Coffee Table With a Secret Motorized Compartment
28,456
307
47
About: Discover woodworking, concrete, LEDs, home decor and DIY projects you'll love.
For a while now I wanted to create a piece of furniture that moves. I didn’t have a preference for the level of complexity I just wanted to create something. I am a huge fan of having a simple space and keeping things I don’t use everyday hidden. When I got my hands on this 4K Projector the light bulb in my head when off! This was my moment to do something cool and hopefully different! I searched the internet for hours looking to see if this concept existed, I found nothing. Now, that doesn’t mean something of its kind is not out there somewhere, I just didn’t find it. So, it was time to sketch up something. This was the second design I came up with. I had many ideas for this, but I needed to watch my time and not make it be a project that takes a month to produce. After scaling back the design, I drew it up and took the cut list to the shop to get started. If you want to follow along I have detailed set of plans here.
To get more cool projects, subscribe to my youtube channel.
Materials Used:
(2) Sheets of 3/4 plywood
(1) 1 by 2 Select pine
(1) 1 by 4 Select pine
Furniture Feet
Magnetic Catch
Vinyl Wrap
Drawer Slide
Electronic Parts:
Actuators
LED Lights & Power Supply
LED Channel Kit
Wireless Receiver & Remote
Step 1: Getting Started
Anytime I am in the shop it’s a great day. Although I don’t like to break down plywood, it’s a part of the process. I think this stands true with anyone that has a shop with limited space. After using the circular saw to break down the plywood sheets. I took the rough cuts to the table saw for a more precise cut. You can use a circular saw for the entire build but it’s much more time consuming, but possible.
Step 2: Gluing Up the Moving Part
I started off by building the moving section of the coffee table. The majority of this coffee table was double paneled to have a thick appearance. I am a little on the impatient side when it comes to gluing so I normally use a nail gun for a quick hold then add clamps.
Step 3: Build the Fixed Part of the Coffee Table
Again, I doubled up on each panel, the areas that were going to be visible I made sure I didn’t over do it with nails. With the side and bottom are taken care of, I needed to pull out the pocket hole jig, to make a few holes. Next, I secured the inner panel using pocket hole screws.
I then went on to cut the drawer slide support profile. The slide was later relocated to the inside. Wrapping up this area, I added the final piece to the top.
Step 4: Cutting the Access Panel
I added a divider in the middle, that created an empty space which will allow me to hide the pull-up outlet. I then installed the tapered part along the top, this really added depth to the design. Next, I drilled out the hole for the outlet, this is totally optional I just love the idea of having power nearby. Then it was on to cutting out the hole for the access panel. I also cut a hole down below for the power cord to pass through. Finally, I closed off the end.
Step 5: Adding the Modern Profile
After spending time-fighting with the drawer slide location and aligning, I finally got it worked out. It was a relief to overcome the challenges I was facing. At this point, I was behind on the time I had planned for this project. Times like this you can easily get discouraged, but I always look for the quick win to get me pumped up again. That quick win came right after I sanded it down and applied bondo. The first coat of primer did it for me, I was seeing the state of the wood box change and I kicked it into gear; pacing for the finish line.
Note: For a more durable surface and wipeable surface I used a white gloss oil based paint and primer.
Step 6: Applying Vinyl
Not going to pretend to be an expert in this area, but that won't stop me from trying. With a little trial and error, I eased my way through this. You must make sure the surface is clean, that’s the first heads up. To get started, work your way from one side to the next, then address the complicated areas a piece at a time. I really like the finish look of this vinyl it’s much thicker than the usual.
Step 7: Adding the Electronics
There are so many things happening here, I covered this in greater detail in the plans. In short, I installed the actuator in the center of the table. I secured the end with the motor to the bottom with a nut and bolt. On the opposite end, I used this bracket with a piece of 1/8in plate as a way to secure it to the part that moves. The actuator was wired to a 4-channel wireless receiver which I also wired in the LED strip. I would suggest using a LED Kit as a standalone device so you can control each color. The LED were installed in a channel for a cleaner look. If you feel like you are going to do some LED projects down the road I would say grab the channels otherwise you can get by without them.
I also added the pull-up outlet and installed the chrome feet.
Step 8: Final Touches
To close out this project I added a set of magnetic catch to the cover panel for easy access. If you noticed I also wrapped the cover plate to make the access panel blend in, I know I didn’t show it but you will need this double-gang cut in ring to mount the plate. Of course, you can use magnetics if you want to eliminate the screws. Not a big deal for me.
Step 9: My New Setup
Reaching the finish line was a very exciting time for me. Through all the trial and errors I can now say that this was a success. Bringing ideas to life is what it’s all about, I look forward to the next design challenge ahead. If you want to build your own you can now have the coolest coffee table on the block.
I do expect my setup to grow a little over time, but for the time being here is what I have.
Current Set up:
4K Projector
Sound Bar & Sub
Sound Bar Rear Speakers
Amazon Cube
PlayStation 4 Pro
More to come….
I hope you find this post helpful. If so, I would love to hear what you think about it. Let me know if you have any questions and thank you for stopping by, and check out my links below to stay up to date and see what’s next to come.
You can also find me here:
Youtube
Instagram
Pinterest
My Website
Safe and Secure Challenge
Grand Prize in the
    • Epilog X Contest
      Epilog X Contest
    • Remix Contest
      Remix Contest
    • Weaving Challenge
      Weaving Challenge
    47 Discussions
    tond2
    4 weeks ago
    Amazing, the only problem to make here is the money to buy this projector! lol
    So Gorgeous, congratz!
    LucianT6
    5 weeks ago
    I love this table, makes me want to build something motorised like that.. So smooth sliding, woah.. Great job, thank you
    sdlnyc
    5 weeks ago
    Impressive, all around.
    nellbacala
    5 weeks ago
    Ooh, I love love love this project. I wish I can make this for my own! Definitely saving this one and make it a goal to do this in the future. Thank you for sharing your idea!
    cschlager15
    6 weeks ago
    Amazing! I really love the idea/design and the aesthetic is spot on! Great Work
    misterxp
    6 weeks ago
    Thanks for sharing! It is a really great idea and great design. I really liked your instructable too! At first I thought it was just another coffee table but, when I started to read the instructable I was amazed.
    EdwardH94
    6 weeks ago
    Awesome Job! Really amazing table. Love the details. You are truly good at what you do!
    timdekker1825
    6 weeks ago
    Wow! That's one fancy coffe table ;) nice job!
    Makerneer
    6 weeks ago
    Great video, thanks for sharing your build!
    Chaoslord66
    7 weeks ago
    This is very very cool. Kudos on a really neat build!
    YaënD
    7 weeks ago
    Waooouuuhhh man you're a damned good super genius. really awesome job.
    I love this and wanna have a house just for your DIY.
    Sandy Eggo CNC
    7 weeks ago
    Very cool. Great pictures, video, write up and execution. Let the idea theft begin!
    TimothyH102
    7 weeks ago
    One of the most methodical, well edited, and well narrated projects I have ever seen here. Totally impressed by your skiils and patience!!
    wkparker
    7 weeks ago
    Very slick! Nice looking table and great use of the actuator.
    bighurtx
    7 weeks ago on Introduction
    This was quite impressive.!!!!
    Do you have an extension cord on the floor to power your outlets?
    diycreatorsbighurtx
    Reply 7 weeks ago
    Thank you, No I have an extension cord ran under the rug.
    jtalvy
    7 weeks ago
    Really beautiful work! Love the "Where I'm at" images you added to the video.
