Concrete Garden Lighting
60,572
909
27
With this instructable, you can create your own lighting design for your garden with using concrete. Concrete is a cool material to work with, also a good choice for garden lighting because of the natural look. So just keep reading this instructable and start to create your own concrete lighting. Good luck!
Step 1: The Design
First of all, you need to design a 3d shape. I designed mine in SketchUp based on my earlier sketches. But you need to keep in mind that concrete is a heavy material which is also fragile, so you should be thinking these facts while designing. My design is a triangular prism with another rectangular prism connected to each other and combined into one shape. Spotlights are placed on both top and bottom sides of the rectangular prism.
Step 2: Materials
  • 10 kg’s of cement
  • 10 kg’s of thin sand
  • 7 pieces of wooden boards as listed;
1 x 48x24 cm
24x24 cm
26.8x24 cm
16.8x24 cm
10x24 cm
2 x 15x24 cm
  • 2 x (46 mm radius) spotlights and min. 3 m’s of electricty power cable
  • 20 cm’s of (50 mm radius) plastic pipe
  • 1 m of (10 mm radius) plastic hose
  • 1 pack of soft soap (or any other material to rub inside to the mold, for making mold removal easier after pouring; butter, motor oil etc.)
  • Various tools for preparing the mixture (a mini shovel, a spatula, a bowl etc.)
  • Styrofoam cubes (to decrease the weight)
Step 3: Preparing the Mold
After the design process, you have to build a wooden mold shaped as your design. (After the pouring; when you remove the mold your design should appear.) According to the shape (for example for my shape) you should put together the wooden or hardwood boards as shown by the image.
Before putting together the wooden pieces; you should decide where to put the spotlights and drill holes for spotlights’ bodies, accesories and cables. Also another hole for the power cable. (from behind if possible) This step is when you use the pipe and the plastic cable. Because you need to create a tunnel inside the concrete block. Only possible way to do this, is to place the connection before the pouring. Connection and placement of the pipe and the plastic cable are shown by the image. Important: Cut a hole through the midpoint of the pipe and connect the end of the hose to this hole. It will create a space inside which allows you to place both spotlights from sides of rectangular prism and power cable from behind the block.
If you screw the wooden boards to each other, it will be easier to remove after pouring.
The other important thing is, to not to forget rubbing soft soap to inside faces of the mold. It will create a layer between concrete and the mold and removal will be much easier.
Step 4: Preparing the Mixture
According to the volume of your bowl, pour the amount of cement and sand equally. Mix it. After the cement and the sand is completely homogenized, you should start to pour water and keep mixing until the mixture reaches to the correct consistency. The correct consistency is pretty much the same consistency as mayonnaise.
Step 5: Styrofoam Cubes
If you wish, you can cut a few amount of styrofoam cubes to put inside the mold while pouring. Concrete itself is a really heavy material so it is an easy way to decrease the weight. Using a hotwire foam cutter is the easiest way for this. You can also cut different sized cubes for tighter spaces in your mold.
Step 6: Pouring
After the mold and the mixture are ready, it is time for pouring. Make sure you rubbed soft soap inside of the mold and created a layer. This is the easiest part: just pour the mixture into the mold with a spatula. (If you decide to put styrofoam cubes into the concrete block, start placing them insideafter pouring at least 30mm.'s of concrete mixture. You should avoid placing them too close to the surfaces otherwise they will be visible after you remove the mold.)
After pouring, you should wait for 2 days to remove the mold. Concrete block gets completely dry after minimum 15 days, but it starts to dry up from surface to core so waiting for 2 days is enough to remove the mold. Concrete material wants to absorb water while the drying process, so you should pour water on it at least twice a day otherwise it will crack from inside. This is the main problem to avoid.
Step 7: Mold Removal
After waiting for 2 days, your block is dried on the outside. You can remove the mold by using a drill. This is the advantage if you screwed the boards to each other. Next step is to wait for 5 more days, you can observe the change and the color difference through days. Just don't forget to pour water twice a day. 5 days later pouring water won't be necessary and you can start to use the lighting if you want then.
Step 8: Sanding & Flattening Faces
After 5 days, you'll realize the color of the block has changed. It means it is dry enough to use it. For sharp egdes like I designed, you should use a sandpaper to flatten the faces and sharpen the edges. Also you can remove the plastic pipe, you won't need it anymore. You can try to blow into hose from behind and make sure air goes to spotlight holes. Your concrete block is ready for the last step.
Step 9: The Result
Send the power cable in from behind all the way to spotlight holes, connect spotlights to power cable and place the spotlights into holes. Plug it into socket. And that's it! You made your own concrete lighting. All you have to do is carrying it all the way to your garden. Enjoy!
  • Arduino Contest 2019
  • Gardening Contest
    Gardening Contest
27 Discussions
greenbriel
1 year ago
Very nice indeed. I'm just getting into concrete, but it's a great material. Thanks for sharing this and for documenting so well.
And don't think no-one noticed your fancy cast shadow on the grass in the main project photo :-D
hotpop
3 years ago
Is this waterproof??
kgokcakanlukeg01
Reply 4 years ago on Introduction
Sorry for late reply, I bought them from a local store. They're highly obtainable in almost every lamp or electricity stores.
drose25
5 years ago on Introduction
Great design! Quick question: are those led spots weatherproof or did you do something to protect them?
kgokcakandrose25
Thanks and sorry for late reply. I don't have any information about if they're weatherproof or not, but my concrete block seems to be protecting the system inside.
aysglodacı
4 years ago
owww ww amazing now i have to try it :))): p
Manny B
The design hints at a chair. Knowing that people will do what they do, i'd reinforce it with rebar and get ready for anything.
ghavel
Great project! You have created a very informative ible too. You could also incorporate a solar charged light very easily into this design.
malialtin
5 years ago
You've achieved to attract people with your nice work. Continue the good work on more sustainable products ;)
kbc2
5 years ago
dig it! looks like a high end garden deco. will definitly attempt this around the yard. may try for a solar version too.
kebmoore
This is impressive. Earkier today, I was thinking about making concrete lights to replace the cheap plastic ones lining the walk to our front door. I am thinking about a simpler design because I plan on 8 lamps. This is a great design and a great set of instructions.
