Christmas Tree Shelves
6,476
127
12
About: Analog maker dabbling in digital manufacture
This set of Christmas tree-shaped shelves came about because we have a puppy to whom pine needles are some sort of canine equivalent of catnip and whose behavior around wrapped things inevitably results in rapid shredding thereof. We thought about various solutions for a while, and present tree [sic] came up with this design. It was made using scrap plywood, knocks down for storage, and has close to 6' of linear shelf storage for presents. It can be decorated conventionally, but doesn't need watering...
Step 1: Materials and Tools
You need plywood (5/8" and 3/8") and saws for this project. I used a circular saw with a home-made guide and a miter saw. It was assembled with a nailgun and wood glue and half a dozen screws. Paint for finishing. I had no budget to make these shelves but I did have a lot of left over bits of plywood from other projects and some green paint, so it was a freebie.
Step 2: Design
There were a few constraints for the design. The longest piece of plywood I had was 1640 mm long. The tree had to knock down easily so we could store it. I sketched out a rough plan on paper and refined it using Sketchup. The shelves are 300 mm apart, with the two sides offset by 100 mm. The other piece of plywood I had was 400 mm wide, so that's how deep the tree ended up. The Sketchup file below was close to the final version I ended up cutting out (note: it's been uploaded as a .zip file, because the file uploader doesn't seem to allow .skp extensions any more). The main difference is that the shelves ended up sitting on top of the branches, rather than being fitted inside them.
Step 3: Cut
This was a complicated exercise in careful layout. I measured and cut each piece one at a time, making an effort to minimize waste. The long cuts were made using a circular saw + guide, and the shorter ones with the miter saw.
Step 4: Assemble
If you have a nailgun, the shelves can be assembled very quickly and precisely. Sand once you're done.
Step 5: Add Slots for Shelves
These were made out of a piece of 15 mm ply ripped to 20 mm wide. Two pieces glued and nailed in place formed each slot.
Step 6: Paint and Put It All Together
We painted the trunk and branches with undercoat then 3 coats of some leftover forest green exterior acrylic paint using a small foam roller. Once dry, drill three holes through the middle of each side piece, countersink, and screw the trunk of the tree together as shown. Slot in the shelves - the slope holds them firmly in place without the need for fasteners.
Step 7: Decorate
To stop the tree from toppling, I screwed it to the wall, but you could easily attach a base if you wanted it to be free-standing. Screw small holes in suitable places in the tree, put in small nails, and hang your decorations. Place the presents on the shelves. Merry Christmas!
    • Warm and Fuzzy Contest
    • Paper Contest
      Paper Contest
    • Organization Contest
    12 Discussions
    nl80
    2 years ago
    I love it. I'm seeing it as a kids coloring book, books, crayons, pencils, there shoes on the bottom shelf, next days school clothes on another shelf ( the books would be laying down) a hook on the one side for backpack the other side for coat. Out of 1 to 10, 10 being the best I'd say this is a 10. ??
    makendonl80
    Reply 2 years ago
    Thanks! We still get this out each Christmas, even though our dog is better behaved now
    tcaperton
    3 years ago
    This is awesome! I have 7 cats and CANNOT have a decorated tree. With this, the cats could be ornaments! Thank you for sharing.
    Procrastinateher
    3 years ago
    That is a good looking shelf Christmas tree! But I would have... I'm not sure how to explain it, but imagine those shelves 'upside down' so the sides prevent things from falling off.
    Though that would probably make it a bit more complex if you were to put hinges on the shelves so the tree could be folded up when not in use.
    makendoProcrastinateher
    Reply 3 years ago
    Thanks. I see your point, but I designed it this way so the shelves could easily overflow and so the sides could act as braces. The hinges are a good idea, but would make it a lot more complex. We still put this tree up and knock it down every year and it is holding up well, but you're right in that it could be designed to fold a little more efficiently.
    Procrastinateher
    3 years ago
    Cindy02
    5 years ago
    That's so creative!
    animal lover
    5 years ago on Introduction
    I think you should put racks on the trunk, but other than that its pretty good. :)
