Computer Control of AC Devices
175,314
319
55
If you have ever wanted to control electronic devices from your computer to control or regulate your environment, this instructable will guide you. In this example of computer control, a USB relay device (USBmicro http://www.usbmicro.com - U451) will control two 60 watt light bulbs from a PC program.
Step 1: Safety First!
First off - Any time that you work with 120V voltages, safety is paramount. If you are not comfortable working with mains power, please seek the assistance of someone who is.
This instructable is intended only for someone experienced and confident in wiring high voltages. Do not attempt to do this if you are not. Household current can kill or badly injure you if you who do not understand the danger.
Only the U451 relay contacts should be used for control/connection to 110V AC. The relay screw terminals are isolated from the other circuit connections. DO NOT touch the U451 when there is 110V AC present.
Step 2: Major Parts
The major components used for this example instructable are:
  • USB relay interface USBmicro U451
  • two light bulbs
  • lamp sockets
  • 110V AC cord
The example project will control two independent 110V AC lights with the two relays on the U451. The U451 and lights will be mounted on a wooden plank.
Step 3: Project Mounting Board
The lamp sockets are placed on either side of the wooden plank used for this project. The location of the lamps are copied to the plank and traced with a pen. A center line is drawn through the circle to aid in mounting the lamps.
Step 4: Board Parts
Four adhesive-backed felt pads are added to the bottom side of the board. This will prevent the board from scuffing the surface that the board is placed upon.
The lamp sockets in this example setup will rest on some washers to provide some space for the wires that lead out from the under side of the socket and to the U451.
Step 5: Mounting Lamps
The lamp sockets are positioned and the screw locations marked with a pen. The screws and two washers are added and partially screwed in place. The lamp sockets loosely mounted as a "dry fit" just to see that they fit in place nicely.
Step 6: Mounting the U451
The U451 is mounted next to the lamps with small standoffs and #4 screws. Pictured are the two 3-screw headers - one for each relay.
Step 7: Wiring Parts
Because of the high voltage and current involved with this example, you must use a wire of sufficient diameter. In this case 16 gauge will suffice.
Step 8: Hot Wire Connection to the U451
The pair of wires from the two-wire plug consists of "hot" and "neutral" represented by black and white respectively.
Hot connects to each of the two common "c" terminals on the U451. This example project uses a wire nut to make the connection from the single source hot/black wire to the two pigtail wires that lead to the U451.
Step 9: Connections to Lamp.
The neutral/white connection is split into two wire pigtails that connect to the lamp socket (silvered connection).
One black wire connects from the N.O. (normally open) screw terminal connection on relay 1 to this lamp socket (brass screw on socket) while the other lamp socket connects in a similar way to the N.O. connection for relay 2.
Step 10: Lamps and Bulbs.
Mount the lamp sockets, tighten the screws. Install the light bulbs. These test bulbs were incandescent. Other more energy sensible light bulbs could be used.
Check your wiring. Once you are sure about the 110V AC connections, attach the USB cable to the U451 and your PC. Plug the AC plug into an outlet.
Step 11: Very Simple PC Programming
This project is brought to you by the magic of RobotBASIC. RobotBASIC (RB) is a free programming language and IDE (integrated development environment). It has support for controlling the USBmicro U451.
RB is free. FREE! You can write a program in the RB IDE and then save it as an .exe - a stand-alone executable that doesn't need the IDE to run. The USBm.dll is needed to go along with that file, but that is free, too.
I'm not going to get into the details of the program in this instructable. The entire program is the 35 lines in the image below. The program is easy to copy into the IDE and simply run. Here is the program as text: (note the spacing gets screwed up.)
// U451 relay control program
// If the DLL is found...
if usbm_DllSpecs() != ""
// And the device is found...
if usbm_FindDevices()
// Initialize the U451, outputs
n = usbm_DirectionB(0, 0xFF, 0xFF)
// Create title and two checkboxes for the relays
xyText 10,10,"Relay 1 Relay 2","",20,fs_Bold
for i = 0 to 1
addcheckbox "" + i, 10 + 120*(1-i), 60, " "
next
while true
for i = 0 to 1
if getcheckbox("" + i)
n = usbm_SetBit(0, i+8)
else
n = usbm_ResetBit(0, i+8)
endif
next
delay 100
wend
else
print "There are no Devices"
endif
else
print "The USBmicro DLL is not installed"
endif
Step 12: Running the Program
When the program runs you are presented with two boxes that you can click on or off. If everything works the bulbs follow suit!
Step 13: Let There Be Light!
You now have control of two lights in this example instructable.
This setup could easily be modified to control the power to almost anything that plugs in. And RobotBASIC (www.robotbasic.org) can be used to make much more complex programs that, for instance, turn on electric devices based on a complex PC schedule.
Let there be light bulbs. :-)
Step 14: Updated: Instead of Wiring the Lamps Directly...
...wire the relay into your own outlet.
Please see the specifications for the U451 for limits to the current for the devices you control.
Runner Up in the
USB Contest
    • IoT Challenge
      IoT Challenge
    • Classroom Science Contest
    • Fandom Contest
      Fandom Contest
    55 Discussions
    ManuelK20
    Question 6 months ago on Step 14
    Is it possible to do a 220 Dryer outlet to this? Or is there a relay that would handle a 220 outlet?
    MisterXR
    Question 1 year ago on Step 10
    Created an EXE file from the text in the article. Connected my USBmicro U451, which the Windows XP operating system recognised ok, but the EXE just flashes very quickly on screen and disappears before I have time to read any error message etc.
    How do I troubleshoot this please?
    Helma MariaT
    3 years ago
    What is the easiest/cheapest way to controll 240 light bulbs?
    indestructableHelma MariaT
    Reply 3 years ago
    The obvious solution of using 120 U451 is a bit painful.
    Better solutions depend on your electronics construction skills. A single U451 can drive 6 more relays directly from the J4 connector. So now a solution would involve 30 U451s plus relays. J1 can't drive the coils of relays directly, but with some transistors could control 8 more relays, cutting the number in half.
    You can buy boards on ebay that have 8 relays on them. The boards are $7-10. They can be controlled by a USBmicro board that is similar to the U451 and so one U421 could control 2 of these 8-relay boards. So 16 relays controlled by each U421 would be 15 sets of these controllers.
    Instead of mechanical relays, you could also use solid state relays.
    jonA4
    4 years ago on Step 14
    Just a heads up. The plastic covers used are intended to be flush mounted against a wall since they aren't structural. For exposed boxes you need the metal covers that don't extend past the junction boxes themselves.
    Jumprocks
    5 years ago on Introduction
    wHi, what woudl I need if i wanted to control 4 lights??
    amalkady
    7 years ago on Step 13
    what sholud i use if i want 220 v??
    indestructable
    The U451 is limited to about 2 amps at 110V. So at most each relay could control about 200 watts.
    ToddRwhiplash
    From their website:
    PCB trace widths limit the connections to the relays to about two amps - this should not be exceeded.
    The board is what's limiting it, not the relays. Probably not that hard to work around if necessary.
    reoozeitToddR
    My general knowledge of relays tells me that the 120v side is the side being switched on and off by the relay- essentially making it the same as the standard single pole switch in your house. And if those relay contacts are rated at 10 amps, they should be able to handle around 10 amps. The relays in components are typically purchased from other manufacturers and integrated into products by the electronics manufacturers. When they say differently about the connection to the relays being limited to 2 amps and are talking about the pcb, the 120v connection to the relays has some pcb trace going out to a separate terminal block- and that is true in this case (which would be a not-so-smart way to design a relay because it creates confusion about ratings, limits uses, and it could be done with terminals integrated into the relay to avoid all of this! ). In that case, a direct soldering of your wires to those contacts bypassing that pcb connection should suffice as described by author in comment below. Good luck, have fun, void your warranties, and BE CAREFUL! Don't hurt (enter your name here)!
    indestructableToddR
    A reasonable work around is to use a heavy gauge wire to connect to the soldered relay connections on the bottom of the U451 USB relay board (in pictures above). You make direct heavy connections to the relays themselves to overcome the limits of the printed circuit board.
    maewertmaewert
    sry for the broken link:
    https://www.instructables.com/id/Yet-Another-Arduino-110v-Power-Controller/
