Connecting 16x2 LCD to Raspberry Pi
111,358
145
When you’re done playing with LEDs, motors,switches etc  the next thing to do is connecting a 16×2 alphanumeric LCD module. The LCD modules are affordable (less than $10) and effortless to interface to the Raspberry Pi. They have 16 data pins but we would be using only 6 pins.
Almost all 16×2 LCD available in the market are based on Hitachi HD44780 LCD controller. This permits you to purchase  nearly any unit and make sure its determined to work in  same way as all others.There are loads to browse on eBay.
Step 1: Circuit
The circuit consists of a 8 bit I2C port expander IC named PCF8574. HD44780 is interfaced with Raspberrypi via PCF8574.
For the main circuit & schematic please visit my blog for more info- http://www.rpiblog.com/2012/11/interfacing-16x2-lcd-with-raspberry-pi.html
Step 2: Code
Going to the programming part, Python is utilized to control the logic part.I have composed a straightforward library to communicate with the LCD utilizing the I2C bus.Please visit my Raspberry Pi Blog for code and other projects:- http://www.rpiblog.com/2012/11/interfacing-16x2-lcd-with-raspberry-pi.html
    • Tape Contest
      Tape Contest
    • Arduino Contest 2019
    • Trash to Treasure
      Trash to Treasure
    3 Discussions
    rahulkar
    6 years ago on Introduction
    The library used here is a simple python script, which contains all the necessary hardware settings to communicate with the LCD via I2C bus.
