Clamping at ANY Angle
74,031
462
34
About: I love working at the intersection between design, material science, function, and delight! I like thinking about fashion, history, and art, and about how we define ourselves through the objects we make and...
Clamps are a woodworker's best friend... until you need to clamp two non-parallel surfaces. There are specialty clamps for picture frames, cabinet making, and other 90 degree applications but you'll also find yourself facing a 45 degree or 30 degree angle every so often.
When faced with a 45 degree angle, if you're like me, you'll first try to use a bar clamp with a pivoting head. Friction will allow the clamp to work if your surfaces are close to parallel or if your wood is rather rough. Thinking yourself rather clever you'll then attempt a glue-up and the now-greatly-slicker surfaces will slide all over when you try to tighten the clamp.
A scrap piece of wood, a few basic tools, and 5 minutes are all you need to create a custom v-block for securely clamping any angle!
Supplies:
Step 1: Grab a Scrap Piece of Wood and a Piece of Paper
You'll need-
  • A scrap piece of wood (mine was approximatly 1.5" x .75" by 1 ft)
  • A piece of paper
  • A pencil
  • A saw
Optional-
  • Power Drill
Step 2: Create a 45 Degree Angle
Fold the piece of paper to form a 45 degree angle. Lift one corner along the short edge of the paper and bring it to the opposite long edge, lining up the short edge of the paper with the long edge.
Note: This is a great trick to quickly check angles around your workshop. Often a folded piece of paper is better than a metal angle when checking the alignment angle of a blade (which might be knicked) or reaching in between delicate components.
Step 3: Mark a 90 Degree V
Line up one edge of your 45 degree angle with the bottom edge of the scrap board. Mark with a pencil along the folded edge (you could also use the other edge of the 45 degree angle but the pencil will travel better against the fold). Flip your template over horizontally and mark a second line.
Make sure that the intersection point between your first and second line is approximately in the center of your scrap board. If the V shape is too deep, your block might split later under clamping pressure.
Step 4: Mark the Edge
Draw a straight line so the V shape will be approximately in the middle of the final block. If you love exact angles, you can use the corner of your piece of paper to draw a vertical line 90 degrees from the bottom edge of the scrap board.
Step 5: Optional: Drill at the Intersection
Use a drill to make a hole at the intersection of your two 45 degree lines. I used a 3/16" drill bit but you can use whatever looks proportional to you. The hole creates clearance space at the intersection of the V block and will help protect delicate corners (especially mitered corners that are slightly off).
Step 6: Cut Out the V and Cut Off the V Block
Use a saw to cut off the section of your scrap lumber that will become the v block. Mine ended up being a little over 3 inches but yours will vary depending on the depth of your V and desired angle. Next, cut each side of the v shape. Be sure to keep your blade on the inside of your pencil lines to make the drilled hole as effective as possible.
Step 7: Clamp at 45 Degrees! (or Any Other Angle)
Clean up the edges of your v block with some sandpaper and clamp away!
You can use this technique to make a custom v block to clamp against any angle with a little math (or a protractor).
I'd love to see your results if this helped you out!
Happy making!
    • Fandom Contest
      Fandom Contest
    • Arduino Contest 2019
    • Party Challenge
      Party Challenge
    34 Discussions
    Willyco2608
    2 years ago
    great, thanks for sharing
    Raitis
    2 years ago
    Been thinking about making something like this for a while. How does it hold up when clamping a diagonal that long? Doesn't it spread the walls apart anyway?
    marteen1Raitis
    Reply 2 years ago
    You can simply make a larger version off her design, so it has more 'backing' on it. Basically, if the backing goes up higher, you'll have more of a plane to brace against. Good for larger projects or for wood that is flexible (which would require a rigid backing).
    As of now the backing is a bit low, but that is all that she needed in this case. Her cuts of wood are straight, rigid, and she double-checked with a square.
    mikeasaurusRaitis
    Reply 2 years ago
    Just add another clamp on the diagonal to keep it all together.
    Clamps on clamps on clamps! :)
    Raitismikeasaurus
    Reply 2 years ago
    Of course, exactly why there are never enough clamps in the workshop!
    marteen1 - sure, yet then there's the thing of stock size needed to cut such a thing. I think I have one idea in mind though - a bigger version with steps for clamsp should work.
    robbadooz
    2 years ago
    Great idea! Now, why didn't I think of that? Thanks!
    danzo321
    2 years ago
    In regular woodworking, you secure the diagonal piece with glue plus 18 ga nailgun. If you clamp a diagonal into a 90º, you have to be spreading the angle. The angle blocks are great but not in this construction.
    marteen1danzo321
    Reply 2 years ago
    You think so? This is the perfect time for the angle blocks.
    The vertical wood piece would have to bend before that angle would spread. And if it was to bend, then your clamping it too hard.
    danzo321marteen1
    Reply 2 years ago
    And it strikes me that any but the lightest clamping will bend the 90º to 93, 95, 97º.. Keep a good square on the angle and give it a try. You might also create a double hooked piece that prevents spreading. Could also place the rt-angle assembly facedown on a piece of plywood with wood strips hard against both sides so it can't spread.
    marteen1danzo321
    Reply 2 years ago
    Double-hooked is a great idea too, I like that! Never one way to do things.
    I get what your saying, but clamping 90 degree will not spread with a proper backing/support, because it can't expand/spread if there is something backing it on both sides of the vertical/horizontal planes.
    inchman
    2 years ago
    First, this is a neat 'ible. But I really LOVE the idea of using paper for the angles. That is worth the 'ible by itself!
    Thanks for sharing.
    mikeasaurusinchman
    Reply 2 years ago
    It's the simple things. I love tips like these!
    mbonifax
    2 years ago
    Thank..
    So easy... so well explaned... so usefull..
    redcanary16
    2 years ago
    A nice, simple fix for an awkward clamping problem. As someone pointed out below, in the the clamping example shown it would indeed be advisable to clamp the two perpendicular boards so that the force created, whilst tightening the diagonal brace, couldn't push them out of square. That's not because of any deficiency with the corner clamp of course as any pressure applied in this way would act to force the members apart.
    Anyway, it was also very pleasing to read an eloquent instructable - call me sad if you will, but a good grasp of grammar and proper punctuation pleases me enormously! Thank you for sharing. ?
    john171
    2 years ago
    Very nice 'ible....BTW, that hole also helps relieve the pressure and keeps the block from splitting. As for spreading, make the block a bit bigger for those larger glue ups. Seal them and tag with the angle
    muadibe
    2 years ago
    A very useful tip, Thank you.
    CharlesAndSue
    2 years ago
    Great tips. Sometimes the simplest things are the best. We'll done. The clearance hole is a great idea for better corners.
    HeatherT4
    2 years ago
    Thank you! What a great tip!!! Way cheaper too. What do you think of putting a finish on then so they resist glue?
    mikeasaurusHeatherT4
    Reply 2 years ago
    Not a bad idea. An alternative would be any think sacrificial piece, like wax paper or even lining it with thin sheet metal.
