Compost Heating System
122,345
513
61
The Pain Mound is a large pile of woody biomass, aka mulch. Invented by French farmer Jean Pain in the 1970s, it is made of woodchips and sawdust, surrounded by a ring of hay bales for structure and insulation. As the Pain Mound decomposes, heat is produced and harnessed using a hydronic loop. The Pain Mound will produce heat for up to 18 months, after which time the remains (nutrient rich, earthy humus) can be used to build soil.
Supplies:
Step 1: Lay Out the Mound
Stake out a circle approximately 12 feet in diameter. Purchase hay bales from a local farm, collect fallen trees and branches, and rent a chipper. A load of sawdust can usually be procured from a local sawmill: they will often deliver for a nominal fee.
Step 2: Create a Hay Bale Backstop + Add Aeration
Lay about 15' of perforated 4" tubing at the bottom of the mound, with each end protruding out of the perimeter. Create a "backstop" of haybales to catch the woodchips as they are thrown from the chipper into the mound. Chip a layer of woodchips approximately 1' high into the mound on top of the aeration pipe.
Step 3: Lay the Hydronic Loop
Coil 1/2" plastic pipe at the bottom of the mound and hold it down temporarily with cinder blocks. Run the end of the pipe outside of the ring of hay bales, to be connected to your water source.
Step 4: Chips and Sawdust!
Chip wood into the pile, intermittently stopping to throw shovelfuls of sawdust in. The high carbon content of both materials create a lot of heat when decomposing.
Step 5: Continue Laying Water Pipe + Building Up the Mound
Once you get started, this project should take 1-2 days of labor. Keep looping in water pipe and building up the hay perimeter as you add woodchips and sawdust. Throw in some manure - any animal will work - if you have any.
Step 6: Fill Line With Water
The Pain Mound can be used to heat hot tubs, greenhouses or hydronic heating systems. Plan out your location carefully ahead of time so that you are close to the thing you will be heating. In the diagram shown here, we hooked up a pain mound to a greenhouse. We buried the water lines so that we would not lose additional heat to the outdoor air.
For more information, CompostPower.org has an excellent detailed installation guide, which can be found here: http://www.compostpower.org/node/24
Step 7: Track the Heat Output
If possible, consider including a series of temperature sensors with your water pipes, so that you can track the BTU output along the way. Our mound produced more than 6 million BTUs over a period of 12 months, including a freezing New England winter.
Collaborators: Garth Schwellenbach and Jesse Selman
  • Fandom Contest
    Fandom Contest
  • Classroom Science Contest
  • Party Challenge
    Party Challenge
61 Discussions
bulau65
4 years ago on Introduction
Piles of compost can catch fire spontaneously! Watch out when storing compost too close to your house.
TomK208bulau65
Reply 3 months ago
Piles of fresh hay can catch fire too. That's why they salt the hay down when they stack it up on the barn. The salt draws out moisture and slows down bacterial heat production.
katrinaspadebulau65
Reply 4 years ago on Introduction
You are right! Some towns have a minimum height of 8' for compost/mulch piles, for that reason.
adillbeckkatrinaspade
Reply 4 years ago
That makes a little more sense. I just didn't know if there was some weird trick with heat dissipation in large piles or something. Contemplating making a fairly small one and putting it inside of a make shift greenhouse. Basically just plastic over a dome... Curious if it could keep it warm enough to start seedlings in the garden in late winter/early spring on Michigan. I don't have the space/money to make a big pile and get the pumps and pipe run.
beastcoast94adillbeck
The heat output should be sufficient but you must be mindful of the gaseous anaerobic decomposition byproducts. Concentrations can become too high and kill plant life.
stephencarlsbad.beastcoast94
Reply 4 months ago
It only goes anaerobic if its too wet and the heat dies off. If that happens, stop watering and mix fresh material into the center of the pile. You should always check your pile's core heat on a daily basis anyway.
This will tell you if you need more moisture or if you have too much or if you need more carbon-based materials etc.
mikaelvisby
2 years ago
Loooove you great instructions!!!
Still...whats the ideal size of the woodchips?
mikaelvisby
2 years ago
And....two more questions:
The wood chips shoud they be made from fresh trees or "dead" threes or maybe it doesnt matter?
How much and water did you add and did you do it all the time or just "like" each 10' or so....
TomK208mikaelvisby
Reply 3 months ago
Fresh trees, as fine as you can chip them, pre soaked before piling them.
Jan-OlovW
Question 1 year ago on Step 4
If I am right in my thinking is there a possibility to use other materials, such as autumn leaves, although they do not produce enough heat for as long as the wooden material, right?
1 answer
TomK208Jan-OlovW
Answer 3 months ago
You want a VERY hot pile. By the time leaves fall they are only good to add carbon to a pile but Pain used freshly harvested wood chips, double processed to make them finer, soaked in water and THEN piled up so that the moisture would activate bacterial action in the highest amount of surface area. I tried hot fresh pig poo this fall, before reading about Pain, but due to other "design flaws" ended up with high amounts of damaging gases that shriveled leaves, etc etc
AwaitingA
2 years ago
Can anyone tell me why plastic piping is always used as the coil?
TomK208AwaitingA
Reply 3 months ago
Plastic, being flexible, is easily manipulated, reused and yet maintains just enough memory to provide structure, plus is cheap.
cassioppeAwaitingA
Reply 2 years ago
I am making one this year's and plastic is cheapest. I tried shop for copper or other tubing but the cost is prohibiting. like thousands of dollars as compared to plastic tubing being 230$
stephencarlsbad.cassioppe
Reply 4 months ago
If you're trying to heat your greenhouse by heating tubing that winds through your compost, you should either use copper tubing or aluminum for the coil and then switch to plastic when transporting the heated air from the compost pile into the greenhouse.
Aluminum is much cheaper than copper. And using plastic/pvc pipe to transport the hot air once its collected by the copper/aluminum coil will provide less heat loss and valuable insulation properties while in transit.
It would be the same principle as using a copper frying pan that has a plastic handle so that you dont get burned.
Heat transfer into a copper pipe is double from what you get from aluminum. And a plastic pipe will give you 1/200th the heat transfer from the compost pile into a plastic pipe.
Plastic is very inefficient for transferring heat through its surface thus, the better choice for a heat coil collector that sits inside the middle of the compost pile is copper first, then aluminum.
Hello, I have a quoestion here. What about rebuilding this system after these 18 months? Do you remove everything, like: hay bales, pipes? How do you do it?
I would remove all composted materials and remix the non-composted materials into the new compost pile. If the hay is in useable condition, then why not reuse it?
