Classic Homemade Toothpaste
7,433
233
24
About: I like to tinker. I'm a co-founder and active participant of my local hackerspace: Hack42 in Arnhem, the Netherlands. You can also find me on BookCrossing.com under the name Moem.
Why would you want to make your own toothpaste? Plenty of good reasons...
  • It's cheap.
  • You have full control over the ingredients.
  • It works really well. Leaves your teeth nice and clean.
  • It's great for your gums. No more redness or irritation!
  • Coconut oil is naturally anti-bacterial.
  • You're sticking it to The Man by not buying commercial rubbish from multinationals.
  • You don't like store-bought toothpaste, for one reason or another.
  • It's cheap.
And finally...
  • Because you can.
Of course, Scoochmaroo posted a great recipe for fancy toothpaste that is rather a lot like store-bought. But some of us prefer the good old classic baking-powder-and-coconut-oil approach. So this is a pretty basic, glycerine-free recipe. The choice, as always, is yours!
Step 1: What You'll Need
Here's your ingredient list. It's nice and short.
  • Coconut oil
  • Baking soda (I used the famous 'Body Part and Tool'-brand)
Optionally:
  • Peppermint oil (or other fragrant and food safe oil)
Even more optionally:
  • Blue food colouring
  • Wodka, if using food colouring in powdered form
Why the peppermint oil? Because it tastes nicer.
Why the food colouring? Because as we all know, anything blue cleans better.
Of course, none of these embellishments are needed. They're just nice, if you like that kind of thing.
Finally, you'll need
  • something to put it in. Glass or ceramics = good.
Step 2: Melt Stuff
Put your container, if fireproof, on a heat source. If it's not, use a small saucepan.
Add coconut oil. A little bit less than half of what will fit into your container. Heat on low heat until it's mostly liquid; then, shut off the heat and stir with a fork.
Step 3: Add Stuff
Add baking soda in a more or less equal amount to the coconut oil. Stir well.
Add up to about a teaspoon of your chosen flavouring, and stir some more.
Step 4: Add More Stuff (if You Want)
Mix the food colouring (if it's powdered) with a spoonful of wodka. You don't need much. It's just for fun anyway.
Add it to your mixture. If your food colouring is liquid, just pour some in. If you want to of course.
Step 5: Mix Stuff
Stif your mixture until it's all the same colour. Then allow it to cool. Before it's completely solid, give it a final stir.
What more can I say? Yes, it really is this simple.
This toothpaste is solid at room temperature, depending on your climate. If you find you cannot scrape some out of the jar with your toothbrush, find a cute-looking little spoon. Yes, I tried adding water; it did not help.
Enjoy using your home-made toothpaste! I'm sure you'll like the clean feeling it leaves behind. If you feel that you must have fluoride* you can always add a suitable mouth wash to your dental routine.
*This is controversial and highly debatable and I don't actually want to get into that debate, so I'll not state my own preference here. I'm just mentioning it as an option.
  • Trash to Treasure
    Trash to Treasure
  • Jewelry Challenge
    Jewelry Challenge
  • Tape Contest
    Tape Contest
24 Discussions
TaintedxxBright
2 years ago
I make this all the time, but add Xylitol for sweetness and calcium powder to remineralize your teeth and prevent cavities. I don't put any blue colouring in it tho.
parisusa
3 years ago
I use coconut oil for my hair & skin daily. I had no idea I could use it for my teeth! (And of course it's highly popular for cooking). Also, thanks for the side note on fluoride. People should talk to their dentist about this (depending on individual ages/health/community water supplies). Thank you for this thorough Ible!
Moemparisusa
Reply 3 years ago
Thank you for your kind words, I'm glad you like my I'ble. Coconut oil is great, isn't it? It has so many uses.
FarmLover
3 years ago
Btw, your pictures are really good! It looks quite nice!
MoemFarmLover
Reply 3 years ago
Thank you! I figured that something that is supposed to go into your mouth should at least look somewhat appealing.
FarmLover
3 years ago
How long does this keep in a container like yours? And how long will it keep in an air tight container?
MoemFarmLover
Reply 3 years ago
Honestly I wouldn't know. I've never tried to keep it, I make it when I run out and start using it right away. It keeps at least a couple of months, for sure.
FarmLover
3 years ago
MoemSabrinaN1
Reply 3 years ago on Introduction
No, there is no soap in this recipe (which is what makes commercial toothpaste foam) so it will not foam.
JitendraT1
Hi, I live in dubai where normal temperatures are above 35 C. So will this tooth paste become liquid at room temperate?
MoemJitendraT1
It would be thinner than at lower temperatures, for sure. You might want to keep a little spoon with it so you can give it a good stir before use.
One80Bits
3 years ago
he he 'wodka'... Love it!
bi barb soda and triple distilled wodka mixed into a paste is apparently brilliant for a skin cleanser... half way through shower, turn off water, scrub up and then resume and rinse, then spend at least 15mins in some sunshine to get a healthy dose of vitamins and goodness! Cleopatra's trick or somethin!
I've used variations of these ingredients for few years now for all sorts of home replacements, thanks for sharing such an aesthetically pleasing recipe :-D great job
NathanSellers
3 years ago
Awesome. I've been using just straight baking soda because it cleans so well. Now I can have the taste not suck. Thanks.
MoemNathanSellers
Oh yes, this will taste better for sure, and the coconut oil is great because it kills bacteria. Some people believe that it also makes teeth whiter and stronger.
Moemantp
I can tell you names of stores, but I don't know whether you can find those stores because I have no idea where in the world you are. In my country I can find it at some supermarkets and in stores that sell Asian foodstuffs.
MoemMoem
Also the kind that I use does not have any flavour or scent at all.
