Cleaning PVC Pipe (the EASY Way)
40,939
21
Have you ever tired to clean PVC Pipe?  It's not an easy job.  My recent project called for 200 Feet of PVC Pipe.  I had plenty of time to experiement.  I tried Pipe Cleaner, Acetone, Sanding, Steel Wool, and Paint Remover.  They worked, but it required a lot of time and effort.  I kept thinking that there must be an easier way.
Step 1:
The best method that I found was to start by wiping the lettering with Goo Gone.  Just a light coat is all that is needed.  Then go to Step 2.
Step 2:
Using a second cloth, clean the lettering with Acetone.  You will need to scrub a little and the lettering will wipe off.
    • Tape Contest
      Tape Contest
    • Jewelry Challenge
      Jewelry Challenge
    • Trash to Treasure
      Trash to Treasure
    2 Discussions
    Aaaecm
    Tip 6 months ago
    Thanks for posting. This is just the information I need right when I needed it. I let the Goo Gone set for about half an hour and used the tiniest bit of acetone. The pipe is clean and shiny. Again, thanks.
    darrenhall
    5 years ago on Step 2
    we use olive oil - cos that pesky writing drives me nuts - smooth clean pipe is super smart, all that text can ruin a project.
    Good instructable - the more ways of getting that writing off the better
