Coffee Can Forge
75,520
830
33
I know that this isn't an original idea, but it is something I have wanted to do for a long time. Given I don't really have the space for a real forge I thought this would be a good place to start some metal-crafting.
Things you will need:
Coffee can (I used a small one)
Couple of bolts, washers and nuts too.
Drill and bit to make hole the size of your bolts (also a step bit to make the hole for the torch.)
Scrap piece of metal for base
Plaster of Paris
Sand ( I cannot stress enough the importance of sand)
*I am going to assume that all of you on this site are competent human beings and do not need to be reminded to wear your PPE (Personal Protective Equipment) i.e. safety glasses and such. Then again we should never underestimate the power of the idiot to slip in here and do something foolish. So......... Wear the proper safety equipment and use your tools safely. PSA over.
Supplies:
Step 1: Attaching Coffee Can to Base
You will need a base to keep your coffee can upright while heating. Find a piece of scrap that is big enough to support the can plus 5 pounds. I recommend some channel or square tubing.
Decide where you want your holes on the coffee can and mark that distance on your base. Drill the holes to accommodate the bolts you will be using. I used 1/4" no need to go nuts here.
Once the holes are drilled, attach the can to the base with the bolt heads inside the can. I used lock washers, because I didn't want to have to worry about the bolts coming out of the base and making a hot melty mess.
Step 2: Adding the Torch Port
I used a 1/2" pipe for the torch port.
To accommodate the 1/2" pipe I used a step bit to drill through the coffee can.
Just thread the pipe in and mark where you will need to cut it off. I only left about a 1/2" inside the can and 1/4" outside.
Now the hard part is over.
Step 3: Plaster the Inner Walls.
To plaster the inner walls I used a ratio of 1/2 Plaster and 1/2 sand with just enough water to get a good mixture (about the consistency of play-doh.) Line the bottom and inner walls with about 1/2" of mixture. Try to smooth it out as much as possible. Clear the torch port of any plaster debris and you are done.
If you got the mixture right, there is no need to wait. You can insert the propane (I used MAP) into the torch port and heat away. It will take a while for the plaster to cure, but when it does it will get red hot.
Remember to use heat protection when using this thing it is small but very functional. Also the can will still get hot. I am thinking of adding some fiber insulation around it. Good luck and be safe!
  • Woodworking Contest
    Woodworking Contest
  • IoT Challenge
    IoT Challenge
  • Fandom Contest
    Fandom Contest
33 Discussions
Joe_M
4 years ago on Step 3
I would like to see it in action, and what you make with it. I wonder how big it can be and still use the map gas torch. I also wonder if there is a cheaper way to heat it, as map gas can be expensive , depending on how long it takes to complete a a singe job. Please post your first project so I can see it in operation. Thanks for sharing.
Lithim.Joe_M
Reply 2 years ago
i upsized the design to a 10 litre steel bucket and it works great! Of course i ditched map gas and made it a bintōchan (japanese charcoal) heated forge
brentreissman
DO NOT USE A GALVANIZED STEEL CAN. These can cause poisoning if not insulated well. Also i recommend spending the extra money to get refractory cement.
Lithim.brentreissman
Reply 2 years ago
i upsized the heck out of this design and used a 10L galvanised steel bucket and ive never caught metal fume fever, i just use alot more of the sand plaster stuff for insulation (i only need a small area because i use it as a blacksmiths forge, and this basically just holds burning bintōchan)
janharmbrentreissman
Reply 4 years ago on Step 3
..Why not? I can't see much harm in that, since it is a very, very tiny bit of Zinc- which is not a very poisonous metal at all.
brentreissmanjanharm
because its not just zinc. I use zinc for casting and its not bad, but if galvanized steel becomes too hot gaseous zinc oxide can come off and THAT can cause zinc poisoning. Please look up zinc oxide poisoning. I don't want to see anyone get sick (you'll recover, but it sucks)
I also could be wrong but I believe that coffee cans are tin-plated and not galvanized. I say this because I've used plenty of steel cans to make forges and have never had zinc fumes from them. I have, on the other hand, had zinc fumes from pipe nipple. Even if it were galvanized, it's such a small amount that you'd have to be in an enclosed space(which is stupid) in order to breathe in enough for it to be a problem.
Just pre-burn off the zinc plating before serious use. The dangers of zinc poisoning from this sort of thing are vastly over-stated anyway; fume fever also isn't permanent. Very elementary precautions(ventilation, mask, etc) prevent this sort of thing anyway.
JacobA5
I'm just spitballin' here, but what about cutting out a "window" in the bottom of the can and adding a swing door on it so you could make larger pieces? Also, if you can add threaded insert where the torch attaches, I imagine it would be just as easy to connect a hose for the liquigas of your choice. Very cool concept jannetty16!
janetty16JacobA5
Reply 4 years ago
Do whatever you want to make it yours. that is why i keep coming back here. sometimes someone's design is just the spur i need to make s project sit my specific situation. just don't stop crafting.
ToggleSwitchJacobA5
Reply 3 years ago
Although this could be a great idea making a "window" could let a lot of the heat out but if your need is heating longer pieces then maybe you could try connecting two cans for the forge
johnnybravoesq
3 years ago
How large a can will this work with using a standard propane/butane mix torch?
janetty16johnnybravoesq
Reply 3 years ago
I'm not sure
I had to enclose the end somewhat to get the temperature up to a desired level
janetty16throbscottle
Reply 4 years ago
I don't see why not. I think aluminum melts around 600 C I haven't measured how got this gets.i simply use it to harden temper knives I have made.
amberrayh
4 years ago on Introduction
Be safe is right! Have you seen this video?
https://www.youtube.com/watch?v=A796N_YZTm8
Wear a face shield, gloves, apron, whatever you can get your hands on... that being said. Great 'ible! I hope we see many more from you in the future!
