Conductive Paint
259,838
633
201
The goal of this experiment was to try to find an alternative to commercially available conductive paint. It is incredible stuff but expensive. I've read other Instructables like Makerboat's $1 Conductive Ink and IceCats' Paper Electronics. They helped me arrive at my own recipe, which uses only two ingredients but I think my testing is more reliable.
To make the winning recipe you need:
  • Graphite powder*
  • Acrylic paint
  • A jar with an airtight seal
To complete every test you need:
  • Elmer's Glue-All
  • Titebond III Wood Glue
  • Acrylic paint
  • Wire Glue (tm)
  • Graphite powder
  • 4 wooden toothpicks
  • 4 jars with airtight seals
  • Paper
  • Ohmmeter
  • 2 zip ties
*Be careful with graphite powder because inhalation can lead to respiratory problems.
Step 1: Glue-All and Graphite Sample
For the first recipe graphite powder was mixed with Elmer's Glue-All until the consistency was spreadable. Be careful when adding the glue because squeezing the bottle will shoot a blast of air into the jar and graphite powder will blow everywhere. The third picture illustrates this.
The ratio was:
  • 2 parts Elmer's Glue-All
  • 1 part graphite powder
The result was fluid but very thick. It could still be used as an adhesive.
Two lines were drawn with the toothpick. One thin line and one thick line. The toothpick was wiped off on the side of the jar and allowed to dry next to the lines.
Step 2: Titebond III and Graphite Sample
The second recipe was Titebond III and graphite powder.
The ratio was :
  • 1 part Titebond III
The result was fluid but not runny.
Step 3: Acrylic Paint and Graphite Sample
The third recipe was acrylic paint and graphite powder.
The ratio was:
  • 1 part acrylic paint
The result was slightly thicker than paint.
Step 4: Control Sample With Wire Glue (tm)
The fourth sample was commercially available Wire Glue (tm) from Think Geek. The Wire Glue(tm) needed to be stirred so another toothpick was used.
The Wire Glue(tm) was much runnier than the other samples so the lines were not as bulky. Less material being put down means a higher resistance since there is less carbon/graphite for conduction.
Step 5: Preparation for Testing
All the samples dried for five hours and were labeled.
Close-up pictures were taken to show the thickness of each sample. In order they are:
  1. Elmer's Glue-All
  2. Titebond III
  3. Acrylic paint
  4. Wire Glue(tm)
To ensure the samples were tested uniformly two zip ties were tightened around ohmmeter test probes. This ensured the probe tips were the same distance for each test.
Step 6: Testing Elmer's Glue-All and Graphite
Each sample of Elmer's Glue-All and graphite was tested with the fixed-width probes and recorded.
Step 7: Testing Titebond III and Graphite
Each sample of Titebond III and graphite was tested with the fixed-width probes and recorded.
Step 8: Testing Acrylic Paint and Graphite
Each sample of acrylic paint and graphite was tested with the fixed-width probes and recorded.
Step 9: Testing Wire Glue(tm)
Each sample of Wire Glue(tm) was tested with the fixed-width probes and recorded.
Step 10: Results
The acrylic paint is the most conductive material in this sample set when painted with a toothpick. The materials are commonly available and inexpensively. The acrylic paint cost $0.78 and the graphite powder cost $0.75. All prices are in US Dollars.
The advantage of the Wire Glue(tm), which has the next highest conductivity, is that it has a lower viscosity so it could potentially be used with custom pen nibs. Store-bought pen nibs were used with the Wire Glue(tm) in a different experiment but it was inconvenient to apply.
This build took me two days and one more to write these instructions.
I run a blog where I talk incessantly about the things I build, including an unabridged version of this project with videos that show the viscosity of the samples. There are other neat things there like a device that lets you hear temperatures and a keyboard you can use from inside your pockets.
Paint It! Sponsored by Olympic Paint
Finalist in the
2 People Made This Project!
  • Tape Contest
    Tape Contest
  • Trash to Treasure
    Trash to Treasure
  • Arduino Contest 2019
201 Discussions
SatchM
Question 4 months ago on Step 8
Hi there! 1:1 ratio is 1g Graphite to 1mL acrylic paint? Any particular acrylic paint you use?
mwillerich
1 year ago
I used the acrylic/graphite powder mix today to shield a few guitar cavities. After the first (and so far only) coat I measured in various pockets anything between 500 and 1k Ohm. No idea if that's "Faraday" enough :-D.
I used 9g of graphite on about 12 ml of acrylic paint. The paint was just under 3€ for a 15ml jar, and I managed to order the graphite on ebay for 1€ for about 30g.
AllanT40mwillerich
Reply 11 months ago
You should use copper shielding.The paint is good for hard to reach areas or as a base coat before you put down the copper.From all the videos I've seen the paint doesn't do much either way.
gdjidje
Question 11 months ago on Step 1
So from what I've seen with conductive paint the powder substance being used is almost always graphite or carbon which makes a boring black colour. Is it possible to use something else like magnesium safely to make conductive paint?
1 answer
24Enggdjidje
Answer 11 months ago
A number of things can be used to make the paint conductive. Magnesium will conduct electricity but I don't consider powdered metal safe.
Exercise a lot of caution when working with any powdered metal for the health risks and flammability risk.
AllanE15
1 year ago
Would this possibily be safe for rear window in cars? General consensus is over larger gaps in the grid conductive paint fails due to high resistance, and that it flakes off. I'd like to give it a go but worried it'd be too much? I've put Primer on the lines which is hard to get off (good thing) then go over with conductive paint, perhaps that'd act as an insulator between glass and heat, possibly have high heat spots even?
24EngAllanE15
Reply 1 year ago
I can't guarantee this would be safe but I would be confident enough to try it in my own car. I suspect that the resistance of this paint would be higher than the OEM traces so you may end up with a cool spot but that's better than the whole strip remaining nonfunctional. Good luck and let us know if it works.
AllanE1524Eng
Reply 1 year ago
Been testing the existing grid, gives me 3 at furthest distance on a complete line, to 0.4 within roughly an inch. Would need to experiment, but it should do the job over small breaks. I'll have a go soon, be a lot cheaper than wasting conductive paint
24EngAllanE15
Reply 1 year ago
Good luck. Take a picture if it works and let us see!
BreelO
1 year ago
Hi , i think I might be a bit late to the party but, im searching for a "DIY" version of winter gloves. I've seen conductive thread is the best option but its difficult finding it in my country. The goal is to make the index finger and thumb of a glove conductive enough to use with a cellphone on cold weather. Do you think "painting" the fingers of a pair of wool gloves with this mix will do the trick? I bet you have to make the paint go through the fabric so the finger and the exterior of the glove can conduct correctly.
24EngBreelO
Reply 1 year ago
Sorry for the late replay.
I think it would be conductive enough but I think the paint would flake away during normal use. Maybe even worse, since graphite is involved, you would leave marks on everything you touch. It would be like having a pencil for a finger. Maybe you can be carbon fiber more easily? Not the kind which has already been combined with epoxy to make a hard surface but the woven cloth.
SammyL17
1 year ago
Hey, I was wondering if you could answer my question since i've been making the acrylic based conductive paint with graphite but when it dries it doesn't seem to be conductive anymore. Is this what is supposed to happen? How can i possibly leave it conductive when dry?
thnx!
24EngSammyL17
Reply 1 year ago
The paint was always dry when I tested it. Perhaps you aren't using enough graphite powder which will make nearly anything conductive if you use enough. When I mixed it, I used equal amounts by volume, not weight. Perhaps this is the problem. The process for experimenting, shown above, can be followed but instead of different glues/paints, try different proportions of paint and graphite powder. Good luck.
The Gretz 69
1 year ago
i'm looking to shield the inside cavity of a bass guitar pick up area. i was looking at shielding tape but it's so expensive. So i was looking at shielding paint. same deal just tooo expensive.
So will this paint recipe work for what i'm trying to do?
24EngThe Gretz 69
Reply 1 year ago
I haven't tried it myself but it should work well. If you can wrap a pick-up in some painted paper first that could be a good test.
If this works, please let us know here so other people can follow your example!
tipigeon
1 year ago
Now this is very very experimental, but would it be usable for metal plating using electrolysis for exemple?
24Engtipigeon
Reply 1 year ago
Are you talking about electroforming?
Some people have tried electroforming with this recipe but it doesn't hold up well in since acrylic paint isn't meant to be submerged in water. White glue would also be a bad choice. I have heard of people using silicone with a much higher graphite ratio but you will lose detail because it is so thick even if it does work.
I wish I had a better answer for you.
Let me know if I misunderstood your question.
tipigeon24Eng
Reply 1 year ago
No you were spot on thanks alot for the feedback! Since what im gonna use is a bootleg DIY method i wont need to submerge it fully so i'll give it a go on a scrap piece when i can
JamieO34
1 year ago
Do you think using metal powders such as copper and aluminum powder would work?
Why is Graphene the ideal conductive material in making conductive paint?
Thank you so much!
24EngJamieO34
Reply 1 year ago
Graphite powder is inexpensive and easy to buy. Some metal powders are flammable and harmful if they get on your skin. However, if you are careful they may provide better conductivity.
