Christmas Tree Crayons
23,509
291
16
Here's something something you can do with your old Christmas tree to recycle little bit of it. So I first saw these kind of crayon pencil things at the Minnesota Minneapolis St. Paul airport. I thought they were kind of fun so I tried to duplicate them and here's what I came up with.
Supplies:
Step 1: What You'll Need
So the old Christmas tree and some old crayons is pretty much all you're going to need to create these from a material standpoint.
Tools are used were a pair of loppers for pruning trees, drillpress with Forster bits to drill out the pencil holder, regular sets of drills to drill the crayon holes, Sharp knife to whittle the ends when you're done pouring the crayon in and I use the table sander to smoothing out the top and bottom of the pencil holder.
Step 2: Cutting Your Christmas Tree Crayons
So for the stick part you will need about 3/4 inch thick branches from the tree most Christmas trees that's going to be the bottom couple branches. I cut mine off about I would say 8 inches long but depending on what you have you could make them shorter or longer. Picking crooked ones probably won't work as well so trying get straight ones if you can. I then cleaned up the branches of any other things that are poking out the sides of them and so you should end up with a stick something like this. For the pencil holder I took a piece kind of in the middle of the tree. But that depends on how big around you wanted to be and I also cut mine just about 7 inches tall I would say. But again you can customize make it whatever you want.
Step 3: Drilling the Holes
So as you can see in the previous picture you can just pretty much the drill a hole right in the middle. Be careful don't drill your fingers or anything. I just put about 2 to 2 1/2 inches of hole in the top of the stick.
Step 4: Filling With Crayon
I don't know exactly what materials they used in the ones I saw at the airport. It may have been a little bit harder than a crayon so maybe colored pencil type of material but I used crayons because that's what I had. So easiest way to do this would be to melt it in some type of container and then poured in but the way I did it was to put on some gloves light up my propane torch and melt and drip the Crayons down into the holes. A word of caution here crayon when it's melted it is very hot so don't burn yourself.
Step 5: Cutting the Crayon Tip
So as you know crayon is pretty fragile so when you cut the ends to make the pencil tip to crayon tip be very careful cut slowly and deliberately use a very sharp razor knife.
Step 6: Creating the Holder
So you can see here from the picture that I just have a piece of the trunk cut and sanded on both ends. I then took my Forster bits and started working counterclockwise around drilling a hole as deep as I could go, which for my drill press is about 2 inches. When I got done with that around I lowered the bit and get it again for another 1 inch.
Step 7: Finishing Up
So I don't have very good drum sander so I'm going to go to the store and grab another drum sander that's a little bit longer to get to the bottom of this and then I'll sand all the edges smooth on the inside and be done. I hope you enjoyed the instructable.
    • Woodworking Contest
      Woodworking Contest
    • IoT Challenge
      IoT Challenge
    16 Discussions
    tomatoskins
    4 years ago on Introduction
    I love this idea! I The only downside is you can no longer use the built in crayon sharpener on the back of the box. :)
    omikeo
    4 years ago on Step 7
    pretty cool
    gives me another idea, like melting crayon into a used toilet paper roll to make one big psychedelic crayon, thanks, mike
    MU5ICI4N
    awesome! I love the presentation of all of the different colors in the tree trunk. Great use for all of those extra branches!
    young96
    4 years ago
    I bought one of these tree crayola from the same airport you mentioned. I never thought about making them myself. Nice job
    Robin-
    I love the crayons. Very "Flintstone". For those who look for the drill bits the name is actually "Forstner".
    NathanSellers
    4 years ago
    this is cool. great thinking with melting crayons down into the core.
    Sunnysalt
    4 years ago
    Take a wooden dowel and glue or tap sand paper and just attach it to a drill it's cheap and easy to sand deep down
    DIY-GuySunnysalt
    Reply 4 years ago on Introduction
    Sunnysalt - Great idea for sanding the inside of the empty container. And any other inside surfaces on other projects!
    DennisPelle
    4 years ago
    Very cool, and a nice way to present them in the trunk Great work!
    kylegilbert
    4 years ago
    Nice execution of this idea!
