Concrete Leaves for Gardens or Fountains
170,950
838
98
Kindly vote for this in the Concrete Casting Contest!  Thanks ever so much. ( :
This instructable is on behalf of Madeline Werner, the caster of these lovely leaves.  Being inbetween jobs, I have the time (and inclination) to do it!   This is an easy, cheap, and fun way to make a lasting addition to any landscape. We hope you enjoy our first instructable.  Feedback welcome. ( :
Materials needed:
-Large, fresh, veiny leaves such as rhubarb (don't worry if they have a few holes) or smaller like hosta
-50 lbs. Play Sand for forming
-Plastic wrap, food storage type
-50--80 lb. Bag of Concrete (sand aggregate only)
 -Nitrile gloves
-Spray and hand paints, brushes, etc.
-Water sealer for concrete
Optional: Portland Cement, concrete colorant, wire to coil and set for hanging, chicken wire or drywall mesh joint tape for more strength
Supplies:
Step 1: Gather Leaves
Put the shout out to all you know, we offer a free finished leaf to anyone who donates to the cause.  I've even stopped by a commercial farm, and they were happy to oblige.
Keep in water until ready to use, but no more than a couple of days.
Step 2: Prep the Casting Area
Maddie started off doing them on the ground in the carport, then I built her a table in her shop.  (Much easier on the back!)  Extra large are still done on the ground.
Press the leaf on a pile of sand to desired shape, mounding or flatening. Remove the leaf, then cover the sand with plastic wrap.  Return the leaf to its original spot.  Prep all leaves to be cast before the next step.
Step 3: Mix the Concrete
Maddie has found that adding Portland cement (Up to a coffee can per 40 lbs.) makes a stronger leaf, and is the easiest way to get the water/concrete to the nice pasty consistancy if you've added too much water. A 1/2 bag (about 40 lbs,) of concrete will do 5 medium sized leaves.  We call approx. 18" across the widest point "medium" sized.  12" and 24" would be small and large.
Step 4: Pile It On
Still talking about a medium leaf, it is about 3/4  to 1" thick along the rib, tapering to about 3/8" thick at the edges. Rolling the wrap can neaten up the edges.  Do the thickness in two steps if you plan to add the hanging wire, or mesh tape/chicken wire.  The latter advised if hanging, and for large to monster leaves.
Step 5: Let It Be for at Least a Day, 2 Is Better
2 is better!  (Water bottle is for scale)
Step 6: Pealing Takes the Most Time!
We've tried compressed air, and a jet of water (from garden hose sprayer).  It seems that patience works best.  The first one still needs work. Needle nose pliers, picks, and stiff brushes can help.
Step 7: Painting
No holds barred here, whatever you want goes.  We've been liking the metalic look lately, with some accent color in the veins. A sponge for blending works nicely.  Finish with the water seal front and back after the paint has dried and you're done!  Resealing once a year is highly recommended.  One warning, if you bring one to work or a gathering to give to somebody...you will be making more!
Concrete and Casting Contest
Runner Up in the
    • Gardening Contest
      Gardening Contest
    • Fandom Contest
      Fandom Contest
    • Woodworking Contest
      Woodworking Contest
    98 Discussions
    LaurieK3
    3 years ago
    I made a elephant ear leaf and It has cracked on one of the side veins. Is there any way to fit it?
    sharonnah59LaurieK3
    Reply 3 years ago
    Gorilla Glue works great for this. Just remember it expands, so don't use too much on the top side.
    Sumethat
    2 years ago
    I want to make 5 of these beautiful pieces of art this weekend and want to make a tall fountain. I don't know how to mount them. Please share your ideas on how to support/mount these leafs on to a metal stand
    MaryP148Sumethat
    Reply 2 days ago
    What I used on my fountain leaves were 1/2" rings. I set them partially into my cement leaf as it was drying, plus I had pre drilled a small hole in the ring for a set screw. I put them on any post that's 1/2" as long as it is strong enough to support them and, I can put the leaves any direction I want.
    CarolineT27Sumethat
    Reply 10 months ago
    I use 8 or 10 inch rebar set in a concrete base. For a simple stand you would use 1, for something more elaborate, you might want want to get someone to weld the rods. I leave or drill holes in my leaves and then cement them in, either covering the bar completely or leaving some areas exposed for interest. The most important thing is allowing the leaves to cure as slowly as possible to increase the strength. See ex below.I have set the rod through the base bowl, and built up a concrete base underneath which doubles as a stabiliser.
    sharonnah59Sumethat
    Reply 2 years ago
    Without seeing the stand...hard to say! Assuming there is a flat surface on it, you could use concrete to make a small "stand" for the leaf, perhaps using a plastic coffee can cut down to a desired tipping angle as a mold. (Then let it harden on the concrete leaf, then remove the can.)
    MaryP148
    Question 2 days ago on Step 7
    Hi, Can I make a silicone mold from a leaf that I casted a year ago
    leafjeannie
    Question 10 months ago on Step 7
    For larger leaves, how do you reinforce them? I've heard of drywall mesh tape and chicken wire, but I'm not sure how to use either one. Thank you.
    1 answer
    sharonnah59leafjeannie
    Answer 10 months ago
    You can also use screen door material. Just cut where it bunches up on curves. Apply 1/2 thickness of concrete, press in reinforcement material (2" away from edges) then add the final thickness of concrete.
    CorryD
    2 years ago
    Love these. Thank you for the tutorial. I shared on my Pinterest and Facebook page.
    littlehoneybunny
    2 years ago
    Swallowtail seeds sells dinosaur food seed (giant rhubarb leaves) n going to grow my plant and harvest leaves for fountaiin. Am unsure about how to stack secure leaves for fountai . . . . Any suggestions
    TedN6
    2 years ago
    would it be possible to use varnish or fiberglass for the project
    bricky62
    3 years ago
    when buying Portland cement ask for the back saver bags. only 47 lbs. and half the weight of a big bag. don't ask for concrete. concrete has stone for aggregate. you want to mix Portland with fine sand.
    SuzanneK6
    3 years ago on Introduction
    I love these! Can you tell me How you make them into a three tier fountain?
    chickenleg12
    How do you get the edges of the leaf to look so neat? Also I found that spraying the leaf with Pam helps with removal.
    Pulling the plastic wrap up and molding with your hand helps the edges look neat. We've tried Pam, but then the paint runs. Washing/blow drying seems just as much of a pain as peeling.
    sharonnah59
    5 years ago on Introduction
    By the way, we did try using a cooking spray on the back of of the leaf to hopefully help its removal after the concrete set. Not only did it not help, but made the surface resistant to the paint! Fail.
