Coffee Bean Earrings
5,404
69
14
Peak up your ears with super-cute coffee bean earrings : )
Step 1: Materials and Tools
I'm not always a fan of shiny silver jewelry, but in this case, bright silver sets off the coffee bean more nicely than a matte or gunmetal finish.
Materials
2 Coffee beans
2 Crystal beads (4 mm)
2 Silver hook wires
2 Silver bails
2 Silver headpins or wire (20 gauge)
Finish
Shellac (or another type of finish if you prefer)
Denatured Alcohol
Wire
Tools
Dremel with 1/32" bit
Rounded pliers
Wire cutters
Metal file
Step 2: Drill Beans
Use Dremel to drill tiny holes close to the end of each bean.  Even if you are very careful, plan on having a few break!
Step 3: Shellac
Adding a finish to the beans will not only add a shine, but will also preserve and strengthen the little guys.
  • Mix shellac with denatured alcohol, stir and allow to sit for a few hours before using.
  • Hang each bean from a thin wire and dip into shellac
  • Allow to dry for 20 minutes and dip again
  • Repeat 3 - 5 times
Step 4: Crystal Bead
  • Use round pliers to shape one end of a headpin into nearly a complete circle
  • Add crystal bead
  • Cut
  • File end if needed
  • Shape other end - leaving the circle a little bit open for the next step
Step 5: Assemble Earrings
Simply connect all the pieces...
  • Place piece from Step 4 on hook
  • Attach bail to the other end
  • Hold bail with pliers and line up with the hole drilled through the coffee bean
  • Gently close bail with pliers, leaving enough space to allow bean to move a little
Complete!
    • Sweet Treats Challenge
    • Organization Contest
    • Warm and Fuzzy Contest
    14 Discussions
    miaowimacat
    6 years ago on Introduction
    These are so cute!! :D I wanna try making them for my mom, but I can't figure out about the bails, do you know another name for them or something? I'm Danish, and I really can't figure out what they're called... Can't even find the right things when I look at English sites?
    kyashimiaowimacat
    Reply 2 years ago
    they are called pinch bails and you can find all kinds on ebay
    kyashimiaowimacat
    Reply 2 years ago
    http://www.ebay.com/itm/100-Small-Little-Ice-Pick-Style-Pinch-Bails-W-6mm-Legs-Plated-Brass-Base-Metal-/191495952449?var=&hash=item2c960c5841:m:mLysDZ4fiWZTfr_ogtvaZfg
    The earring are really cool! I know a few people who will love them. But I have to say, I love the mug! Good to see other supporters of Democracy Now!
    breumer
    Here the are ! The are awesom thanks for sharing !
    That would be easier, I just like shellac : )
    If using nail polish, I'd hang them up to dry rather than set them out, so they won't stick.
    kelseymh
    7 years ago on Introduction
    Very nice, clear and complete instructions!
    I have one small question about the final assembly. You recommend putting together the whole earring chain first, then crimping the bail closed over the bean. Would it be more difficult to attach the bean to the bail first, then chain everything together?
