Computer Control Box
18,137
256
14
About: I'm french, I'm a second-year student at INSA Rouen-Normandie school of engineering. I love technologies (Arduino, 3D print...) and DIY projects. I practice electronic since I am 12
Hello everybody !
I made this box to "improve" my computer, with it you can switch the internet connection, audio output and microphone input. You can also turn on and off each fans of your computer case and control their speed even if they are not PWM-ready ! But that's not all !
(PS: I'm french, I hope my english is not too bad... :)
Let's go !
Step 1: Designing the Box
First, I used the PowerPoint software to get a good approximation of the position of the buttons and switches. Each button represents a function I want to add to my computer. Here, potentiometers are used to control 3-pins PWM fans (not PWM ready but I will now be able to control their speed thanks to a PWM generator).
The key switch will be use to power up / reset the computer. The red switch to kill the internet connection, the orange one to kill a USB connection, the blue one to mute speakers and the green one to mute my microphone. The 3 buttons at the bottom left corner are use to:
- Put my computer into sleep mode
- Control my computer case LEDs
- Power up a (future) watercooling
The emergency stop button stops the computer immediately.
Then I calculate the area needed to support all these buttons, the final dimensions of the front side are 100*300mm
After that, I used SolidWorks software to draw the shape of the box panels so I can print it to real scale. (usefull for later)
Step 2: Designing the PWM Generator
I inspired myself from these schematics to build my own PWM generator. I computed resistors and capacitors values in order to have a signal with a higher frequency than the original circuit. I needed to reach a frequency about 20kHz (if the frequency is less than 16kHz, the circuit and fans will be noisy)
I reach a mean value of 18kHz.
When I get values for the oscillator part, I computed values for the monostable part.
Once it have been done, I tried the circuit with an oscilloscope and a LED...No smoke... So I tried with a fan and it works !
Step 3: Making the PCB
I made a detailed instructable on how to make a professional PCB. Just follow it to make the PCB. Or ask https://www.pcbastore.com/ if you don't want to make the PCB yourself.
For soldering, start with ICs sockets in the middle of the PCB and then continue soldering all the components to reach sides. Finish by soldering fans connectors and potentiometers. All the components are soldered through holes except fans connectors.
The artwork I shared is made for 100*160mm PCBs to cut in half (to get 2 pieces of 50*160mm) once the PCB is made.
Step 4: Let's Build the Case
I use 3mm MDF to build the wooden case. There are:
- 2 pieces of 100*300mm
- 2pieces of 100*56mm for sides
- 1 or 2 pieces of 56*306mm, depending if you attached the case like me or if you want to completely close the box.
Trace some straight lines with the help of graduated square. Then cut all the pieces with a metal handsaw, it will be more acurate.
Step 5: Tracing Buttons Holes
Now print out the pattern of the button locations, cut each circle with a cutter (be patient, you have to be as precise as possible)
Use adhesive tape to attach the pattern on a 100 * 300 piece of wood. Place a dot in the center of each hole and mark the circles.
Proceed in the same way for the rear panel.
Step 6: Drilling Holes
Use a small drill bit (about 1-2mm) and precisely drill a small hole into each center of circle you made before.
Then, widen them with a conical drill bit to the diameter of the buttons and switches you have.
For the rear panel, I used very good cutters to cut holes, it's very precise.
Step 7: More Style !
After that, you can give a style of carbon fiber to your box by applying an imitation sheet on pieces of wood. Then use a cutter to unclog the holes.
Step 8: Assembling !
Insert potentiometers and PCBs into the front panel, then solder wires to each buttons. Put and secure them with nuts. Then connect all the wires to screw terminal. Insert the left wooden side and use brackets and hot glue to attach it. Do the same for the right side.
Once you are done place the rear panel. Be careful with pins. Use brackets and hot glue again.
Step 9: Making Wires to Connect the Computers
You also have to create cables to link the box to the computer. (power, fans, USB ports...)
Fan: On one side clamp wires into femal pins and insert pins into the plastic connector. On the other side, solder male connector onto wires.
USB: Clamp wires into femal pins and insert pins into the plastic connector (as shown in pictures) Do it on each sides of the wire.
Power: Connect power jack to a MOLEX. The inside of the Jack to the yellow wire and the outside to a black wire.
Also connect wires of the key switch to the corresponding pins on your motherboard to power up the computer, do the same for the LEDs button, the reset pins and watercooling if you have. I can't give more details here, it depends of your motherboard. But feel free to ask me if you are not sure ! ;)
Step 10: Parts List
I bought my parts at:
- aliexpress.com
- farnell.com
3 pins connectors male x 12
3 pins connectors female x 6 (+ wire)
4 Pins connector (for USB card-to-card link) x 2
2 Pins connector (for power card-to card link) x 2
Stereo jack socket connector x 4
10 nF capacitor x 15
1N4148 diode x 6
Relay (DPDT 12v) x 6
1k resistor x6
1k5 resistor x 6
3k3 resistor x 2
10k potentiometer (+ nut + washer + button) x 6
NE555 x 8
8 pins (2x4) socket x 8
screw terminal (2) x +/- 14
screw terminal (3) x +/- 3
USB port x 2
10 pins (2.54mm - 2x5) (male) connector x 1 / pins x 16 / female x 2 (+ wire)
RJ45 (2) port x 1
Power Jack connector x 1
Emergency stop (2NC) x 1 (+optional)
Key switch (2 x SPST) x 1
Switch with LED (SPST) x 4
Switch (SPST or SPDT) x 6
Button (momentary) with LED (SPST or SPDT) x 2
Button (latching) with LED (SPST or SPDT) x 1 (for the watercooling)
Slide switch (SPDT) x 1
PCB pin x 10 (1x6 + 1x4)
Power inlet socket (3 pins) x1
Electrical outlet x 1
Heat shrink tubing
Imitation tape x 4
I hope you liked this project, if it is right, you can also check my others Instructables ;-)
Thank you for supporting me. Feel free to leave comments !
Box Contest 2017
Runner Up in the
Box Contest 2017
    • Build a Tool Contest
    • Faux-Real Contest
      Faux-Real Contest
    • Paper Contest
      Paper Contest
    14 Discussions
    Joebarteam
    1 year ago
    Thank you to everyone for your friendly comments. I hope somebody will try to do it !
    BradGibson256
    1 year ago
    You are one smart guy! Awesome job
    heyshippy
    1 year ago
    This is really neat, man. Nice work!
    JeffMustache
    1 year ago
    Looks amazing! especially with the carbon-fibre-esque wrapping. Congratulations on the new addition, and thanks for sharing. :)
    srawcliffe
    1 year ago
    Cool. Reminds me of electronic equipment from the 1970s (I'm exactly 40 years older than you)! Et ton anglais est excellent. Chapeau !
    JorenM
    1 year ago
    I am very impressed! especially that you got 2 instructables featured in a single newsletter :D good job!
    gm280
    1 year ago
    Nice design, Nice effort, Nice layout. But you forgot the labels for all the switches and buttons and pots. Labels add that certain professionaisum to any project. JMHO
    UncleEdgm280
    Reply 1 year ago
    Agree on the labels making a project look like it was done well. Hate to admit that I often (usually?) quit when I can see that it works and I can control it, so my projects look like some amateur did it.
    Joebarteamgm280
    Reply 1 year ago
    Thank you, I will update this soon, but you can find/guess these informations in the schematics.pdf file ;)
    Anshu AR
    1 year ago
    Coooool!
    Looks like the control panel of some kind of spaceship :D
    EdwardF2005
    1 year ago
    Great Job with the article, the English is great as well!
