Croc-type shoes at Walmart for the bunny slippers. These particular shoes had fuzzy liners, which were nice.  The liners were removed, and then later replaced once the pink covering was on.
The ears for these were made much like the ears for the hood. These were attached with lots of hot glue.
Step 13: Slipper Covering
After a pattern was made and a practice covering was found to be adequate, covers were made for each shoe. These were stretched and glued in place.
The liners were replaced and glued back in with hot glue.
Step 14: Slipper Details
Bunny faces were added with black yarn, felt, and googly eyes.  That's it!
Merry Christmas!
Grand Prize in the
Homemade Holidays Contest
4 People Made This Project!
  • Gardening Contest
    Gardening Contest
  • IoT Challenge
    IoT Challenge
73 Discussions
dragon fllyer
5 months ago
I hope your brother-in-law appreciates you!
Brian M V
5 months ago
HAHAHAHHA makes for such a great user-thumbnail!!
seamsterBrian M V
Reply 5 months ago
Thank you, my friend. I thought it was appropriate for this time of year! : )
Darlene SA
Question 6 months ago on Introduction
I think you’re bunny costume looks awesome, and I would like to use your pattern to make my daughter’s boyfriend a costume. He is 6‘2“ tall. He wears a 3XL shirt and has a 46 inch waist. How can I modify your pattern to fit him?
seamsterDarlene SA
Reply 6 months ago
I think you might be able to use it as is.. I made the pattern fairly oversized intentionally. It was made for someone about 6 feet tall and close to the dimensions you note. I'm the one modeling it in the photos, at 5'8" and a 42" waist, and you can see how floppy it is on me. It fit the actual recipient just fine from what they reported. Good luck!
WattzE
Question 8 months ago
Hi! Just wondering how much fabric you used overall? Also, where is a good place for me to get a sewing machine? I'm from Canada...
1 answer
seamsterWattzE
Answer 8 months ago
Hi there! In the pattern I attached to step 2, in a note I mentioned that I started with 5 yards of pink fleece.
Regarding a sewing machine I would recommend checking your local classifieds for a used machine. Machines from the 60s through 80s are generally very good machines and can be picked up for very good prices. If you buy from someone who has maintained it well, all you have to do is make sure it sews nice clean stitches. Best of luck!
Max ChristopherW
3 years ago
How long would you say this could take for an experienced seamstress vs. a person who doesn't do this often?
I ask because I may ask someone to do this for me who sews more frequently than I do. But before I ask I want to take a twirl in doing it.
missdiane2
5 years ago on Introduction
I am so glad that you have this pattern for the Ralphy Bunny suit. It looks totally awesome. My son has been after me to make him this costume for years, the thing is he is over 300 lbs and I wasn't quite sure I would be able to make a pattern this large. I have been sewing for years, and made a lot of Halloween costumes when he was a kid, but I always had a pattern to follow and modify. He is over 6 ft tall, will this pattern be large enough for a man of his girth?
seamstermissdiane2
Reply 5 years ago on Introduction
I would think so. It was made to be loose on a guy that's 250 lbs. But if you needed more girth, it could be added when you layout the pattern.
damudguysgal
6 years ago on Introduction
I have almost completed the costume by your pics only til I looked further and you have printable instructions. I am having extreme difficulty with the hood. Can you tell me the width of the hood middle and both measurements you use for the hood sides. This is my first project and I have never read a pattern.
seamsterdamudguysgal
Reply 6 years ago on Introduction
Hi, my pattern is very simple. Each block represents 1 inch. So you have to draw out full-scale pattern pieces for yourself, based on the dimensions I've provided.
Let me know if you still have trouble . . . but you should be good to go if you have some large sheets of paper and a ruler and pencil. Good luck!
This pattern looks amazing!!!!! I would love to make this for my cousins new husband (welcome him to the family ;) ) Unfournatly I am having some difficulty opening the PDF file. Is there any other way of looking at the PDF file or getting the pattern?
So I'm new to the whole sewing thing but really want to try making this for a Christmas present. The person I'm making this for is around 6 foot and 150 pounds. I know you said that the pattern fits someone upwards of 200 pounds, so how would you recommend that I take this in so that it will fit. Sorry for the stupid question, anything you can help with will be greatly appreciated! Thanks for the pattern!
